BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    Has anybody considered M8 Comp wheels for F90??
      08-04-2019, 06:10 PM   #1
euro*
euro*'s Avatar
1658
Drives: F90 M5
As title states. Has anybody considered getting OEM Competition wheels from M8 for their F90 M5??
I think it should look pretty awesome when the car is lowered and spacers.
Can anybody photoshop it??
      08-05-2019, 12:37 AM   #2
brad850csi
1316
Drives: 16 F13 M6 Comp
The M8 has a track of 1627mm at the front and 1632mm at the rear.
The M5 is the same at the front but the rear is 1593mm, I don't think anyone has managed to fit 20mm spacers to the back of the M5 on stock wheels so I'm going to guess this won't really work.
The F10 and F13 were much the same, the rear wheels from an M6 were way too aggressive for an M5.
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
Appreciate 2
euro*1657.50
somer966.00
      08-05-2019, 10:13 AM   #3
euro*
euro*'s Avatar
1658
Drives: F90 M5
That makes sense, thanks for explaining it like that
Well that's a bummer
      08-06-2019, 10:51 AM   #4
hybrid_eg
hybrid_eg's Avatar
Drives: 90 S13, 22 MSP, 23 JLUR 4xe
F13 wheels fit just fine on F10 M5.. no spacer needed in rear and small spacer up front, lowered on KW.. as for M8 wheels fitting an F90, we would need to look at the exact size and offset. Did BMW release this yet? I couldn't find it online anywhere.
      08-06-2019, 02:48 PM   #5
brad850csi
1316
True, but it is borderline and you can run 305s on an M6 but not an M5 with those wheels I believe. The M6 was 19mm and the M5 34mm so 15mm difference.
The F90 and F92 will be 20mm difference in offset assuming that the rear axle is the same and they are achieving the track difference by using a different offset. But the F92 might have a unique rear axle - we don't know yet. If it has an axle which is unique and is wider so the offset is closer then the wheels might fit just fine. But I think if the axle is the same I think that 20mm will be too much!
soopa113.00
      08-06-2019, 02:58 PM   #6
hybrid_eg
hybrid_eg's Avatar
correct, yes i ran stock tire sizing on the F10 using F13 wheels with no issues an no rubbing fully loaded.
If F92 is 20mm apart from F90 fitment then yes the rear will not work unless adding additional negative camber, front may work but even that will be a tight fit with few millimeters of poke past the fenders.
      08-06-2019, 03:02 PM   #7
euro*
euro*'s Avatar
1658
Drives: F90 M5
I was searching all day yesterday, could not find specs for those M8 comp wheels anywhere yet.
      08-06-2019, 03:17 PM   #8
brad850csi
1316
Yeah I couldn't find anything either. Probably realoem.com will get updated first with the wheel specs and we'll know the info from there.
My question with the M8 wheels is if the 813M and 811M are both forged (and in turn what the weights are). The press release talks about the 813M being forged but no mention of the 811M construction at all.
863M wheels are cool too. https://www.bmw-m.com/en/topics/maga...nce-parts.html
      08-06-2019, 04:42 PM   #9
euro*
euro*'s Avatar
1658
Drives: F90 M5
Yes they are, looking forward to seeing more real photos of that style also
      08-15-2019, 02:54 PM   #10
Leestep69
Drives: Nissan GTR
What if you put the rear wheel off the m5 up on the front as well. Most people like to space out their wheels anyway. With the rear being 1 inch wider that would be like putting a 12 mm spacer up front so now the wheel is out a bit more and you could run a square set-up on tires and rotate them. You could still put a 12 mm spacer out back to help keep the stance more balanced as well.
      08-24-2019, 10:30 AM   #11
IancoleTX
Dillo boxers
IancoleTX's Avatar
Drives: 2019 M5C
Those wheels look like a nightmare to clean lol. Stock comp wheels are bad enough
      10-19-2019, 09:53 AM   #12
euro*
euro*'s Avatar
1658
Drives: F90 M5
Offset specs for both 813m and 811m found. Same offset as F90 wheels, so shouldn't be any issues with fitting them of F90
811M:
FFront Wheels: 9.5Jx20 ET28 (p/n 36118089564)
Rear Wheels: 10.5Jx20 ET28 (p/n 36118089565)
813M:
Front Wheels: 9.5Jx20 ET28 (p/n 36108089568)
Rear Wheels: 10.5Jx20 ET28 (p/n 36108089569)
Eman1536.00
      10-19-2019, 01:32 PM   #13
brad850csi
1316
Ohh that’s interesting so the M8 has a different rear axle from the F90. That’s quite handy knowledge actually!
      03-20-2020, 01:08 AM   #14
calicyclist
Drives: 2020 M8 Competition Conv
I realize this is a several month old thread but just curious if anyone here is actually interested in these rims.
I am looking to buy an M8 competition and it has these rims but I like the blacked out ones way better and am trying to swap them out. I could work out a good deal compared to what they are selling for online.
https://www.alloywheelsdirect.net/bm...13m_wheel_6460
      03-21-2020, 10:22 AM   #15
amg55driver
79
Drives: F90 M5
Ewww
I hated the similar ones from M3/M4..
To each its own.
      04-29-2020, 09:52 PM   #16
ski1972
43
Drives: M5 finally
811m on 550i unfortunately 285/35/20 with this offset is no go , will try 275/35/20 near future , Love the wheels
      04-29-2020, 11:33 PM   #17
Mrbig
106
Drives: 15 M3
M8 wheels ?
Where u find a set ?
      04-30-2020, 08:00 AM   #18
ski1972
43
Drives: M5 finally
craigslist NY special already order 275/35/20 for rears. view of the rear wheel
Eman1536.00
      04-30-2020, 08:01 AM   #19
ski1972
43
Drives: M5 finally
sorry that is a picture of the front wrong upload.
      04-30-2020, 08:24 AM   #20
euro*
euro*'s Avatar
1658
Drives: F90 M5
I love it, they look as good as I imagined! Thank you for sharing!
And like somebody asked, where were you able to find them?
      04-30-2020, 10:32 AM   #21
ski1972
43
Drives: M5 finally
Really want to keep them they look really constructed strong too, unfortunately for m550i rears poke a lot hopefully before purchasing 2 new front 9.5 275 35 20 tires will do the trick .
      05-05-2020, 05:09 PM   #22
ski1972
43
Drives: M5 finally
Final update 275/35/20 works with no rubbing a little stretch on 10.5 rim but I can live with that .
