Coby Wheel
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Starter help e90
      05-08-2024, 07:17 PM   #1
Dtheking87
Dtheking87's Avatar
9
Drives: BMW 328i xdrive
Starter help e90
Yo so I just had a question about my car. Car has good battery alternator is good fuses are good but no start no crank just a click. Was wondering if I should change ground strap first before diving into the starter 2010 328
      05-08-2024, 08:03 PM   #2
GoRomeo
GoRomeo's Avatar
Drives: 330i, 135i
2008 BMW 135i  [9.50]
2006 330i  [6.75]
Can you read codes? Have you ever replaced your starter? If not most likely you nee a new starter. I replaced mine on my 06 E90. Lasted about 10yrs.
      05-08-2024, 09:27 PM   #3
Dtheking87
Dtheking87's Avatar
9
Yea I just have a code for starter actuator. I read a lot that 99% of times nothing happens when your actual starter is bad and only the ground strap is bad when you get a click. But either way went and got a brand new starter just to be safe and some universal ground strap from my local parts city hopefully it works lol
      05-08-2024, 09:31 PM   #4
Dtheking87
Dtheking87's Avatar
9
And no I have never replaced started. I’ve only owned car for line 3 months and other then the existing problems I knew when I bought it this is the only new one.
      05-09-2024, 12:25 PM   #5
sabino56
80
Drives: 2006 E90 330i
Somebody posted that you can check whether ground strap is bad by using jumper cable from ground to engine, providing alternate path for ground. You might look into that first. Good luck
Appreciate 2
      05-09-2024, 02:15 PM   #6
lookalikehuuh
Drives: 2006 330i, 2007 335i
When a starter clicks it could be a few things.
1. Starter itself is engaging but just doesn't have the power to turn the engine.
2. Bad power/grounds
3. Engine is seized and starter will never be able to turn the engine.
Have you attempted to turn the crank by hand with a large breaker bar just to make sure the engine isn't locked up?
Mike K332.00
      05-09-2024, 03:44 PM   #7
Dtheking87
Dtheking87's Avatar
9
I really don’t think my engine seized. I don’t have any engine issues not even a CEL. And before it just stopped starting completely , it would take a couple button presses to get it to start and that was for 2-3 days before it completely stopped starting
      05-09-2024, 04:01 PM   #8
Dtheking87
Dtheking87's Avatar
9
Not having the power to crank is most likely a bad ground strap tho or something right ? Alts good battery’s good fuses are good and only code I get is a starter actuator code
      05-09-2024, 07:08 PM   #9
StradaRedlands
StradaRedlands's Avatar
Drives: 2006 BMW 330i MT
2006 BMW 330i  [8.25]
2009 BMW 328i Touri ...  [8.00]
2013 BMW X5 35i  [7.80]
2011 BMW 528i  [8.70]
2006 Mazda3  [5.50]
Yeah, connect engine to the frame with a jumper cable (just one color). Replicates the path of the ground strap. Grab one of the oil filter housing bolts, and connect over to the ground bar on the passenger side.
Mike K332.00
      05-09-2024, 08:05 PM   #10
Dtheking87
Dtheking87's Avatar
9
It was starter. Changed it out fired right up. To my surprise too cause when I was down there I found a massive ground strap that was corroded right in the middle so bad that it broke. But I had absolutely no way to get to parts city to buy a replacement but definitely will be getting it replaced tomorrow!
Appreciate 5
GoRomeo1028.00
Cal122206.50
      05-14-2024, 05:32 PM   #11
Daaaaaaaan
93
Drives: 08 323i
A bad ground strap could have caused premature starter death. More resistance = lower voltage = more current = more heat (and longer start time). It's also why high current devices (like an air compressor) will tell you NOT to use them with an extension cord.
Rust belt life. Check your ground straps fellow rust belt dwellers!
Appreciate 3
      05-16-2024, 09:04 AM   #12
Dtheking87
Dtheking87's Avatar
9
Not sure how to reply to your comment but you could be right about the ground strap. I’m gunna grab one tomorrow I’m pretty sure it’s the engine to body ground
