10-29-2018, 12:18 PM | #24 |
Rep 25
Drives: 2019 X7 and 2020 X3 M40i
Sorry the noob but what is drone effect?
Also where are those connectors at, more or less? I did install the M Sport Exhaust (mid section muffler). It changed very slightly, wasn't worth the investment IMHO.
2018 BMW M5 Rhodonite Silver
1985 BMW M635csi Diamond Black 1994 Porsche 968 Amazon Green 1991 Acura NSX Red 1988 BMW M5 E28 (retired) |
01-08-2019, 02:39 PM | #25 |
852
Rep 818
If its same as X5M i'm assuming you put the car into Sport+ rev the engine then shut the car off so that valves remain in open position. Physically verify that valves are open since they are visible on F90, then proceed to unplug the connectors, tape them and tuck them away.
I have done this mod on my X5M and there is drone which i don't mind, however looking at F90 insulation i highly doubt this will be the case. On X5M it works perfect as i don't want the full system and the exhaust note is just slightly amplified, i noticed if you want the drone to go away just drive in sport mode since it elevates the RPM just enough to be out of the drone zone when in high gear. It sounds best when fully warm and you fire it up, it sounds almost like a deep bark, lol. I'm looking forward to same results on the F90. |
01-08-2019, 07:45 PM | #26 | |
75
Rep 142
There is a sound difference, but its nothing seriously and no real change at WOT...you really notice it around half throttle and first start. |
01-08-2019, 07:49 PM | #27 |
75
Rep 142
Go to the rear of your car and get down to eye level with the exhaust tips, look about 6" back from outer exhaust tip. you'll see a black actuator/motor mounted to the exhaust pipe and a wire connector on the bottom of it. - Thats what you need to unplug, one per side. You cant miss it.
09-25-2022, 08:25 PM | #28 |
4092
Rep 3,672
Drives: 2022 M5C
I know I'm reviving an old thread here, but does anyone have photos to show where to unplug the valve control on the LCI?
Not a BMW guy...but certainly an M5 guy.
09-25-2022, 08:31 PM | #29 | |||
4092
Rep 3,672
Drives: 2022 M5C
exhaust valve system unplugged - M5POST - BMW M5 Forum - F90
