BMW M5 F90 (2018+) General Forums Cosmetic Modifications    DIY: F90 / G30 LCI Tail Lights Retrofit
      04-10-2022, 04:44 PM   #529
euro*
euro*'s Avatar
1658
Drives: F90 M5
Originally Posted by Neil McRae View Post
So I got mine to work.
I've got a F90 Comp with the new LCD cockpit - I followed the re-pin instructions by the OP but I had the same as Whiskey and I note he has the same model car of mine. turn signals ok on the outside but the brake light blinking on the inner lights. So I moved pin 5 on both to pin 4. And that resolved it.
So only one thing I don't have is the inner red lights don't react to brake pedal but that is the same behaviour as the LCI I believe.
I didn't have to do any coding, no errors, reverse lights work, fog light works; welcome lights work.
Cheers,
Neil.
That's not a proper way for them to work, all 4 have to light up upon braking. You need to get lights coded for them to work properly.
      04-10-2022, 05:35 PM   #530
Neil McRae
BMW Motorsport
Neil McRae's Avatar
United Kingdom
235
Drives: BMW ///M4 F82 / BMW ///M5 F10
2020 BMW M5 CP  [0.00]
2015 BMW M4  [10.00]
Ok cool I’ll have a go at coding this week.
      04-10-2022, 10:58 PM   #531
Maverik259
Maverik259's Avatar
Drives: F90 M5 / F15 50i
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
The outers work because they're plug and play. The inners is why the wiring and coding is required. GL.
'07 Yamaha R1 (sold)
'06 C55 AMG (sold)
‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe
'14 X5 50i (wife’s now)
Joe-BMW337337.50
      04-11-2022, 09:11 AM   #532
PetieD 7
170
Drives: 540i xDrive M Sport
Was wondering any OEM LCI taillights "retrofit wiring harness" available for pre-LCI models in North America at this point?…folks from one of performance shops out there mentioned it's available…and is considered an OEM part.
      04-11-2022, 10:03 AM   #533
Joe-BMW33
Joe-BMW33's Avatar
7338
Drives: '18 M550i|'21 X5|'03 540i
2013 VW Tiguan  [0.00]
2015 Infiniti QX60  [0.00]
2021 BMW X5  [0.00]
2003 BMW 540i  [0.00]
2018 BMW M550  [10.00]
This would be the harness that comes with the Chinese knockoffs. They are plug and play and include a harness that effectively re-pins and jumps the out to inner and require no coding.
2018 M550ix|Carbon Black|Dinan Modifications|2003 540i|Jet Black|M-Sport|2021 X5 Mineral White
Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|2002 745li|2007 750li|2006 750li|2001 530i|2012 535xi|
      04-11-2022, 10:14 AM   #534
PetieD 7
170
According to this vendor, they're selling OEM LCI taillights w/ necessary associated parts (which include retrofit wiring harness). If the "retrofit wiring harness" part(s) will work with OEM LCI taillights assemblies, it could avoid re-pin the wire connectors and assist many DIYers out there.
      04-11-2022, 10:21 AM   #535
Joe-BMW33
Joe-BMW33's Avatar
7338
2021 BMW X5  [0.00]
Interesting. If it adds expense, repinning and running the jump is easy enough. If this avoids coding, that's another story.
      04-11-2022, 10:46 AM   #536
Joe-BMW33
Joe-BMW33's Avatar
7338
2021 BMW X5  [0.00]
I pinged them for a price and to define what "Coding and Activation" means as part of the list of what you get.
      04-11-2022, 01:15 PM   #537
Neil McRae
BMW Motorsport
Neil McRae's Avatar
United Kingdom
235
2015 BMW M4  [10.00]
So I made a jump cable to the inner brake light from the the outer brake light. Works. No coding required on my car.
Neil.
