BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    NEW RELEASE! KW Height Adjustable Spring Kit (H.A.S. Kit) F90 M5
      01-08-2019, 06:33 PM   #89
AutoTalent
AutoTalent's Avatar
2311
Drives: e92 M3 6mt | e60 M5 6mt
Bump!
      01-18-2019, 02:04 PM   #90
AutoTalent
AutoTalent's Avatar
2311
Bump!
      05-22-2019, 08:42 PM   #91
AutoTalent
AutoTalent's Avatar
2311
Bump
      06-11-2019, 05:41 PM   #92
AutoTalent
AutoTalent's Avatar
2311
Bump!
      07-02-2019, 06:28 PM   #93
AutoTalent
AutoTalent's Avatar
2311
Bump!
      07-02-2019, 09:02 PM   #94
Evanhuang13
Drives: bmw m5 f90
As a competition owner, should I go with KW HAS?What are the difference besides lower drop? Any thoughts?
      07-02-2019, 09:05 PM   #95
AutoTalent
AutoTalent's Avatar
2311
Depends on your objective. Feel free to email me and I will give you my honest input.
      07-02-2019, 09:19 PM   #96
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
The main difference is KW HAS allows you to adjust the drop to your liking.
But as far as lower, M550iX I think is the lowest drop.
KW HAS uses helper spring.
For some, the helper spring will give comfort, but for my personal taste, I don't really like a combination of helper spring with progressive spring.
For example, my customer with Nardo Gray is on HAS and he prefer Comfort suspension.
While when I drove the car, I like it better in Sport setting for the suspension.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
      07-03-2019, 02:46 AM   #97
Evanhuang13
Drives: bmw m5 f90
Thank you for your reply bros. I saw lots of owners said KW HAS is more stiffer than the OEM. maybe they are comparing to the regular m5 not the compt.
r33_RGSport12971.00
      07-03-2019, 01:29 PM   #98
windtendo
windtendo's Avatar
1716
Drives: 2023 M5C
2023 BMW M5C  [0.00]
1989 BMW M3  [0.00]
Maybe I'm misunderstanding, but that helper spring is just there to provide tension against the adjustment collar. As a mechanical engineer, I think it's a bit unnecessary when there's a locking Allen screw on the collar itself.
IG @windtendo_m5
Appreciate 2
r33_RGSport12971.00
Mcc420475.00
      07-03-2019, 04:50 PM   #99
Used2be
Perennial PFC
Used2be's Avatar
Drives: F90 M5 DG/Aragon
I believe the helper spring is there to keep the main spring from losing tension if the owner wants a large drop and has the lower spring collar turned way down. When the weight of the car is loading the suspension, the helper spring is pretty much fully compressed at any ride height. But, at full droop with the extra distance between collars, there's too much travel for the main spring alone and it'd be loose between the spring collars without the helper. Does that make sense?
      07-03-2019, 05:51 PM   #100
Evanhuang13
Drives: bmw m5 f90
And also does the kw has give more performance than the competition oem spring?
      07-03-2019, 10:47 PM   #101
soopa
113
Drives: 2018 F90 M5
Quick review of the KW HAS
I had them installed this morning and I cannot tell any significant increase in stiffness on normal road conditions (Comfort / Sports / Sports+)
No sign of bouncing either.
However, I can tell the system is stiffer when going over speed bumps as the KW triggers my dashcam that has impact sensors which didn't happen before.
I am dropped about 10mm all around.
Will report back after some more road time.
      07-07-2019, 03:15 AM   #102
Slayerkillhate
Ukraine
67
Drives: M8
Which one is better? KW or Competition suspension?
      07-08-2019, 03:10 PM   #103
AutoTalent
AutoTalent's Avatar
2311
Better is subjective, better looking - KW
Ride quality will change with how low you go, typically doing springs you do lose a little bit of comfort since the shocks/dampers are not designed to work with lower springs.
From our experience, the ride quality is very good. No drastic loss in comfort and improved performance in handling and steering feel in all three modes
      07-15-2019, 06:36 AM   #104
dappercivility
dappercivility's Avatar
204
Drives: F90 M5 Competition
Is the KW HAS kit able to have a uniform wheel arch gap for both the front and rear?
Born in M Town
      07-15-2019, 04:04 PM   #105
AutoTalent
AutoTalent's Avatar
2311
Uniform 1 finger gap front and rear, very do-able
If you wanted the arch to sit right on top of the tire on stock wheels, no.
The lowest settings front and rear will make the car sit level, which is going to have a half finger gap front and no gap in the rear
      07-20-2019, 08:33 PM   #106
clutchdj
1879
Drives: a few cars
Both are different. Comp suspension is really good but taut. KWs springs in base cars smooth out the ride. Rebound is not as sharp especially in the rear, otherwise it’s exactly like stock. My base f90 is about 1/4” lower than a comp on KWs
      07-21-2019, 12:49 AM   #107
soopa
113
Drives: 2018 F90 M5
I think Slayer might have been referring to the M Performance HAS kit:
      07-21-2019, 03:45 AM   #108
Slayerkillhate
Ukraine
67
Drives: M8
Both are different. Comp suspension is really good but taut. KWs springs in base cars smooth out the ride. Rebound is not as sharp especially in the rear, otherwise it's exactly like stock. My base f90 is about 1/4" lower than a comp on KWs
Just try to figure out is that reason to set KW on M5 competition and now I know about M performance HAS kit and what to set for best look and not loose and maybe do better
      07-21-2019, 05:33 AM   #109
soopa
113
Drives: 2018 F90 M5
About 3 weeks into the KW and I am very happy with result. The car feels just right in Sports suspension mode for spirited driving. I am dropped 15mm front, 10mm rear and plan to raise the rear 5mm as the car looks a bit squished.
      08-13-2019, 05:07 PM   #110
AutoTalent
AutoTalent's Avatar
2311
Please let me know if anyone has any questions
