02-10-2023, 04:12 PM | #1 |
130
Rep 214
M550i Springs Finally Installed
I had my lowering springs installed today[ATTACH][/ATTACH]
Before: After: |
02-10-2023, 04:18 PM | #2 |
4092
Rep 3,672
Drives: 2022 M5C
Stance looks fantastic!
Not a BMW guy...but certainly an M5 guy.
02-10-2023, 04:18 PM | #3 |
130
Rep 214
It turns out my 2018 had the factory blocks in the front springs. It just goes to show you taking car to dealership for oil changes etc they never noticed.
Car absorbs bumps better than factory base springs. I haven’t fully tested in the corners but also looking for improvement. Last edited by M5KEITH; 02-10-2023 at 07:29 PM.. |
02-10-2023, 04:53 PM | #4 | |
4092
Rep 3,672
Drives: 2022 M5C
imperfectluck426.50 PDOT130.00 |
02-10-2023, 05:16 PM | #5 |
4074
Rep 5,233
Car looks great!
02-11-2023, 10:32 AM | #9 |
50
Rep 72
Maverik2594140.00 |
02-11-2023, 01:06 PM | #11 |
4092
Rep 3,672
Drives: 2022 M5C
02-19-2023, 10:04 PM | #12 |
130
Rep 214
After lowering car I noticed that my headlights were not projecting as far on the road at night even though they move with steering wheel. I noticed I had to utilize my high beams but never did before.
There is an adjust under hood behind headlights for allen wrench to adjust and they are visible. I adjusted height foe better visibility post lowering springs. It literally took me 30 seconds to do both. Problem corrected with headlights and thought I would share. |
V series6.00 |
08-21-2023, 09:43 AM | #13 |
681
Rep 527
I am contemplating switching he the H&R 550i springs. Currently on the Eibach Pro Kit for M5. I am on 20" wheens, Titan7 specs for size and offset. Will I see any rubbing by moving to the 550i springs? I do not want any rubbing while driving or full lock turning. Thanks!
08-21-2023, 09:50 AM | #14 | |
838
Rep 478
dcohen13681.00 |
08-22-2023, 08:15 PM | #15 |
4074
Rep 5,233
Confirmed .. you should have no rubbing.
12-30-2023, 11:40 PM | #16 |
Rep 22
Did these springs and some spacers on my f90 about a year ago, I love the stance but the Southern California roads don’t make for a fun ride. I’m having the stock springs reinstalled very soon. Looks amazing but the the ride quality does suffer a bit.
01-03-2024, 06:34 PM | #17 |
IG: @M5RCY_
365
Rep 317
I am in California and no complaints here. Are you on 21s or 20s?
Autotecknic.com - code: M5RCY for 12% off
Project Gamma - code: M5RCY for 5% off Dura-Coating - code: M5RCY for 20% off |
01-11-2024, 09:57 PM | #19 |
130
Rep 214
M550 HR springs is a softer ride than my stock pre LCI.
If I could do it over again I would have went with M5 H&R lowering springs for stiffer ride and better handling when pushing car hard in the corners. My car above also settled 1/4” lower after a week or so. |
01-12-2024, 07:27 AM | #20 |
5234
Rep 10,616
The H&R M550xi springs are more the cosmetic option for less wheel to fender gap than the performance option for better handling, and cosmetics seems to be the primary interest of members here. Still, maybe the lower center of gravity offsets the softer spring enough to provide some overall handling improvement.
I used the springs H&R developed for the M5 — made sense to me, but the ride is stiffer than stock on my 2018 M5. I am not sure how it would compare to a 2019 Comp. I will probably buy a used set of the late Comp struts at some point for the improved valving. Probably won’t go to coilovers like KV4 because I like the adjustable suspension settings — in my daily driving on the roads in my area, I do not need or want stiff all the time. |
02-14-2024, 04:28 AM | #22 |
4074
Rep 5,233
