02-28-2019, 03:23 PM | #133 |
9159
Rep 14,522
Interesting conversation I had with a power lifter. we were talking about leg workouts and one thing negative about having huge legs or even having more than a somewhat built legs is how PITA it is for shopping for jeans. not only that he complains about how he gets some pretty bad rashes on his inner thighs from every day walking. he said that most of his pants are really jumpers or anything that doesn't cause resistance when they rub when he's walking
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg |
NickyC17484.50 |
02-28-2019, 03:24 PM | #134 |
9159
Rep 14,522
t-bar rows like mentioned are awesome! you could also do wide grip pull ups and close grip pull ups until exhaustion. stiff arm i'm assuming when you use a rope or short bar on a cable machine and you lean forward a bit and pull it with a slight bend in your elbows and you bring it to your thighs? I forgot what that's exactly called but I do that almost as a finisher for my back work out
02-28-2019, 04:07 PM | #135 | |
17485
Rep 10,663
Drives: M4 CS. Former G82, x2 F82, F80
This was a major part of my dropping from 275 when I was in my early 30s, to 245 where I've been for around 9-10 years now. I'm certainly overdeveloped top compared to bottom now, but I ain't going for any trophies so who cares. |
lsturbointeg9158.50 |
02-28-2019, 04:19 PM | #136 | |
9159
Rep 14,522
NickyC17484.50 |
02-28-2019, 04:24 PM | #138 | |
8211
Rep 2,250
But my legs happened to be my best body part, so I was bottom heavy forever before my upper body caught up. Now I have to only hit them hard about every 8-10 days as if I train them more frequently, they start over shadowing my upper body. Any other leg training I do through the week is flexibility work and just moving some blood around. I still have issues with pants that fit. Waist is about 30"....but I have to wear a 34-36" waist in a relaxed style jean to fit my legs comfortably and have good mobility. |
NickyC17484.50 |
02-28-2019, 05:56 PM | #139 | |
9159
Rep 14,522
02-28-2019, 10:31 PM | #140 |
750
Rep 1,149
1MM, have you ever done a push/pull workout? I do one every few weeks. Very effective and mixes things up. It’s exactly like it sounds. Pushing movements combined with pulling movements. Example....Bench press/pull ups, DLs/sled push. Just a few there’s tons of combos.
02-28-2019, 10:52 PM | #141 |
11817
Rep 23,187
I have different split than most I think, dont do chest and tri, back and bi routine. Back own day. Chest own day and bi and tri together. Legs own day and work in traps, calves, forearms and abs whenever
02-28-2019, 11:28 PM | #142 | |
9159
Rep 14,522
Exactly my workout
03-01-2019, 05:33 AM | #143 | |
8211
Rep 2,250
Usually in a de-load session. Bench with Bent Rows, OHP with Pull-ups, etc. The pump is unreal because of the amount of blood in the area. I used to exclusively do a push/pull type of workout...but it would be push one day, and pull the next. Push, Pull, Legs...rinse, repeat. Made some really good gains.
Everybody has a gameplan....until they get punched in the mouth.
03-01-2019, 05:40 AM | #144 | |
8211
Rep 2,250
We have one guy in our gym who has huge adducters (Inside thigh), and he has this issue. I told him to drop those exercises and focus more on the abductor muscle group, but he keeps doing the same routine. I guess he will figure it out at some point, or deal with it as is! Problem is that one of these areas will always be more dominant than the other, and while foot placement during leg exercises can help to some extent, any stimulation of the leg muscles is going to accentuate the strongest part of that muscle group.
03-01-2019, 09:17 AM | #145 |
18027
Rep 9,378
I'm looking for a 4th in a cycle with the overhead bar. I do back/bi, so generally a cycle (either of 1 or four if I can) back, then bi, then come back to back. I do adjust the plane between cycles, just as I move around the grip within each cycle.
I'm looking for that fourth with the overhead cable, so I don't have to move around and/or wait for someone else. I don't even consider myself very large in the legs, and I still have issues with pants that might fit my waist, but then I can't even get the pants to my waist. I think it's a plot to make us all wear skinny jeans |
03-01-2019, 10:10 AM | #146 | |
8211
Rep 2,250
Didn't you mention you do straight arm pull-downs? Here's a variation that you could add in. Do the same exercise, but facing the pulley system backwards. Position your body like you are "draped" over a barrel slightly....kind of in a convex position, and then do the pull-downs from behind your head. This simulates a pull-over movement whether it be a dumbbell pull-over...or something like a machine pull-over. Plus on the back side, you can get a very extreme stretch in your intercostals and serattus muscles.
UncleWede18026.50 |
03-01-2019, 02:49 PM | #147 | |
750
Rep 1,149
03-04-2019, 06:42 PM | #148 |
9159
Rep 14,522
Monday Chest Day!
King Rudi13154.00 |
03-04-2019, 11:53 PM | #150 |
9159
Rep 14,522
That's what I'll do Tuesday. Can't wait!
03-05-2019, 06:00 AM | #151 |
8211
Rep 2,250
This morning was my off day....tomorrow is back for me focusing on thickness work. Deads, Bent Rows, trap work, etc.
Next back workout is more width focused with weighted pull-ups, Lat pull-downs, etc. My gym got one of those new "Mag" bars and it is awesome for pull-down work!
03-05-2019, 07:59 AM | #153 |
2465
Rep 1,144
This schedule would be impossible at my gym. Everyone and their mother is in there doing chest on Monday and when Tuesday rolls around, you guessed it everyone is doing back. Even if my chest day falls on a Monday I switch to something else to avoid the bullshit lol.
03-05-2019, 08:01 AM | #154 |
13154
Rep 1,965
Same.....chest and triceps. I'm still relatively new at all this and slowly becoming more acclimated with the equipment at the gym. Last night I made "friends" with the smith machine for the first time......ironically last night was also the first time I experienced complete muscle failure on some heavy (to me) weight. Feeling it today for sure! Not so much sore but the skin on my chest feels like I'm wearing a t-shirt that is too tight.
Tonight is legs. |
