12-09-2017, 05:12 AM | #89 |
I can haz cheezburger?
6807
Rep 3,677
Drives: 14 Sahara/08 335xi/22 Maverick
Please BMW, can we have an engine that doesn’t have crank hub issues, rod bearing issues, Nikasil blocks, etc..?
Thanks! |
Brake_Late1937.50 CLEANM416.00 |
12-09-2017, 06:38 AM | #90 |
371
Rep 615
Drives: E92 M3 6MT Space/Black
Wow, these production runs are getting much shorter...the E9X M3 was produced 2007-2013! The F8X, 2015-2018 ?
GM |
12-09-2017, 07:03 AM | #91 | |
Moderator
7517
Rep 19,368
E90 M3: 2008 - 2011 (MY2008 - MY2011) E92/3 M3: 2008 - 2013 (MY2008 - MY2013) F80 M3: 2014 - 2018 (MY2015 - MY2018) F82/3 M4: 2014 - 2020 (MY2015 - MY2020) So, the reality is the F8x M3/M4 will actually be in production roughly a year longer than their E9x M3 counterparts. FAQ: Q: Why do the two-door M models go longer? A: Because the Series two-door models they are based on go later. Q: Ok, but why do the Series two-door models go later? A: Because they debut later. Q: Alright, but why do they debut later? A: Because auto manufacturers stagger product releases to minimize risk and spread costs. Q: Fine. But then why doesn't the M3 sedan start commensurately sooner? A: Because of the familial shared parts that are plucked from the late-arriving Series two-door. Q: Wow, that’s a bummer for sedan buyers. Will they ever rectify this? A: Only if M3 revenue were to become large enough to warrant separation from the M4. |
7
12-09-2017, 08:02 AM | #93 | |
277
Rep 419
Very interesting I knew this was the way it went, had never heard the actual explanation...points to you!
12-09-2017, 08:23 AM | #94 |
1938
Rep 3,297
XDrive w manual please
Eendraght Maeckt Macht
FOF82,3pedals,MPE,CCBs,Multicams, CarbonStrucktureAnthracite, CF_Everything BMWPhotoVin, 01of01, GTS DCT, EPS, MDM, CS EDC,Analog Dip ,GTS parts. Euro Vin e30 M3, FIA cage / 14.7 p / w ratio. Euro E30 touring G30 MSport i3s LBB X5M 3.2carrera https://www.youtube.com/channel/UClRTsfNzuz_EjUBu59UCykA |
12-09-2017, 08:53 AM | #95 |
133
Rep 169
12-09-2017, 09:15 AM | #96 |
589
Rep 585
The advantages of platform/drivetrain sharing come from economies for scale. Some obvious pros are:
Keeps the cost down for both the manufacturer and the end user. R&D learned from higher end models trickle down faster You essentially get more bang for the buck in lower priced models. For example, I believe same DCT and rear diff is used in both M5 and M3, so when you buy an M3, at least in paper, you are getting over engineered components. Better parts availability when it is time for service Engine/gearbox tuning and upgrade costs will be lower etc. Some cons of sharing: Defects will have a ripple effect Smaller cars that share the same platform might end up becoming heavier than competition Your car may not feel "special" or whatever that means Anyway, no matter what, new M3 going to be better in every measurable way. Heck, I don't mind if they simply just drop in the new M5's AWD V8 drivetrain and just call it a day. But it looks like it'll share the engine with the X3M so most likely it will have an option for AWD. If 911 can have AWD, M3 should have an optional AWD too, even if it rustles the jimmies of so called purists.
_______________________________________________
My Euro Trip Special Report, 3900 kms, 18 days, Lots of Videos +Pix! My PCD and journey back to MD My Youtube Channel |
12-09-2017, 09:19 AM | #97 | |
1613
Rep 1,608
"Beware of false knowledge; it is more dangerous than ignorance."
12-09-2017, 09:26 AM | #98 |
589
Rep 585
If 911 can have an optional AWD then I think M3 should have one too.
JustChris17527.50 Who's on first2464.00 |
12-09-2017, 09:29 AM | #99 |
Bimmer Fanatic
368
Rep 1,660
AWD that can be switched off, 6MT, 500 hp. Sounds like a winning mix to me, I haven't tested an F80 ZCP but my base F80 had a tough time putting down that power, I'm all for awd with high HP high torque cars.
