08-14-2020, 08:24 PM | #24 |
4146
Rep 7,164
Drives: F90 M5 / F15 50i
'07 Yamaha R1 (sold)
'06 C55 AMG (sold) ?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe '14 X5 50i (wifes now) |
DocWeatherington2943.50 |
08-15-2020, 08:04 AM | #25 |
13046
Rep 18,751
FYI guys.
This is how the supplied rivet supposed to work. In order not to lose the push pin, during manufacturing process, the push pin is left attached to the rivet itself. So, prior to installation, you need to snap the pin off from the rivet. Once it is separated, you can push it in into the rivet and press in to secure it. It is a tight fit. But, I don't recommend to use acetone to wipe anything off your paint, lay things on top of your car, and use hammer to push a small plastic pin. I do use the handle of a screwdriver to push it in. Hope that help.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
08-15-2020, 09:40 AM | #26 | |
38
Rep 143
r33_RGSport13045.50 |
08-16-2020, 12:06 PM | #27 |
82
Rep 142
Didn’t know that. Just followed video and carefully hammered it in. Just when I hit the oem ones the rivet went inside the fender. I doubt it will be an audible rattle from there.
04-10-2021, 03:31 AM | #28 |
141
Rep 401
How are these holding up for those that have installed? Any other options out there right now as I cant seem to find anything other than PPF that look nice. I'm on the fence...…..Thanks
04-10-2021, 08:39 PM | #29 |
392
Rep 279
They're holding up well for me. Hardly any scratches either and still securely in place.
M5 F90 (2018)141.00 |
04-13-2021, 11:32 AM | #30 |
876
Rep 1,319
I actually made my own, for my first Competition in 2019. On these photos, they look like they stick out quite a way, but i made them wide enough, to cover the outer edge of the tyre tread, at the bottom of the front wings, where the wing recesses into the body. My new car has just landed, and i will be making some more. I noticed, cars that come with Pirellis, seem to have more rash, than Michelin shod cars. Guess what my new car has come with, yes, Pirellis, so im dealing right now for Michelins from the off. To add, these flaps are very discreet. |
JRod1980391.50 |
04-13-2021, 02:36 PM | #31 | |
141
Rep 401
04-13-2021, 09:53 PM | #32 |
4146
Rep 7,164
Doing good on my end. They clean up like new still. Only. Annoying but yet oddly satisfying is hearing all the rocks hit them when going through a parking lot
JRod1980391.50 M5 F90 (2018)141.00 |
09-24-2021, 06:39 PM | #34 | |
16
Rep 34
09-25-2021, 04:42 AM | #35 | |
876
Rep 1,319
On my current M5, ive used 3mm black flap material in the same shape. They really do work, and the sides of the car are 100% rash free. |
10-14-2021, 07:55 PM | #36 |
91
Rep 124
Just ordered these as well as well as some for the rears will post pics after the install.
21 F90 M5C Frozen Dark Grey/Tartufo (all options except NV) Prior: 19' F90 M5C DG/Aragon (all options except NV); 14 F1O M5 SG/SS; 11 E92 M3 SB/BL; 06 E60 M5 SS/BL; 00 E39 M5 CB/CAR; 95 E36 M3 AB/DG
10-25-2021, 05:08 AM | #37 |
29
Rep 302
I'm curious is this on a set up w spacers or stock that most are seeing issue? I'm new to platform and Haven't noticed any chips on stock set up w pirellis.
10-25-2021, 07:42 AM | #38 |
4146
Rep 7,164
Give it time. It will happen. Especially along lower rocker panel. The tires stick out quite a bit at the bottom regardless of spacer.
10-25-2021, 09:20 AM | #39 |
228
Rep 298
10-25-2021, 10:05 AM | #40 |
845
Rep 482
10-26-2021, 11:08 AM | #41 |
29
Rep 302
How far do these stick out anyone have a pic from a couple steps away
