BMW M5 F90 (2018+) General Forums F90 M5 General Forum    Track day advice?
      09-04-2019, 05:25 PM   #23
isanube
isanube's Avatar
25
Drives: 2016 F80 ZCP, 1992 R32 GTR
2016 BMW X5M  [0.00]
Originally Posted by norbtx View Post
My track day advice? Take your sports car to the track.
My GTR is still getting engine assembled so next year
Give me a follow on IG @rcs.tyson
      09-04-2019, 07:00 PM   #24
limeypride
limeypride's Avatar
Drives: 2022 M8 Competition GC
Whoa, thanks. I can't imagine what we might have done without that gem of wisdom. :
      09-05-2019, 07:45 AM   #25
gtenedio
Drives: '%E2%80%9909 e92 m3, '19 X3, %
Originally Posted by Archimedes65 View Post
Very curious why you guys are running steering in comfort mode. I've only had my M5 for about 500 miles, but my initial impressions are that the comfort mode steering setting is fairly light and not very linear.
its added weight to the steering wheel for no reason
if you've ever tracked a car hard, you'll understand that 10 minutes into a session, your hands/arms will get very tired.
      09-05-2019, 10:50 AM   #26
Next Phase
Next Phase's Avatar
41
Drives: 2019 M5
Anyone have any input regarding the stock brake pads on the base M5?
I am an addicted track rat with dedicated sports / track cars, but I do plan to take the M5 out to VIR once it gets here to hopefully embarrass some cars. Are the stock pads adequate?
      09-05-2019, 11:47 AM   #27
limeypride
limeypride's Avatar
I only tracked her twice but the pads have held up just fine. No discernable fade either.
      09-05-2019, 04:15 PM   #28
Archimedes65
Archimedes65's Avatar
Drives: BMW M5
Got it. So far, I'm finding that, on the street at least, the lightness of the wheel in comfort makes it more difficult to be smooth in hard cornerning, as the wheel wants to turn too easily and I'm constantly making small corrections. In his review, Clarkson alluded to the new M5 having some weird steering traits due to BMW trying to remove understeer from the car. I do agree that driving in Sport is a bit more tiring, even on the road.
      09-05-2019, 09:26 PM   #29
RPI-M5
RPI-M5's Avatar
Drives: 2019 M5 Competition Frozen Bla
The steering on the M5 is definitely its achilles heel. In any sort of spirited driving the lack of feedback and twitchiness of the steering in Comfort is unusable in my mind. I only use comfort on residential type roads under 40 mph. On highway at 70+ I'm always in S+ steering. On the track I'd go to sport, especially if there are long straights and/or long sweeping turns.
Current: 2019 M5 Competition | Frozen Black | Black Extended Leather | Executive Package | 706M 20" (winter) | ANRKY AN14 21" (summer) | Remus Exhaust | High Flow Air Filters | XPEL Stealth
      09-06-2019, 09:34 AM   #30
adeuel
317
Drives: 2021 Oxford Green M5C
My '18 with steel OE brakes had 14.5 hours of on track time at WGI, and almost a year of street driving before I had to replace.
They worked fantastically on the track.
Rears will burn out first with heavy track time if you leave the DSC on. They are constantly pinching back and forth under heavy load to keep the rear end straight.
      09-06-2019, 07:57 PM   #31
isanube
isanube's Avatar
25
2016 BMW X5M  [0.00]
So update, it is supposedly going to rain pretty heavily the day I track the car, I checked the roster list and I think I'm the only person with a awd/4wd vehicle lol
      09-06-2019, 09:45 PM   #32
MysticBlue
369
Drives: '20 M5C, '09 M3 DCT Coupe
Rainy track days are the best. I've learned the most and had the most fun on wet tracks.
M5C 20% tint, Xpel full front, partial sides and rear. Spacers, 15mm front, 12mm rear. Turner Motorsport Oil Cooler Guard.
M3: Active Autowerke filter, Dinan underdrive pulley, Dinan full exhaust and software, 3.45 Differential, Springs, Brakes, Dinan/HRE wheels, 275/30-19 w/10mm spacer, 295/30-19 w/3mm spacer, painted front reflectors, 30% tint, Escort 8500i & Lidar Jammer, LUX H8 V5 halos, Euro rear foglights, 3M ClearBra.
      09-06-2019, 11:23 PM   #33
stealth70mde
stealth70mde's Avatar
376
Drives: 2019 M5C
The OEM pads are made by Pagid and they are quite good on the track.
I just got my new rear set today because it is true that they wear much faster than the front ones and I still have one more track day this season on Monday.
2019 - M5 Competition
      09-07-2019, 08:33 AM   #34
av.7447
180
Drives: E39, E60 M5, F06 M6, F15, F90
The F90 M5 is a pretty insane tool on the track and will give a hard time to Porsche GT3 RS guys if you know what you are doing. The standard oem brakes are great and have very little fade after laps of annihilating the brake pedal. Keep everything in sport plus including the steering... the steering sport plus setting is there for a good reason and you will find the car is easier to control during violent cornering. The suspension can be set to sport or sport plus depending on how good the track surface is.. the traction control needs to be fully off in 4wd mode unless you want to goof around, then you can leave it in 4wd sport. Make sure to have plenty of warm up and cool down laps as things will start getting very hot... starting cold tire pressure for perelis is good around 32psi... keep monitoring the left front tire as it gets much hotter than others on most tracks, start the cool down once you hit around 95 degrees C. Also note that there is a delay between what the idrive shows you and the actual tire temperature! Have a blast and most importantly show the lighter more nimble cars who is the 2 ton boss on the track!
Appreciate 2
      09-07-2019, 09:49 AM   #35
stealth70mde
376
Drives: 2019 M5C
^^ Absolutely this !
