BMW M5 F90 (2018+) General Forums Cosmetic Modifications    DIY: F90 / G30 LCI Tail Lights Retrofit
      11-09-2021, 03:26 PM   #375
Joe-BMW33
Joe-BMW33's Avatar
7338
Drives: '18 M550i|'21 X5|'03 540i
2013 VW Tiguan  [0.00]
2015 Infiniti QX60  [0.00]
2021 BMW X5  [0.00]
2003 BMW 540i  [0.00]
2018 BMW M550  [10.00]
Originally Posted by take0524 View Post
Originally Posted by Joe-BMW33 View Post
If you have a rear fog wire you can use it as the 5th wire needed for the Euro tails. Yes, this will be moved to pin 4, but you also have to move it at the BDC.
This is all detailed in the last 4 pages or so of this thread, including colors of wires and where to move it to at the BDC.
Thank you very much.
Where can I find this?
Honestly, if I have to go back in this thread and look for my post on the BDC assignments, so can you. Not trying to be flip, but it's the same level of effort. I don't have this thread memorized page by page. It's where I discovered using the fogs as the 5th wire.
2018 M550ix|Carbon Black|Dinan Modifications|2003 540i|Jet Black|M-Sport|2021 X5 Mineral White
Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|2002 745li|2007 750li|2006 750li|2001 530i|2012 535xi|
      11-09-2021, 05:08 PM   #376
take0524
Drives: BMW
Thank you!
I'll start looking from the beginning.
      11-09-2021, 05:51 PM   #377
Joe-BMW33
Joe-BMW33's Avatar
7338
2021 BMW X5  [0.00]
Thank you!
It definitely can't hurt to go to the beginning, but what your looking for is no more than 10 pages back from the end.
      11-09-2021, 08:54 PM   #378
take0524
Drives: BMW
I've done a lot of research and put it together in my own way.
I think this is the easiest way to make a jumper.
david51537.50
      11-10-2021, 12:50 AM   #379
Joe-BMW33
Joe-BMW33's Avatar
7338
2021 BMW X5  [0.00]
Very nice illustration. Yes, pin 4 inner to pin 1 splice outer. Are you sure on pin 1 outer? Shouldn't that be labeled "brake light"? Also, what's the difference between turn indicator and direction indicator?
      11-10-2021, 01:37 PM   #380
take0524
Drives: BMW
Hello.
I don't have a wiring diagram for LCI, so I can't be sure.
I'll do some more research.
Thanks!
      11-10-2021, 02:12 PM   #381
Joe-BMW33
Joe-BMW33's Avatar
7338
2021 BMW X5  [0.00]
Hello.
Thanks!
Ahhh, I see what you did. The key is assigning the correct labels to the LCI pin locations after coding, they do different things than the pre LCI locations.
      11-10-2021, 11:21 PM   #382
take0524
Drives: BMW
I'm getting a little confused.
Can anyone tell me the signal name of the LCI tail lamp body?
pin of the LCI tail lamp body?
      11-11-2021, 07:08 AM   #383
Villy
Romania
13
Drives: BMW M5 F90 Competition
Sub. Just ordered mine and will install once I have the parts next week!
I'm in Europe, purchased a 2018 BMW M5 Comp from Germany, surprise when I registered the call it was an US model, so I ordered EU spec Tailights of course.
Will post back with pictures after I have everything done.
Thank you euro, gtatx, joe and others for putting all this information together. Much appreciated and is what made me decide to go with the retrofit!
Joe-BMW337337.50
      11-11-2021, 10:57 AM   #384
Joe-BMW33
Joe-BMW33's Avatar
7338
2021 BMW X5  [0.00]
Nice! Good luck!
      11-11-2021, 03:30 PM   #385
Evil Derboy
Evil Derboy's Avatar
271
Drives: E92 M3
Your diagram above is correct.
Appreciate 2
      11-11-2021, 03:55 PM   #386
Ptoscano911
Drives: F90 M5
It would be great for someone to make a pigtail Y adaptor for the euro to make it nice and clean when you jump.
      11-11-2021, 04:20 PM   #387
Joe-BMW33
Joe-BMW33's Avatar
7338
2021 BMW X5  [0.00]
I'm curious if anyone tried a T-Splice and just tapped in. That would be pretty clean.
      11-11-2021, 06:13 PM   #388
Evil Derboy
271
Drives: E92 M3
There’s a seller on eBay in the UK that makes a female/male wiring adaptor that piggy backs the outers on the outer so the F8x. The exact same one will work for the F90 with potentially a few changes on the pins.
      11-11-2021, 08:39 PM   #389
Jakerx
Jakerx's Avatar
701
Drives: F90 Comp
I t-tapped the outer light pin 1 and ran a sheathed wire along the car’s existing wiring to the inner light pin 4.
Appreciate 2
      11-12-2021, 03:30 AM   #390
take0524
Drives: BMW
Hello.
That was good!
I'm in the process of ordering the parts and look forward to installing them!
Joe-BMW337337.50
      11-12-2021, 03:33 AM   #391
take0524
Drives: BMW
Hello.
Did it work correctly?
      11-12-2021, 04:54 AM   #392
Joe-BMW33
Joe-BMW33's Avatar
7338
2021 BMW X5  [0.00]
Hello.
Don't want to answer for Jaker, but I'd have to assume with the correct high quality and correct gauge T-Spicers, it should work perfectly and be clean. Plus, no need for molesting the pin 1 outer wire, just tap in. Should be the same result as stripping, twisting, taping, etc. I ran from the BDC, but if I jumped, I would definitely just tap in.
      11-12-2021, 10:16 AM   #393
Evil Derboy
271
Drives: E92 M3
Same here. I decided to run to BDC but if I did it again I’d do exactly as you describe above. Which is the way it’s on the F series LCI tail light retro fit as well.
      11-12-2021, 11:07 AM   #394
Jakerx
Jakerx's Avatar
701
Drives: F90 Comp
Hello.
Yep, it works great. Vick coded my car last night and I have 100% functionality.
For those of you not comfortable with tinkering on vehicles or don't have much experience, just ensure you're using the right t-taps for the right gauge wire.
Joe-BMW337337.50
      11-12-2021, 11:51 AM   #395
Joe-BMW33
Joe-BMW33's Avatar
7338
2021 BMW X5  [0.00]
Curious, did you have the fog wire?
      11-12-2021, 11:53 AM   #396
Jakerx
Jakerx's Avatar
701
Drives: F90 Comp
I did not have the fog wire. Mine's a 2020 USA-spec M5. I thought MAYBE I'd have the fog wire since I took delivery in Germany, but no such luck.
