01-13-2022, 11:30 AM | #1 |
137
Rep 59
Drives: BMW M5 CS
M5 CS radiator potential debris damage ?
Curious with their location if radiators susceptible to damage from road debris like small stones. Would some sort of protective screen be worth doing? Haven't seen a car in person just wondering.
01-13-2022, 11:35 AM | #2 |
1540
Rep 2,009
Damage? Yes, screen? No. You're just going to restrict air flow and anything that's going to hit the radiator hard enough to bend fins is going to rip right through that screen anyway. Realistically it's not going to be that bad unless you regularly travel to Mexico and ride people's asses. And even then at worst you'll have a slight decrease in cooling performance over the next few years. Just straighten the fins back up and repeat when needed.
01-13-2022, 12:14 PM | #3 |
254
Rep 2,091
Same bumper and radiator as the normal LCI M5. If you are that concerned, then go check out a 2021 M5 with as many miles as possible local to you, whether it be a car meet or dealer, and see what the radiators look like. I think it is of no concern personally.
2012 Audi R8 V10TT| 6MT| Suzuka Grey
2015 Ferrari 458 Speciale| Rosso Scuderia 2020 BMW X7| Mineral White 2024 718 GT4 RS | Arctic Grey |
Ominous136.50 |
01-13-2022, 01:08 PM | #4 |
749
Rep 288
I actually did have an issue with the auxiliary radiator getting damaged. It was when I had an m550 (which has a plastic honey comb grill whereas the f90 is pretty much exposed).
In my case a pebble or something hit the vertical cooling tubes and resulted in a messy coolant leak. Had to get the aux radiator replaced. Even with that experience I'm not worried about the same thing happening on my m5… chalked it up to random bad luck. Could it happen- obviously yes… my guess is that the odds are slim, though. |
Ominous136.50 |
01-13-2022, 01:16 PM | #5 |
137
Rep 59
Drives: BMW M5 CS
Thanks for sharing your experience. Glad to know it is not an issue.
01-13-2022, 03:18 PM | #6 | |
294
Rep 195
The auxiliary radiators are relatively inexpensive and easy to replace. |
Ominous136.50 shawnhayes1837.00 |
01-26-2022, 05:28 AM | #7 |
158
Rep 308
I have protective grilles fitted to my 2019 M5 Comp lower rads and underneath tranny cooler.
I live in UK so any restriction to air flow is not a concern. Zunsport.com |
