02-21-2020, 09:09 PM | #67 |
4427
Rep 4,109
02-22-2020, 05:21 AM | #68 |
367
Rep 804
To settle the RC VS JB debate is simple, scoreboard, suckers. There's no 10.2 1/4 or close on the RC plain and simple
Hockeytyme575.00 |
02-22-2020, 10:33 AM | #70 |
4427
Rep 4,109
02-22-2020, 12:56 PM | #71 | |
575
Rep 754
That being said, JB4 is capable of being a basic 2 wire solution like Racechip or it's has some crazy power you can unlock as well. It speaks for itself. limeypride is 100% stock and has run multiple 10.3's A couple guys have gotten under 10.3 stock as well and even one guy got just under 10.2 When I was running JB4 I ran 10.15 on map2 and many runs under 10.10 on map6. My car does have FBO's though.
DME: 1848 DA 0-60 2.42 -- 1/8 Mile 6.38 -- 1/4 Mile 9.89 -- 60-130 5.91
Evolve: 1418 DA 0-60 2.48 -- 1/8 Mile 6.47 -- 1/4 Mile 10.05 -- 60-130 6.48 JB4: 1096 DA 0-60 2.54 -- 1/8 Mile 6.50 -- 1/4 Mile 10.05 -- 60-130 6.18 IG: @hockeytyme All runs on street with no prep on 21 inch wheels and PS4S tires |
BMWDriverX367.00 r33_RGSport13050.00 |
02-24-2020, 07:32 AM | #72 | |
116
Rep 226
Hockeytyme575.00 |
02-24-2020, 11:53 PM | #74 | |
4427
Rep 4,109
Before my back/neck went, I could do it in about 15-20 mins. Removal being a little quicker. // EDIT: I should've added that this was on an F06 M6 GC (S63TU), not my F90s. However, the differences are subtle having watched my (young) mechanic/friend do it twice now. |
02-25-2020, 07:41 AM | #75 |
3619
Rep 4,532
02-25-2020, 08:23 AM | #76 | |
4427
Rep 4,109
I always set the JB4 to map 0 when going in for anything. No issues yet. That said, I think he's talking about physical detection. |
02-25-2020, 08:47 AM | #77 | |
3619
Rep 4,532
So, I’m lazy, took the ten second option. |
limeypride4426.50 |
02-25-2020, 09:32 AM | #78 | ||
13050
Rep 18,751
So making bypass plug out of 22pin parallel port connector is no longer possible.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
onfireX53618.50 |
02-25-2020, 09:59 AM | #79 | |
19624
Rep 10,205
https://www.radioshack.com/
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
Hockeytyme575.00 |
02-25-2020, 10:01 AM | #80 | ||
13050
Rep 18,751
Hockeytyme575.00 |
02-25-2020, 10:02 AM | #81 |
19624
Rep 10,205
02-25-2020, 07:17 PM | #82 | |
550
Rep 949
02-25-2020, 07:46 PM | #83 | ||
13050
Rep 18,751
Hockeytyme575.00 |
02-25-2020, 09:09 PM | #84 | |
3619
Rep 4,532
Possibly your SD will deny your warranty, etc. with a harness only, could happen. But your SD isn't all SD's. I have 40,000 miles of warranty work done with the SD knowing the harness is there without a problem. On multiple BMW's. I also know my SD will flag a Box. Any box and it has happened on this forum. If you want to split hairs, an anal SD can have the DME inspected with all physical traces removed and still find parameters beyond the factory hysteresis and deny warranty. Removing a box and harness does nothing to prevent that. Telemetrics also is a potential. Just don't lump all SD's into one category. Some probably do not care even if you have the box on the car. |
02-26-2020, 01:31 AM | #85 |
143
Rep 309
What is the point of leaving the box on, any warranty work they are going to defo look for over boost as they can see you had a chip on it, unless you know the stealer well.
Remove it, and they are going to have some other reasons to check for a tune, much stronger chance your warranty work is accepted.
2020 C8 RS6
2019 F90 M5 2017 C7 RS6 2016 F10 M5 2010 C6 RS6 |
02-26-2020, 07:17 AM | #86 | |
3619
Rep 4,532
02-26-2020, 10:34 AM | #88 | |
550
Rep 949
BMW service flags any aftermarket wiring harness that goes to sensors under the hood. They are trained to check for these harnesses. Whether there is a box connected to the end or a bypass plug makes no difference to them they know it's been modified. So do yourself a favor and remove the entire thing or don't be surprised when you find out you can't turn back in your lease or your car has been flagged. Maybe your SA is "cool" and not documenting your car as a favor to you but that doesn't mean someone else there won't or if a corporate guy happens to be at the shop when your car is there. |
