04-17-2015, 02:10 PM | #1 |
BimmerPost Supporting Vendor
689
Rep 6,854
ECU Removal for flashing/tuning
Hey all!
At Vivid Racing we enjoy the opportunity to work on customer cars and use them as development mules. As a result, we have our really great flash tune that instantly gains another 90HP over stock and equally great torque gains! But to get that flash tune in, we need your ECU, and its not exactly the easiest job to do, it takes removing some parts and some time. But to get all that extra power? Worth it. See how to take out your ECU on our VR Tuning blog here. -RyanG
Travis Williams
Shop ALL BMW G80 | G82 Parts Here! 480.966.3040 ext 318 Travisw@vividracing.com PM, Email, or Call Directly for aggressive BMW Member Pricing |
02-15-2016, 08:29 PM | #2 | |
749
Rep 2,108
2015 BMW F80 M3: Tractive EDC Suspension / Dinan Anti-Roll Bars / GC Camber Plates / KMP Dual Diff Mount / Girodisc Rotors / GT4 Brake Cooling Kit / PTF Flash Tune / Eisenmann Downpipes / CSF Heat Exchanger / BMS Charge Pipes
2007 BMW E92 335i (SOLD): BMS JB4 / Quaife LSD / Riss Racing DPs / Helix Intercooler / BMS Intake / STETT Charge Pipe / Forge DVs |
02-16-2016, 09:11 AM | #3 |
689
Rep 6,854
I'd need to double check with our technician, but from the info I have found the intake manifold bolts should be 15nm or 11 ft.lb
Travis Williams
02-16-2016, 09:30 AM | #5 |
689
Rep 6,854
Yes, I am not sure where you would drill into it
Travis Williams
02-16-2016, 09:36 AM | #6 |
Gone Fishin’
7318
Rep 12,125
02-16-2016, 09:42 AM | #7 | |
689
Rep 6,854
I have personally seen 5 or 6 F8x cars here that have had the ECU done this way, I'm not sure the grand total of ECUs that have been mailed in for this application. It certainly is not as popular as our less invasive tuning box solution, but I'm sure as more and more big builds start coming it will turn up. -Sean
Travis Williams
02-16-2016, 11:17 AM | #8 |
8208
Rep 18,823
Drives: BMW
Its actually easier to open/reseal the ECU, which we've been doing for some time now.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
02-16-2016, 11:29 AM | #9 |
Gone Fishin’
7318
Rep 12,125
02-16-2016, 04:13 PM | #10 | |
749
Rep 2,108
Btw, is there a gasket for the intake manifold that would need to be replaced or something?
02-16-2016, 05:15 PM | #11 | |
689
Rep 6,854
-Sean
Travis Williams
08-04-2018, 02:56 PM | #12 |
Registered
Rep 1
Hi there, I have question regarding the ECU tune I just did on my 2018 M3. Power gains are definitely noticeable, however what is also noticeable is the exhaust is a lot quieter. I have the BMW MPE exhaust, prior to the tune it was much loader. Is this a common thing?
