BMW M5 F90 (2018+) General Forums F90 M5 General Forum    Anyone used this for Break Squeal?
      06-11-2020, 02:33 PM   #1
AllCarbonEverything
AllCarbonEverything's Avatar
31
Drives: 2023 Black Sapphire X6M
https://www.ate-info.de/en/details/p...astilube-75-ml
Looks like its made by an official BMW supplier. Its cheap and seems easy to apply. Anyone ever used it??? I wonder if its something you need to re-apply often or if you can just have it applied at each service and be good.
Any insight is appreciated!
      06-11-2020, 04:07 PM   #2
DannyA
United Kingdom
143
Drives: C8 RS6
That link didn't work for me - what was the name of it ?
      06-11-2020, 06:11 PM   #3
AllCarbonEverything
31
Link updated. My bad Gents.
      06-12-2020, 11:48 AM   #4
brownbear_M5
Drives: e39 M5
Amateur question here but is this something you can apply with the wheels on or do you need to take them off to apply this?
      06-12-2020, 03:50 PM   #5
AllCarbonEverything
31
Youd have to take off the wheels. As I understand it this is supposed to be applied to the back of the brake pad BACKING plate. It is not supposed to be used on the pad surface themselves.
      06-13-2020, 01:20 PM   #6
ResidualJinx
114
Drives: 2018 BMW M5
This is how I fixed it:
ACG Automotive Carbon Kevlar Pads Installed https://f90.bimmerpost.com/forums/sh....php?t=1593401
      06-13-2020, 07:14 PM   #7
gblansten
gblansten's Avatar
1977
Drives: 23 Tesla S Plaid
If you squeal when something breaks you can try Headspace. It’s an app on meditation. I just wanted to brake in hear and let that lose.
      06-13-2020, 10:22 PM   #8
ambletx
ambletx's Avatar
516
Drives: 2021 M5 Comp
Unfortunately this solution didn't work for me. The squealing came back after about 1000 miles, and so did the brake dust. (╯°□°)╯︵ ┻━┻
      06-14-2020, 05:41 AM   #9
ResidualJinx
114
Drives: 2018 BMW M5
Sorry to hear that, I wonder if that's the case for most. I've been deployed since the new pads were installed, I can't image the M5 has more than 250 miles since we put them on last Oct.
      06-14-2020, 01:17 PM   #10
Greer
Greer's Avatar
1893
Drives: 2022 M5 Competition
Did you bed the new brake pads after they were first installed?
2022 F90 M5 Competition & 2019 M2 Competition
2019 F90 M5 Competition
2017 F80 M3 Competition
2014 F10 M5 Competition
2003 E39 M5
      06-14-2020, 03:34 PM   #11
josec70
josec70's Avatar
Drives: 22' Individual Chalk M5C
I've had the ACG pads on for about 1 1/2 years iiirc and they have recently started to squeal intermittently.
It is always in city driving and cured with a hard stop.
Nowhere near as bad as the OEMs were and dust remains vastly improved vs OEM.
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
      06-14-2020, 06:10 PM   #12
ambletx
ambletx's Avatar
516
Yup. Eurocharged bedded them in when they installed them.
      06-15-2020, 12:20 PM   #13
Archimedes65
Archimedes65's Avatar
Drives: BMW M5
Doesn't matter if you bedded or not. If you drive around town braking slowly and easily you will start to get squeal. Just brake later and firmer a few times and it will go away. Make a habit of driving like that and you won't get squeal in the first place. It's not rocket science. High performance brakes will squeal if you are dragging them into stops all the time.
      06-15-2020, 03:56 PM   #14
GranitM5
GranitM5's Avatar
366
Drives: 2018 BMW M5
I took your advice on the hard braking. Definitely helped with the noise. Now just need to figure out what to do about the neck pain from my head jolting forward and the coffee stains on the charging station 🤔
Appreciate 2
      06-15-2020, 04:08 PM   #15
ambletx
ambletx's Avatar
516
Its been my experience that this works for about 100 miles and it comes back.
This seems to be the only way, at least for me, to keep them from sounding like a school bus when coming to a stop. However, the look on peoples faces in their rearview mirror when I come roaring up behind them is priceless.
      06-16-2020, 10:38 AM   #16
Archimedes65
Drives: BMW M5
It doesn't even take jamming on the brakes to avoid the squeal. Just a firm pedal versus the drag. What causes the squealing is the habit of stopping by gently dragging the brake pedal with light pressure and slowly adding pressure to the minimum point required to stop the car smoothly. That's how most people typically drive a car around town. But with high performance brakes, if you don't want the squeal, you simply have to wait longer and apply a firm pedal, going from zero brake pressure to the amount required to fully stop the car in a shorter time. It will take a few very firm 50-5mph braking cycles to get rid of the squeal if you have it, but only simple firm stops to keep it away.
      06-17-2020, 06:38 AM   #17
ResidualJinx
114
Drives: 2018 BMW M5
I guess my perspective is I bought an M5 because I wanted to eat my cake and have it too. I want both worlds the super sedan and the executive comfort... I understand science is what it is and there maybe no way around it but damn if I don't complain if my car sounds like a POS pinto when I'm driving my kids around their school drop off line
Tags
brakes, f90, lubricant
