2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum F10 N63 which motor oil
      11-20-2017, 04:00 PM   #1
535_BiTurbo
Drives: 2012 550I - BMS Stg 1 & CAI
Which motor oil to run.....Mobil 1 0w40 or Castrol 5w30?
      11-20-2017, 04:12 PM   #2
spyroz
spyroz's Avatar
Drives: BMW f10 550i ///M Sport
https://www.facebook.com/photo.php?f...&theater&ifg=1
Here's a tip for your N63 motor oil.
BMW f10 550i Msport
      11-20-2017, 05:07 PM   #3
Simple5
354
Drives: F90 M5 and E84 X1 Xdrive35i
Anything that is LL-01 approved by BMW. My local Wal-Mart stocks Pennzoil Euro Formula and also Castrol Euro Formula both LL-01 approved.
      11-21-2017, 03:08 PM   #4
535_BiTurbo
I ended up going with the Pennzoil Euro Formula 5w30. What's crazy is for last 3 years, I've been using the Castrol Edge Extended Performance 5w30 and once I used Castrol GTX Magnatec 5w30.
      11-24-2017, 03:01 PM   #5
spyroz
spyroz's Avatar
you need to step up on your oil man, because N63 motor produce so much heat..
BMW f10 550i Msport
      11-24-2017, 07:19 PM   #6
Bossman535
13
Drives: Alpine white
Which would you recommend ?
      11-24-2017, 07:48 PM   #7
daniel_f10
daniel_f10's Avatar
Drives: BMW 550i
Liqui Moly 5w 30
      11-25-2017, 01:40 AM   #8
spyroz
spyroz's Avatar
Originally Posted by daniel_f10 View Post
Liqui Moly 5w 30
I did 5w40 Liqui Moly Tech
BMW f10 550i Msport
      11-26-2017, 02:01 AM   #9
Simple5
354
If Ferarri uses Pennzoil in their engines I think it's good enough for a n63.
      11-27-2017, 11:18 AM   #10
535_BiTurbo
good point
      05-07-2024, 01:42 AM   #11
hasanalothman
Saudi Arabia
Drives: bmw 650i 2014
oil change fix
in N63tu manual
the oil recommendation BMW Longlife-01 FE & BMW Longlife-01 is low SAPS type of oil i did my search what is it and unfortunately the low saps is low in additives to protect the engine to protect the cataylic converters!!!!!.
first: the solution should be by putting a higher flow catts that end the need to put low quality oil " low SAPS".
second: what is the viscosity should we put? the owner manual state that you can put "belongs to one of the viscosity grades SAE 0W-40, SAE 0W-30, SAE 5W-40, and SAE 5W-30 or malfunctions or engine damage may occur.
if this the case the oil cannot be chosen above or below what the recommend due to main bearing clearance and rod bearing clearance, you need to have the oil lubricating these parts!
the only issue that i did understand that the German manufacturer did is to pass fuel emission with these type of catts that we all need to remove.
i wish that what i said is correct and will not do any harm to anyone.
what i done is 0w40 amsoil SS and high flow catt 200 cel to deal with the issue of not putting high quality oil.
alert if you choose to change the oil without the replacment of the catt it can clog the catts which can cause a problem that you dont need.
      05-09-2024, 02:57 AM   #12
Hornet-01
Hornet-01's Avatar
Russia
164
Drives: BMW 550 xdrive
2011 550ix  [9.50]
redline or bardahl 0w40
5post
