BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    Big problem with m5 f90 2018 !!! Video inside help guys!!!
      03-10-2020, 10:38 AM   #1
IbisF90
Drives: M5F90
https://youtu.be/hWH7IjH9DeM
Hello,
for a long time I have been struggling with the problem of a roar in the car when moving. In addition, large body vibrations during the connection. The problem began in the car after about 40,000 km. Mileage at present 60,000 km The following things have been done to maintenance services:
- bridge replacement - back side,
-new set of discs, blocks front / rear,
Tires OK.
Geometry, convergence OK.
The service is not able to verify the fault.
BMW POLSKA believes that it should change the driving style, i.e. walk.
The car was never on the track. It never went sideways.
Normal use.
PLEASE HELP! Maybe someone had a similar case.
      03-11-2020, 04:22 AM   #2
Nikolov
239
Drives: '19 F90 M5C, '17 911 TTS
Are you braking hard when the sound appears? If so, that's normal, it's your brakes disks warping a bit. It's also normal to continue hearing it if you're braking again shortly after.
Snapper Rocks Blue on Tartufo leather | All options except Homelink and tow hitch
