BMW M5 F90 (2018+) General Forums F90 M5 General Forum    F90 M5 prototype spied entering U.S. at LAX
      07-08-2016, 04:28 PM   #67
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
Originally Posted by brad850csi
Originally Posted by miamiten View Post
One mule was running 275/40-20F and 305/35-20R but that could have been to simulate snow chains fitted for clearance check as I'm confident the F90 will have active kinematics (roll stabilization and rear axle steering) in some form. I found a pre production CAFD file in a recent psdzdata update that has parameters for Bosch ESC 10+ for "M GmbH Prototypen". Some very interesting info in there.
For your project I think we've found an ideal combination. This M6GC is the demo for one of our M6 GT3/GTLM drivers and he's very pleased with the changes and specs. 20" 1p with the same front width/offset and a 1/2" narrower rear are going on. He'll ring it out and make any necessary suspension adjustments. Give the butt some more grip without making it unpredictable and balancing out the front without ruining the steering.
Those are quite tall tyres, roughly in the same region as the G11, interesting. That would allow for the Ferrari 315/35/20 tyres to be fitted easily though.
G11/12 actually has small tires for some reason.
Have all the tires I mentioned in house plus and more incl some prototypes.
Also just did a secret project for Audi that was revealed yesterday. Built a real version of the CGI R8 from the new Final Fantasy movie. They're quite, ummm, interesting in design...bit over the top and phallic but it's a huge step in future construction and materials. It's this method I really want to see released to market.
      07-08-2016, 04:34 PM   #68
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
Originally Posted by Mo@BMWofFairfax
I see a LSD. No xDrive on this one?
xDrive is likely to be offered the next gen or LCI. Not for this version.
If this car is 300lbs lighter and doesn't burn "motor" oil, I'll buy an M5 again.
Well someone flung out a figure of 180kg (396lb) weight loss which I highly doubt even for a RWD version and impossible if there is any front axle drive assembly. The F10 really isn't THAT heavy. The E60 had a totally unique chassis that was all aluminium from the firewall forward and it was less than 150lbs lighter and had a horrible power band for a daily driver.
As for the F90 powerplant, and I want to make clear this is solely a guess on my part and not a leak, but I would be inclined to think the engine designation won't be S63. It's already on its 3rd update (S63O0, S63T0, S63T2) and that seems to be BMW's limit these days. The improvements that came from the S63TU benefited the N63 so perhaps the M version may appear slightly before the standard version. The collaboration with Toyota might actually be just what BMW needed. They've actually done a pretty good job incorporating Turbocharging, Toyota is great at building bulletproof I6, V8, V10, and V12 motors, so a combination is almost perfect.
4,450lb isn't heavy? That's 7 series weight, actually the new 7 might be lighter. I'm betting the new M5 will lose about 150-200lbs as the 7 series did.
For the M5 to be considered "fun" to drive, it needs to get closer to the E60 weight. BMW was able to shed weight on the F80 M3, lighter compared to the E90.
By the way, it's already confirmed that there won't be an xDrive version yet. Unless it's just competitive distraction technique.
Which sources are you using for weight figures?
      07-09-2016, 12:02 AM   #69
brad850csi
1316
Drives: 16 F13 M6 Comp
I wish there was a single way to measure cars! I often use goo-net to check out car weights, mainly as it is an easy place to find all of the weights. They list the weights as below on various cars
E34 M5 1680 - 1710kg
E39 M5 1780 - 1790kg
E60 M5 1830 - 1880kg
F10 M5 1945 - 1980kg
E63 M6 1820kg
F13 M6 1910kg
E65 750i 2040kg
F01 750i 2060kg
G11 750i 1940kg
E36 M3 1470kg
E46 M3 1560kg
E92 M3 1650kg
F82 M4 1640kg
So the F90 might end up being around the 1860 to 1900kg mark I think, with the new M6 (assuming slightly smaller but still 8 cylinder) could be around 1800kg or even a bit lower.
      07-16-2016, 04:02 PM   #70
Lual
16
Drives: M5 2014 CP / X5 G05 ‘21
I really hope they add in the new model some agresiveness.
I like my F10, but somehow I dislake it looks pretty much like a 520 Diesel.
Dear BMW designers, please make a 600hp car look more like a 600hp and not like a Diesel. I hope you incorporate some of the M4 design stuff!
      07-16-2016, 04:53 PM   #71
Vitacura
Ich Liebe mein BMW
Vitacura's Avatar
Drives: 21 M240i CV, 23 X1
That's an interesting viewpoint. I liked the early models of the M5 up to the E39 due to the similarities and subtle changes to the regular 5 series. The E60 really started with aggressive and shouty lines making the car stand out. I always thought of the M5 as a stealthy monster.
      07-30-2016, 12:56 PM   #72
RaTeD ///M
32
Drives: 2K13 M5
I agree the E60 M5 was aggressive looking and u knew it was an M5 from a far. Totally stood out as for the F10 not so much. Most ppl see it as regular 5 series. I miss my e60 it just "popped".
22 BMW M5 CS on order for August Production
20 BMW M5 Competition stage 1.5....
09 Zenith R GTR CP 4.4 Stroked CP tuned.....
      08-10-2016, 07:42 AM   #73
Laki021
Laki021's Avatar
Switzerland
367
Drives: BMW 540i xDrive
I just checked, F10 M5 was presented in September 2011 (~2 years after the F10).
Following the 7 year life cycle logic, we will not see new M5 for another 2 years
On the other hand, they are testing it already for months, so hopefully this time M5 is coming much sooner.
      08-10-2016, 08:23 AM   #74
SlammedR8
SlammedR8's Avatar
521
Drives: 2019 X5 40i/2020 R8 V10 Spyder
I agree with this timeline in the past but I think M cars are coming sooner now then they used to. Not sure the exact timing, but I believe the F8x M3/4 came sooner than 2 years.
Current:
2019 BMW X5 40i - Carbon Black/Tartufo Individual Leather
2020 Range Rover HSE - Black/Black
2020 Audi R8 V10 Performance Spyder 6MT - Ascari Blue/Black
      08-12-2016, 12:49 AM   #75
BaDZeR
Qatar
Drives: BMW M5 F10 2016
Excited for the new M5
I think the new long wheelbase would add positively to the handling and the inner space for the kids when you go out on trips on weekends. But I am sad to hear that they have kept the same engine. Don't get me wrong, the current engine is an amazing one and I have no major complaints about it, but I would have just wished for a newer engine that would have a better exhaust note than the current F10
      08-12-2016, 11:14 AM   #76
Wills2
Barge driver
Wills2's Avatar
Ukraine
8656
Drives: 730d
E63 M6 1820kg
F13 M6 1910kg
E65 750i 2040kg
F01 750i 2060kg
G11 750i 1940kg
E36 M3 1470kg
E46 M3 1560kg
E92 M3 1650kg
F82 M4 1640kg
F82 M4 is quoted at 1590kg (manual) EU (inc 75kg for driver/luggage) by BMW
730d/Z4C
