BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    HRE Wheels | Track Ready F90 M5 with HRE RC104's in Satin Gold!
      01-21-2019, 11:26 AM   #23
HRE_Wheels
HRE_Wheels's Avatar
Drives: F80 M3 6MT
Originally Posted by M5speed View Post
How much to put a set of these on layaway? Being three piece, Id figure them to be somewhat less than the mono-block ones.
Meaning how much are they?
How much for the wheels? Pm me thanks!
PM inbound
      01-21-2019, 11:56 AM   #24
WheelsBoutique
WheelsBoutique's Avatar
1180
Drives: 2015 M4
I will send you over more information on these wheel shortly.
      01-21-2019, 12:03 PM   #25
WheelsBoutique
1180
Drives: 2015 M4
Originally Posted by Viper7 View Post
I've got a question for all you wheel and tire gurus.
I want to go with 21" wheels but stick with the PS4S tires, rather than go back to PSS's.
That means I'll probably stick with a 275 tire on the front (same as OE width), but go to a wider 295 on the rear (given there is no 285/30/21 size for the PS4S).
Does this present any issues for the 4WD system etc? Since I've gone one size wider at the rear but stuck with OE at the front, and the diameter of the new tire combination is a slightly bigger difference between front and rear?
Anyone upgraded to the below sizes and have any feedback?
F:
21 x 9.5
275-30-21 Michelin PS4S
R:
21 x 11
295-30-21 Michelin PS4S
This will not present any issues for you. Moving from the 285 to 295 will only be a height difference of 0.88%. The general rule of thumb is that you should stay within +/- 2% difference from the OEM overall rolling diameter so in this case you're completely fine.
We own an F90 M5 and know the fitments very well so if you ever need to lean on me with more questions like this feel free to PM or email me.
      12-10-2019, 01:55 AM   #26
cream
cream's Avatar
46
Drives: 19' BSM M5
What is the best -offset/tire set up I can get away with for the most concave look? My F90 is running the KW HAS kit with front on lowest setting and rear is 10mm from lowest setting.
Please PM me pricing for 21x10 + 21x11 thank you!
      12-10-2019, 04:52 PM   #27
WheelsBoutique
1180
Drives: 2015 M4
Sure thing, PM on the way.
      12-17-2019, 06:24 PM   #28
RoseyLA
28
Drives: F90
I love my HRE s104's! I'm curious, how much my 104's weight vs stock. I forgot to throw them on the scale prior to install...TIA
josec704074.00
      12-18-2019, 12:54 PM   #29
WheelsBoutique
1180
Drives: 2015 M4
What widths did you order for the wheels? I can give a quick estimate on what the S104's weigh. The stock wheels are complete anchors. I know those are in the upper 20's or 30's.
      12-18-2019, 04:50 PM   #30
marcvtec
407
Drives: M5
Can you do a far out side shot from like 30 feet ? Thanks.
And I assume those are 20 inch ?
      12-18-2019, 04:58 PM   #31
RoseyLA
28
Drives: F90
10'' up front and 11'' out back. thanks for the help.
      12-18-2019, 05:00 PM   #32
RoseyLA
28
Drives: F90
Here you go. Yes, 20'' all around with KW HAS. height is even all the way aroun
      12-19-2019, 11:16 AM   #33
WheelsBoutique
1180
Drives: 2015 M4
P101's weigh approximately 20.8 lbs for the front and 22.2 lbs for the rear. The S101's weigh approximately 2 lbs more per wheel.
RoseyLA28.00
      02-24-2020, 06:12 PM   #34
mr_dennis_s
Drives: 19 M5C
Originally Posted by HRE_Wheels View Post
I weighted the wheels before we released them to the customer, here are the weight figures as compared to OEM, it's quite impressive:
HRE RC104:
20x10 - 22.00lbs
20x11 - 23.20lbs
BMW OE Competition Wheel Weight
20x9.5 - 28.00lbs
20x10.5 - 29.50lbs
Weight info was taken from this post
HRE Weight Savings for RC104
Fronts - 6.00lbs per wheel saved - 12lbs in total up front
Rears - 6.30lbs per wheel saved - 12.6lbs in total on the rear
Total weight saved, 24.60lbs of unsprung weight.
For those of you who want to save even more, then these bad boys would do the trick, a set of R101 Lightweights in 20":
HRE Weight Savings for R101 Lightweight
Fronts - 9.8lbs per wheel saved - 19.60lbs in total up front
Rears - 10.7lbs per wheel saved - 21.40lbs in total on the rear
Total weight saved, 41.00lbs of unsprung weight.
Do you have pics of these wheels mounted on F90 M5?
      02-24-2020, 06:34 PM   #35
WheelsBoutique
1180
Drives: 2015 M4
Yes we do. Admittedly the car would have benefited visually with a bit of a drop (H&R springs) but the customer wanted to maintain the smooth ride comfort. For those that don't mind chunky tires though this is the perfect set for max wheel performance on this platform.
      06-02-2020, 03:31 PM   #36
mr_dennis_s
Drives: 19 M5C
Can you PM me price for R101 in brushed clear? 18lbs is incredible. What size tires are on the pic above? 295/35 and 285/35?
      06-02-2020, 04:50 PM   #37
WheelsBoutique
1180
Drives: 2015 M4
Yes of course. I'll send a PM right over
