05-13-2020, 05:22 PM | #2 |
3323
Rep 8,083
are you looking to do alcantara?
send it to cobywheel in GA. wraps OG wheel in alcantara, does 12oclock stripe, looks sick. and much cheaper than BMW wheel. And retains heated function. |
05-15-2020, 09:25 AM | #3 |
57
Rep 644
05-15-2020, 06:35 PM | #5 |
1659
Rep 1,536
Does your car have Active Cruise control/Lane assist and heated option?? Those will all be disabled once you will go either aftermarket or OEM M Performance wheel. Hence I stayed stock, just added CF paddles and CF steering wheel trim.
05-16-2020, 12:03 AM | #7 |
General
13013
Rep 18,734
I can get it done.
Here are what has been made for F97 X3M, which will fit on F90 M5 too.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
05-16-2020, 07:43 AM | #10 |
General
13013
Rep 18,734
Can't do it over CF, because the heat will not radiate through it. Only on leather and Alcantara.
05-16-2020, 01:46 PM | #11 |
82
Rep 142
05-16-2020, 02:33 PM | #12 |
General
13013
Rep 18,734
Unfortunately no, because the heating element is 1 full loop.
05-20-2020, 03:31 PM | #14 | |
82
Rep 142
My wife’s Lexus has an oem heated wheel. As you may know, Lexus often comes with a partial wood wheel, basically from 10-2 and 5-8 position, if I have my clock face right. There is no heat that can be felt in the top and bottom, the complete wood portion, yet it works well in the leather parts. |
r33_RGSport13013.00 |
05-20-2020, 06:01 PM | #15 | |
General
13013
Rep 18,734
But the manufacturer is not re-engineering the whole steering wheel, just rewrap it and reshape it. It would be ideal if they can do that for me.
05-21-2020, 12:02 AM | #16 |
Enlisted Member
22
Rep 41
Nice swap!
05-21-2020, 08:48 PM | #17 | |
390
Rep 1,152
ETHOS_DAN11.50 |
07-20-2020, 04:59 PM | #19 |
106
Rep 195
I was debating this as well, have a heated wheel I really like so I just ended up changing the aluminum trim out to CF and put on some 3D Design paddles, helped spice it up so good enough.
09-13-2020, 07:24 PM | #20 |
419
Rep 280
Heated still works on the 9 & 3 position. Vibration/lane assist (Auto steer back into lane if swerving out) works. Only thing I couldn't transfer over was my driver assistance brain (basically BMWs auto pilot) because the company cut up the slot that was supposed to be inserted for that. Had no room with all the other wires to put it elsewhere unfortunately.
JayZap16104.50 |
09-14-2020, 12:21 AM | #21 | |
1659
Rep 1,536
edwarjejeega418.50 |
09-14-2020, 07:26 AM | #22 | ||
419
Rep 280
If you have any questions and want to talk my Instagram is @edwarjejeega. I'm very easy to reach there. Even if you would need help with the installation process, don't do what I did and spend $350. It can easily be done at home in 30 mins as long as you have the tools. Edit: more angles |
