BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    New Shoes arrived - Titan 7 T-S5 20”
      03-24-2020, 04:09 PM   #1
northtorque
northtorque's Avatar
268
Drives: F90 2019
New shoes arrived. Will be awhile till I can get them put on though - covid making the rounds certainly takes a some of the joy out of this spring. I’ll post installed pics when done. Take care out there everyone!
Titan 7 T-S5 20” staggered in satin titanium
F: 20x10” +22 @ 22.8 lb
R: 20x11” +30 @ 23.8 lb
Note: weights reported not measured
Great price point for forged, weight and quality
I can’t wait to ditch some of that rotating mass of the OEM shoes.
Appreciate 4
      03-24-2020, 04:22 PM   #2
marcvtec
407
Drives: M5
Nice.
Waiting for pics on car ! .
      03-28-2020, 10:44 PM   #3
apsuard
195
Drives: 2021 BMW M5 Competition
What tire size are you going to run?
      03-29-2020, 08:33 AM   #4
euro*
euro*'s Avatar
1658
Drives: F90 M5
Looking forward to seeing them installed on your car
      03-29-2020, 09:46 AM   #5
flanast
flanast's Avatar
Drives: e92 M3
I'm looking forward to seeing them on your car. Will they clear calipers in an M5 Competition? What tires will you be using?
      03-29-2020, 10:33 AM   #6
northtorque
268
Drives: F90 2019
Michelin PS4S in:
285/35R20 and rears 295/35R20
flanast148.50
      03-29-2020, 10:44 AM   #7
northtorque
268
Drives: F90 2019
Me too! I’ll post when installed
I have the base so cannot comment with certainty - Titan 7 were quick with their responses so I would contact them and ask. The wheel dimensions and offsets are specifically made by Titan 7 for the M5 so I would imagine they have made the design fit both iterations base and comp - also the the barrel diameter appears to at least match oem so is should be good for clearance since my stock oem 706m bicolour wheels have the same dimensions as the black oem wheels which can be ordered for the comp.
flanast148.50
      04-02-2020, 10:50 PM   #8
northtorque
268
Drives: F90 2019
Really pleased how the Titan 7 T-S5 wheels turned out - the satin titanium finish does a great job complimenting the donington grey. Pics shown are stock suspension and no spacers - it is an effective one step solution that improves the stance a bit and removed a total of 48lbs / 22kg of rotating mass. Also can really see the rotors and callipers now!
Appreciate 6
      04-03-2020, 09:27 AM   #9
Vic55
Vic55's Avatar
19355
Drives: 2023 BMW M8 Competition Coupe
The M5 CE and the "Base" F90 M5 have the same calipers and the same size and offset in wheels (just different models)- you will fine.
I cant speak to Carbon Ceramics.
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White
2022 Porsche Carrera GTS Coupe Shark Blue
2020 Audi R8 V10 Performance Suzuka Gray
2012 Mercedes Benz C63 AMG Black Series Obsidian Black
flanast148.50
      04-03-2020, 11:02 AM   #10
amg55driver
79
Drives: F90 M5
They look FIRE!
good job!
      04-03-2020, 03:37 PM   #11
Jocko78
104
Drives: M5 / X3 M40i
Super clean, good option for me so thank for posting. This is my daily and I need something a little more forgiving than 21s.
      04-03-2020, 03:56 PM   #12
euro*
euro*'s Avatar
1658
Drives: F90 M5
Looks great!! Are you planing to lower your car??
      04-03-2020, 05:20 PM   #13
flanast
flanast's Avatar
Drives: e92 M3
Look great 👍
      04-04-2020, 04:08 PM   #14
northtorque
268
Drives: F90 2019
I contacted Titan 7 and they have confirmed that the T-S5 is compatible with the larger ceramic brake option as well - so these will fit all combinations and permutations of M5.
Originally Posted by amg55driver View Post
They look FIRE!
good job!
Thx!
I was hesitant about 21” also given our frost heave roads and this being my daily driver as well. That is why I went with the 20”.
Thx! No plans on lowering at this time. For me at least, I think I would lose too much practicality if I lowered.
Look great ��
Thx!
      04-05-2020, 10:59 AM   #15
flanast
flanast's Avatar
Drives: e92 M3
Michelin PS4S in:
Any idea how big you can go on tires?
      04-05-2020, 11:15 AM   #16
Jocko78
104
I'm moving forward with these. Spoke with the company, 285 front, 305 rear. The 285/295 setup works very well too.
flanast148.50
      04-06-2020, 02:45 PM   #17
northtorque
268
Drives: F90 2019
^ this... I went with 295 rears since I’ll be putting a 100k on the odometer easily as a daily. If I was going for mods and fun I think the 305 would be great.
For the front 285 gives nice stance and had no issues whatsoever. Any larger and I would worry about clearance at extremes of suspension travel.
Appreciate 2
flanast148.50
Jocko78103.50
      04-10-2020, 10:47 AM   #18
Jocko78
104
Do you feel any difference after having dropped that rotational weight? Ordered mine, can't wait.
      04-10-2020, 12:20 PM   #19
northtorque
268
Drives: F90 2019
Surprisingly I note a significant difference on turn in - feels much more planted and the reduced rotational inertia likely is the reason behind the lighter and more accurate steering feeling. Nose points quicker. I say “surprisingly” because it is such a heavy car after all. The Michelin PS4s grip great as well. However, I must disclose that part of this subjective improvement is no doubt due to fact that I just took off the winter tire set that I had put on the original OEM rims - thus I have changed both the wheels and the tires which makes a direct comparison of only the wheels inaccurate. The dry traction and lateral stability on the winters are obviously not going to be anywhere like my setup now in these warmer temps. Very pleased. If I could do it all over again I probably might even run the 305 width in the rear for a little more of a badass look. One other thing. My old summer Pirelli / OEM wheel setup used to occasionally wheel hop or chirp on 1-2 up shift when using launch control. The Michelin / Titans just bite with no hop or traction break. This is good - makes a special car look and feel even better!
Jocko78103.50
      04-11-2020, 09:30 AM   #20
Jocko78
104
Thats awesome, I decided to go 305 pilot sports and will post a couple pics. Agree that the tires had an impact but I'm sure that much weight off the wheels did as well. Appreciate the feedback.
      04-11-2020, 11:15 AM   #21
northtorque
268
Drives: F90 2019
      04-19-2020, 12:49 PM   #22
Jocko78
104
Installed...
Got them installed. Forgot the center caps :-) so ordering those. The ride is great, 285/305. The car does need to be dropped a little but not too much as its my daily. These wheels are so light, amazing.
ToddinTN504.00