Neil J. //McRae -- Alive and Kicking -- neil at DOMINO.ORG --///M ARMY
M5 CP Alpine White -- M2 LBB -- M4 DCT CP Alpine White
      04-11-2022, 01:50 PM   #538
Joe-BMW33
Joe-BMW33's Avatar
7338
2021 BMW X5  [0.00]
Neil.
So when you step on your brakes the inner lights light up with the outer?
      04-12-2022, 01:20 AM   #539
pooyab
pooyab's Avatar
330
Drives: 2011 BMW M3 2020 BMW M5C
2011 BMW M3  [0.00]
I've been reading through this DIY. I ordered Euro ones from Abdul, and I have the lights installed (pending the pins/new wire since those haven't arrived yet). In the mean time I'm trying to sort out the coding.
I saw this posted earlier, but running into some issues:
1) Update software to 03-2021
2) Add HELC to HO-WORT
3) Code BDC module
4) Make some changes manually (bimmercode can do this too):
BL_L_CCM: ccm_346 [01 5A]
BL_L_IS_LED: nicht_aktiv, default [00]
BL_L_MIN_PWM: 5% [05]
BL_L_WARMUEBERWACHUNG: nicht_aktiv [00]
BL_R_CCM: ccm_345 [01 59]
BL_R_IS_LED: nicht_aktiv, default [00]
BL_R_MIN_PWM: 5% [05]
BL_R_WARMUEBERWACHUNG: nicht_aktiv [00]
For the software update, the car says it's already up to date. I was able to get HELC written. But when I read BDC_BODY2 I don't see any of the other listed parameters to edit. Not sure if I'm missing some other step or it's something completely different. I'm using Esys since bimmercode said it couldn't even ready the BDC. For reference the car is a 2020 and originally CAD. Was wondering if anyone else ran into similar issues?
Also is there a cheat sheet for F90s? I'm not sure what the commonly coded features are on this car, or even what is available overall, but the cheat sheets I've found so far have not been helpful, since most I can't find (again).
Interlagos Blue/Speed Cloth | BayOptiks DTM Headlights | Alpine Stage 2 | KW Clubsport | Resonated X-Pipe | Eisenmann Race | StopTech BBK | TE37SL | YFCM CF Driveshaft | Hotchkis F/R Sways | F/R Endlinks | Turner Control Arms and Front Tension Bushings | Powerflex Diff Bushings | Turner Solid Subframe Bushings | MS Underdrive Pulley and Intake | Alpine DCT Tune | Karbonius Intake | Carbon Roof (TBD)
      04-12-2022, 05:14 AM   #540
Joe-BMW33
Joe-BMW33's Avatar
7338
2021 BMW X5  [0.00]
I know a few people who successfully did their own coding. I used Vic. I do know that there is not a one size fits all coding menu for these. Some of the tweaks vary from car to car depending on MY and software version. I suggest you get it all wired, jumped and pinned correctly and then start messing around with coding through trial and error. Vic did my coding before the install and although it was 90% functional, I did need him to go back in to tweak as just the inners were lighting up when braking.
      04-12-2022, 01:48 PM   #541
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Neil.
Not helpful. More info. What car what lights etc. As it stands this is very vague.
