BMW M5 F90 (2018+) General Forums F90 M5 General Forum    Limit on LC?
      02-08-2021, 07:01 PM   #1
gpdriver17
294
Drives: F90 M5
Limit on LC?
When I first got my car, using launch control, shifts to 2nd were seamless. I couldn't even tell the car shifted. I've probably done it a few hundred times now and anymore it shifts just like it normally would in auto mode. There's a noticeable delay going from 1st to 2nd gear.
This isn't just in my head, I have logs to back it up. Also dragy times. I noticed my 0-30mph times are the exact same as the used to be, so is 60-130. But 30-50 is about .3 seconds slower. 50-60 is also the same as it used to be. The result is basically that even with a JB4, 0-60 is right around 3.0 instead of 2.6-2.7 like it used to be. Also 1/4 mile times are up about .2-.3 seconds.
Does anyone know if BMW limits the number of times LC will work? Maybe to save the transmission? It still says "Launch Control Active" but it's not the same. Would a TCU tune address this?
2018 BMW M5
2018 Porsche GT3
2023 Porsche Macan S
2023 Porsche 911 Turbo S
      02-08-2021, 10:55 PM   #2
Resjudicata
Resjudicata's Avatar
Drives: M850i convertible
if you updated your idrive software, I noticed a difference from the 11.2019.45 vs the new 07.2020.55 and 11.2020.50.
      02-09-2021, 09:43 PM   #3
limeypride
limeypride's Avatar
Drives: 2022 M8 Competition GC
There's a launch counter and you've exceeded it. Instead of convulsing seamlessly between gears, I'd bet money you're now hearing a distinct crack at each shift... right?
I've posted about this many times—it's a thing. I burned through them on my M8 in about 3 months.
A TCU tune should address it—that exists for pre-LCI F90s but not for the later models nor for M8s.
The limiter is the transmission, not the engine/ECU.
Appreciate 4
lsal137.50
lambmw179.50
Patton2502939.50
      02-10-2021, 03:04 AM   #4
AHall
982
Drives: 1993 Nissan 240sx
Good info LimeyPride. What are the effects at this point?
      02-10-2021, 07:35 AM   #5
limeypride
limeypride's Avatar
Nothing beyond the shifts but that slows down acceleration significantly.
      02-10-2021, 08:38 AM   #6
AHall
982
Thanks but do the shifts eventually return to normal
      02-10-2021, 10:25 AM   #7
limeypride
limeypride's Avatar
The crack you hear is the sound from a normal high-load shift without launch control. So this is what you'd hear when you've exceeded the limit—this is the new normal. Short of a thus-far elusive TCU tune, there's no way I know of to restore LC's factory shift mode.
      02-10-2021, 11:03 AM   #8
gpdriver17
294
Drives: F90 M5
limeypride Thank you! Confirms what I suspected, unfortunately. Are TCU tunes just like ECU tunes as far as warranty goes? The dealer can tell even if it's flashed back before going in? I'm getting really tired of dealing with this car. Strongly considering the model s plaid. 0-60 in < 2 seconds and 9.2 1/4 miles with a warranty. No e85/boostane/meth mixing.
2018 BMW M5
2018 Porsche GT3
      02-10-2021, 11:32 AM   #9
gpdriver17
294
Drives: F90 M5
I talked to some others about this and found it is limited to 100. TCU Tunes don't appear to fix it, but help...
2018 BMW M5
2018 Porsche GT3
      02-10-2021, 12:03 PM   #10
limeypride
limeypride's Avatar
Who said TCU tunes don't fix it?
      02-10-2021, 12:05 PM   #11
gpdriver17
294
Drives: F90 M5
FSociety
2018 BMW M5
2018 Porsche GT3
      02-10-2021, 12:08 PM   #12
limeypride
limeypride's Avatar
FSociety
But how does he know when there are no TCU tunes for an M8 yet? The implication is that there is now one available—is this from an ongoing thread?
      02-10-2021, 12:11 PM   #13
AHall
982
100 for the life of the car?? This should be documented somewhere.
      02-10-2021, 12:12 PM   #14
gpdriver17
294
Drives: F90 M5
I'm not sure. He mentioned it in the M5 whatsapp group chat.
2018 BMW M5
2018 Porsche GT3
      02-10-2021, 02:15 PM   #15
limeypride
limeypride's Avatar
If you don't mind, could you ask? I'm not a WhatsApp user/fan. :
      02-10-2021, 03:52 PM   #16
gpdriver17
294
Drives: F90 M5
He was speaking about the older M5's < 2020 MY.
2018 BMW M5
2018 Porsche GT3
      02-10-2021, 04:16 PM   #17
pcai
pcai's Avatar
377
Drives: F90 M5
F90 M5  [0.00]
Well, better start rationing launch controls .
Appreciate 2
      02-10-2021, 04:36 PM   #18
KoenG
Belgium
1429
Drives: i4 eDrive40 & Cupra Leon 300
Like already discussed a few times before, as from 09/19 the ZF8HP75 was replaced by the ZF8HP76 which eliminated launch control issues. The M8 got the 76 trans from the commercial launch.
https://www.youtube.com/watch?v=RpGLqvgwtFM
      02-10-2021, 04:38 PM   #19
Trilogy_M
Drives: 2020 BMW M340i
I have a 21 M5C arriving in about a month. Will my LC be limited to 100 too?
      02-10-2021, 04:48 PM   #20
limeypride
limeypride's Avatar
It still has the LC count limiter. I'm not sure of the relevance of your post. :
      02-10-2021, 04:49 PM   #21
limeypride
limeypride's Avatar
Yes, almost certainly... but what we already know today is based on community knowledge—no formal OEM acknowledgement of the restriction exists. So if they have removed the count limiter, they probably wouldn't say so.
      02-10-2021, 05:27 PM   #22
KoenG
Belgium
1429
OP has an M5 with the HP75. They replaced it with the 76 which has stronger solenoids to assure trouble free 1st to 2nd shifts under full load. The 75 is not able to cope with the S63 launches.