12-09-2017, 09:49 AM | #100 |
185
Rep 477
Only time I will consider the AWD as being acceptable for the M3/M4 platform is when you can do RWD mode in MDM and not completely turn off traction. No one wants to drive an m5 with 600hp without traction control in order to get the feeling of driving rwd, so that feature is rarely ever going to get used.
Current Car List
2020 F87 M2 CS - Hockenheim Silver 2020 F97 X3M- Phytonic Blue |
12-09-2017, 09:59 AM | #101 | |
335
Rep 4,633
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
12-09-2017, 10:35 AM | #102 | ||
4972
Rep 10,200
Drives: 2024 Golf R / 2022 718 Spyder
But I don't have much hope for that - given the shift we are seeing, in terms of the "sharing" between standard cars and M cars, I wouldn't be surprised at all if the M3/4 follow the M5's script. I mean, BMW has already developed the requisite software and whatnot. If they can't even be bothered to have a new, exciting engine for the M3/4 or M5, why they hell would they bother with a different AWD --> RWD setup? Just my $.02...
Past rides: 2016 981 BGTS, 2020 MINI JCW, 2017 F80, 2015 981 CS, 2014 F22 235, 2011 E82 135, 2008 E82 135, 2007 E92 328, 2007 E92 328 (My lady drives an OG M2. So does my dad)
12-09-2017, 11:03 AM | #103 | ||
5259
Rep 5,874
12-09-2017, 11:07 AM | #104 |
315
Rep 462
I love M but I don't think this new generation will be for me. It's going in a direction that just isnt pleasing to me. I will keep my e46 till the wheels fall off. Enjoyed my F80 but sold it after a year of ownership.
Looking to get into a Porsche next, even though some of the "lower" models are a bit stale as well. |
12-09-2017, 11:13 AM | #105 |
2936
Rep 3,286
Drives: 2002 M5;2007 M Coupe;2020 M2C
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel 2007 E86 Z4M Coupe Silver Gray/Black 2021 Kia Telluride (hauler) |
12-09-2017, 11:22 AM | #106 |
831
Rep 2,352
Drives: 16' BMW i8
Garage List 2001 BMW M3 E46 CON ... [9.50]
2016 BMW i8 [10.00] 2003 JEEP GRAND CHE ... [0.00] 2000 540i SPORT E39 [10.00] 2007 TOYOTA TACOMA ... [0.00] |
My list of wants/needs:
1.) 500 HP / 450 TQ (Give or Take) 2.) Weigh less than 3,500 LBS 3.) 6MT Option 4.) AWD option 5.) Finally a brutish exhaust |
12-09-2017, 11:30 AM | #107 |
335
Rep 4,633
I like being able to cheat MDM and RWD with alot of power.. I want to be as lazy as i want, irresponsible with the throttle and not get in trouble
12-09-2017, 11:36 AM | #108 |
335
Rep 4,633
If they do use a Modified B58 version to power the next M3, S58, i wonder if it will have any new tech that we can actually use and feel as a driver.
The S55 already has the B58's closed deck, mechanical pump with map thermostat, multiple electric coolant pumps, indirect charge air cooling, arc sprayed cylinder liners and etc. There has been changes to vanos location to the rear but same principle operation, and there also has been changes in the B58 to a valvetronic4 but again, about the same operating principle with nothing ground breaking there. The S55 is based off the N55, but also took alot of the B58's tech prior to its release.. My guess is there is gonna be a even smaller change from the B58 to the S58, compared to the N55 to S55 changes.
12-09-2017, 12:03 PM | #110 | |
2759
Rep 6,760
I loved the E90 for 6 amazing years, and I’m enjoying the F80 equally (actually enjoy it more on track). And I think you are mistaken about what the M3 owners want in their cars - it’s not exclusivity (go buy a Porsche or McLaren). It’s simply having a car that can go to Home Depot one day, take the kids to school the next and go romping around a track on the weekend. It’s a feeling of being able to shake the commmuting blues at a moment’s notice, and transform into a taut, fast, responsive car that can fill you with adrenaline whenever you want. There is no exclusivity at all when you drive something based on a $30,000 sedan. None whatsoever.
2018 F80 Santorini 2019 Z4 3.0i 2022 X2 M35i |
8
Dinh335713.00 ron_jeremy513.00 Who's on first2464.00 XsltAnalyst588.50 Horley9008.50 KevinM2935.50 CLEANM416.00 GGG333603.50 |