'06 C55 AMG (sold)
Joe-BMW337337.50
      04-13-2022, 05:02 AM   #542
Joe-BMW33
Joe-BMW33's Avatar
7338
2021 BMW X5  [0.00]
Just to follow-up, I pinged these guys with questions and it's like pulling teeth. They still have not given me a price. Here is the exchange, vague on what the harness does, they say still needs re-pinning and coding:
Can you tell me what the price is for this kit and when you say "Coding for Activation" do you provide coding or are these pre-coded and plug and play? 𝐆𝐞𝐧𝐮𝐢𝐧𝐞 𝐁𝐌𝐖 𝐆𝟑𝟎 𝟓 𝐒𝐞𝐫𝐢𝐞𝐬 𝐋𝐂𝐈 𝐓𝐚𝐢𝐥 𝐋𝐢𝐠𝐡𝐭
𝗦𝘂𝗶𝘁𝗮𝗯𝗹𝗲 𝗳𝗼𝗿 𝟮𝟬𝟭𝟳 - 𝗣𝗿𝗲𝘀𝗲𝗻𝘁 𝗚𝟯𝟬
𝐑𝐌𝟓𝟖𝟎𝟎
𝐏𝐫𝐢𝐜𝐞 𝐢𝐧𝐜𝐥𝐮𝐝𝐞𝐬 𝐬𝐡𝐢𝐩𝐩𝐢𝐧𝐠 & 𝐢𝐧𝐬𝐭𝐚𝐥𝐥𝐚𝐭𝐢𝐨𝐧
𝗟𝗖𝗜 𝗧𝗮𝗶𝗹 𝗟𝗶𝗴𝗵𝘁
𝗣𝗹𝗮𝘀𝘁𝗶𝗰 𝗧𝗿𝗶𝗺 𝗖𝗼𝘃𝗲𝗿
𝗥𝗲𝘁𝗿𝗼𝗳𝗶𝘁 𝗪𝗶𝗿𝗶𝗻𝗴 𝗛𝗮𝗿𝗻𝗲𝘀𝘀
𝗖𝗼𝗱𝗶𝗻𝗴 𝗳𝗼𝗿 𝗔𝗰𝘁𝗶𝘃𝗮𝘁𝗶𝗼𝗻 𝗼𝗳 𝗟𝗖𝗜 𝗧𝗮𝗶𝗹 𝗟𝗶𝗴𝗵𝘁
Concept Playzone
Concept Playzone
Hello Joe,
Thank you for contacting us. Concept Playzone will always be ready and happy to serve you !
Please provide us with your vehicle information:
Brand:
Model Year:
Specification:
Existing Mods:
Let us know what you are looking for !
E.g: Bodykits, Performance or Detailing
We will get back to you as soon as possible.
Thank you.
You sent
2018 BMW G30 M550
Tue 10:02 AM
Concept Playzone
Concept Playzone
Hello Joe, so sorry for the late reply as we were receiving too many messages regarding the LCI conversion 🙏 one of my partner had open your message and I did not see that there was notification of unread messages
Concept Playzone replied to you
Original message:
Can you tell me what the price is for this kit and when you say "Coding …
Concept Playzone
We provide the coding to activate LCI taillight to customers that are in the same area as us, the LCI Taillight does not come precoded as the coding part is for your Car's DME to recognise LCI Taillight and to activate it to work properly.
You sent
Thanks. So your wiring harness avoids re-pinning and has a jump wire? Price?
Original message:
Concept Playzone
Let me double confirm with you on this as my installer is busy right now. For the price it's 5800MYR (Malaysian Ringgit) as we are based in Malaysia.
Original message:
Concept Playzone
To double confirm with you, the wire connector still has to be re-pin
Tue 10:50 AM
Concept Playzone
Supplier said that the retrofit wiring harness is just another two extra wires that's all as pre LCI only has only one wire
Concept Playzone
Concept Playzone
It isn't the same as 1:1 China Plug & Play LCI Taillight, as China's 1:1 doesn't need coding to activate the taillights together and there's no need to repin or jump wire.
You sent
Thank you
Concept Playzone
Concept Playzone
You're most welcome 🙏 sincere apology from us for missing out on your message and for the late reply
Write to Concept Playzone
PetieD 7169.50
      04-13-2022, 08:13 AM   #543
Jakerx
Jakerx's Avatar
701
Drives: F90 Comp
Lol. Sounds so sketchy. I wouldn’t touch them with a 10-ft pole.
      04-13-2022, 09:27 AM   #544
PetieD 7
170
𝐑𝐌𝟓𝟖𝟎𝟎
𝗟𝗖𝗜 𝗧𝗮𝗶𝗹 𝗟𝗶𝗴𝗵𝘁
𝗣𝗹𝗮𝘀𝘁𝗶𝗰 𝗧𝗿𝗶𝗺 𝗖𝗼𝘃𝗲𝗿
Concept Playzone
Concept Playzone
Hello Joe,
Brand:
Model Year:
Specification:
Existing Mods:
Thank you.
