2010 2011 BMW 5 Series Forum F10 F11 instrument cluster problem |
04-15-2024, 02:18 PM | #1 |
Rep 3
Hello guys, this is my first thread here so sorry for anything.
My instrument cluster keeps turning white at night for like 5 seconds and goes back to orange, my first guess is the sensor but where is it located? spent all day searching about this issue but can't find anyone with this problem. The headlights apparently does not affect the instrument cluster, it's another sensor. It's a BMW F11 2013 Thanks for any help |
04-16-2024, 08:12 AM | #2 |
4528
Rep 7,584
The phototransistor that determines night/day mode is somewhere built into the instrument cluster.
There can be 3 different types of instrument clusters...but the phototransistor is probably located in the same place for all 3:
You can see 2 of the different clusters below...the 6WA (which has a digital display that goes all the way across the bottom section of the cluster and the anodized rings are open on the bottom (similar to a horseshoe) when the cluster is off. The basic cluster has 4 anodized rings that are full circle, and you can still see the gauge graphics when the car is turned off.
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
04-16-2024, 09:16 AM | #3 |
Rep 3
Thank you so much for replying, my guess is the sensor is that small circle in the middle of the dashboard, it has no light so it can be the sensor. Do you know if it has a fix? or do I need to buy a new dashboard? It is not cheap.
I have the 6WA Thank you again for helping me! |
04-17-2024, 07:03 PM | #4 |
4528
Rep 7,584
Unfortunately I do not know of a fix.
04-19-2024, 12:16 PM | #5 |
Rep 3
Ok I tested the sensor and it is what I said, with a flashlight pointing the sensor it changes from orange to white, I also cleaned the dashboard and to this day it didn’t happen again. Thank youuu!
04-22-2024, 09:22 AM | #6 |
4528
Rep 7,584
Great! Glad to hear that you got things working.
