04-27-2020, 05:31 PM | #309 |
3588
Rep 9,788
So I looked into Reolink POE systems as well as Eufy Cam wireless systems. Notes and questions below.
Reolink - for some reason the 4MP version offers clearest pictures and highest frame rate vs 5MP and 4K/8MP. Watched various YouTube videos on this and a guy showed pictures captured at 50 ft and 4MP was clearest. Anyone knows why? - setting to record 24/7 HDD can only store about 3 days worth; more with lower resolution. - not sure if I should go with old 4MP version or 4K ($170 difference) Eufy Cam - better motion detection and fewer false alarm (it’s not 24/7 recording) - batteries should last a year before recharging - ease of setup Can’t decide which is better. It seems that the best solution would be to have a wireless system for motion detection and then POE if I need more footage should something happens. Which version do you have? |
04-27-2020, 05:38 PM | #310 | |
613
Rep 1,254
04-28-2020, 04:13 PM | #311 |
3588
Rep 9,788
EL Jeffe 5612.50 |
04-28-2020, 04:41 PM | #312 | |
613
Rep 1,254
Like I said earlier 2019 Iowa temperatures broke record with the coldest temperatures recorded -30°F on January 31 2019 no issues.
04-28-2020, 04:53 PM | #313 |
3588
Rep 9,788
Nice! Lots of people seem to recommend Reolink. Was going back and forth between POE and wireless and ultimately decided on the former. Will get a few Ring floodlights for the front garage and backyard for motion sensing notification while the Reolink will record 24/7.
EL Jeffe 5612.50 |
05-02-2020, 10:53 PM | #315 |
3588
Rep 9,788
Was thinking of getting 8MP/4K but don’t think it’s needed at almost 2x the price. For home use 4-5MP is plenty. I’ve watched enough video reviews and the 4MP is good enough as it’s already better than 1080P.
05-03-2020, 06:10 PM | #317 |
11592
Rep 11,145
05-03-2020, 08:04 PM | #320 |
146
Rep 158
I recently bought 4 Reolink RLC-520 cams (5 MP, turret, PoE) for $34 each and am quite happy with them.
- The resolution is 2560 x 1920 which is 4:3 so it is not 16:9 widescreen, but it gives you a wider vertical angle. The 4 MP cams are 2560 x 1440 which is 16:9 but then you lose some viewing angle from the top and bottom. - For the PoE wiring, I used flat Ethernet cables that can fit under window frames, and along the walls with adhesive clips. I also used an Ethernet line splitter to run 2 cams over 1 cable for 1 location. My house has structured Ethernet wiring running back to a central wiring closet. - I record 24/7 to a QNAP NAS with QVR Pro. The bitrate per camera is around 8 Mbps during the daytime and 2.5 Mbps at nighttime (black and white night vision and frame rate drops to 12 fps). So around 50 GB/day per camera. I record to a 4 TB hard drive so that's enough for over 2 weeks for 4 cams. |
05-03-2020, 08:32 PM | #322 | |
3588
Rep 9,788
05-04-2020, 10:42 AM | #323 |
11592
Rep 11,145
05-07-2020, 11:20 PM | #325 |
3588
Rep 9,788
Installed Reolink system. Took 5 hours or so with all the drilling, running new wires and unhooking old system. So far so good. Not sure about their customer service as I reached out Last week and haven’t heard back.
05-08-2020, 06:07 AM | #326 |
930
Rep 5,538
Anyone uses these, Ring Floodlight camera or Eufy one? I was going to give Eufy a try, 1 flood at garage, 1 at backyard, and the doorbell camera. After reading a bit, seems like Eufy offers internal storage with no subscription, better app, and support.
With floodlight combo install is super easy and no need to buy floodlights for house separately Last edited by Kolyan2k; 05-08-2020 at 06:14 AM.. |
05-08-2020, 01:55 PM | #327 | |
Guest
Rep n/a
Drives:
The 6MP and 8MP cams mentioned are still fairly "value" oriented, so other than the slightly larger sensor size of the 8MP cam, the specs on the 4MP cams that were replaced have got to be pretty crummy in comparison to make as dramatic of a difference as you are describing. More than likely, the 4MP cams you'll reference use the same exact sensor as the 6MP that replaced them. You'll end up with a higher resolution/wider field of view for sure, but you'll actually get worse low light performance out of the 6s for obvious reasons. Other conditions should provide fairly equal results though. |
05-08-2020, 02:21 PM | #328 | |
3588
Rep 9,788
05-08-2020, 06:38 PM | #329 | |
11592
Rep 11,145
zx10guy5151.50 |
05-09-2020, 11:25 AM | #330 | |
Guest
Rep n/a
Drives:
As mentioned, most value-oriented 6MP cams are built using the same exact hardware, chipsets, sensors, lenses, etc. as 4MP cams...only difference is that they pump more resolution through 'em via firmware hacks. It's the equivalent of stating that a 335 w/ no muffler and an M badge is vastly to superior to those that are stock...laughable, at best. |