You sent
2018 BMW G30 M550
Tue 10:02 AM
Concept Playzone
Concept Playzone
Original message:
Concept Playzone
You sent
Original message:
Concept Playzone
Original message:
Concept Playzone
Tue 10:50 AM
Concept Playzone
Concept Playzone
Concept Playzone
You sent
Thank you
Concept Playzone
Concept Playzone
I received a reply message via FB Messenger from this vendor this morning…was informed the "so-called" OEM retrofit wire harness (or harnesses) cannot be sold separately and it must be sold as a kit at $5800RM (apx. $1371.00 USD).
      04-15-2022, 12:12 AM   #545
iliannavy
Drives: bmw f10
2 additional wires to the BDC
Originally Posted by MUC_G30 View Post
Hey guys,
as a forum should be there to help each other, instead of constantly offering services for money, I would like to share a coding solution, that works without throwing errors.
Please note, that this refers to the EURO spec rear lights on a European car, where you also need to run 2 additional wires to the BDC and re-pin the inner connector.
What I did in terms of coding:
1. Update car to latest I-Step 21-03
2. Perform LCI Rear Light retrofit measures within ISTA (this will still throw a break-light error)
3. In BDC code:
  • BL_L_Warmueberwachung & BL_R_Warmueberwachung to "nicht_aktiv"
  • BL_L_CCM & BL_R_CCM to "off"
Here you go, the rear lights work w/o error
Hello.Do you have picture for these 2 additional wires to the BDC.
I did not get the point 2 about ISTA.
Thanks for above sharing information.
      04-15-2022, 05:34 AM   #546
Joe-BMW33
Joe-BMW33's Avatar
7338
2021 BMW X5  [0.00]
This might help.
      04-15-2022, 07:39 AM   #547
Disbealig
45
Drives: F90 M5, E39 M5
Shout out to Joe for your help and advice. Was able to get with Vick and he sorted out the couple of minor issues I was having. Everything is working as it should and I couldn't be happier.
      04-15-2022, 07:43 AM   #548
Joe-BMW33
Joe-BMW33's Avatar
7338
2021 BMW X5  [0.00]
Excellent, nothing like that feeling when you know everything is right.
      04-15-2022, 07:50 AM   #549
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
𝐑𝐌𝟓𝟖𝟎𝟎
𝗟𝗖𝗜 𝗧𝗮𝗶𝗹 𝗟𝗶𝗴𝗵𝘁
𝗣𝗹𝗮𝘀𝘁𝗶𝗰 𝗧𝗿𝗶𝗺 𝗖𝗼𝘃𝗲𝗿
Concept Playzone
Concept Playzone
Hello Joe,
Brand:
Model Year:
Specification:
Existing Mods:
Thank you.
You sent
2018 BMW G30 M550
Tue 10:02 AM
Concept Playzone
Concept Playzone
Original message:
Concept Playzone
You sent
Original message:
Concept Playzone
Original message:
Concept Playzone
Tue 10:50 AM
Concept Playzone
Concept Playzone
Concept Playzone
You sent
Thank you
Concept Playzone
Concept Playzone
Just buy oem and repin. It's stupid easy and cheaper. I paid less than $1000 from dealer. Unless you're buying euro lights
'06 C55 AMG (sold)
      04-15-2022, 08:01 AM   #550
Joe-BMW33
Joe-BMW33's Avatar
7338
2021 BMW X5  [0.00]
Agreed, I was just curious what this seller was actually offering so I hit them with some Q&A, which I still don't really have any answers. I was intrigued by the wiring harness comment as were others and wondered if someone developed a harness that avoided re-pinning and coding for LCI's. Neither seem to be the case.
