09-03-2023, 12:22 PM | #45 | |
Rep 28
09-03-2023, 12:36 PM | #46 |
Rep 28
So the weather is beginning to somewhat normalize here. The car feels a bit better but not as strong as I’m expecting. My convertible M6 Comp seemed to have less lag and more immediate push than my non-comp ‘18 M5. Larger turbos and AWD causing this sensation?
Here’s a data log from when I gunned it at 5mph off a toll booth in 90ish degree weather with humidity. https://bootmod3.net/log?id=64ecf427c090c6c83dae53ac The draggy time is my second attempt at doing a 0-60 with just brake boost, no LC. I did upshift early at a little past 6k during 1-2. 60ft. was 1.80. I changed plugs and air filters as those were due at my mileage (40k). |
09-04-2023, 05:39 PM | #47 |
Rep 28
Any input? For the log, two things that concerned me was the boost pre throttle and timing corrections. The boost seems to miss the target at around 1-3 psi, but the wgdc seems normal so a boost leak is out of the question? The car does pull timing by 3 degrees at WOT across the board and there was one knock detected.
09-06-2023, 07:57 AM | #49 | |
114
Rep 282
It's hot and your octane rating isn't keeping up. But I think it's normal for this car especially if you are running stock boost Edit: Just noticed you are not running stock boost. Might want to retard the timing slightly in your tune. |
09-06-2023, 01:31 PM | #50 | |
Rep 28
09-08-2023, 10:13 AM | #51 |
203
Rep 212
Interestingly I just upgraded from a G80 M3 and maybe because it has been really warm recently, my G80 felt like it pulled much harder. I need to get a dragy to confirm but I was a little underwhelmed. I thought there might be a noticeable difference, but maybe the G80 was that underrated as it has been discussed.
01-15-2024, 02:01 PM | #52 |
150
Rep 141
01-15-2024, 02:02 PM | #53 | |
150
Rep 141
01-16-2024, 04:47 PM | #54 |
114
Rep 282
01-16-2024, 07:06 PM | #55 |
150
Rep 141
01-16-2024, 07:48 PM | #56 |
5266
Rep 10,653
I installed the 90C thermostat and selected the added cooling option in BM3 or JB4 or XHP, I forget which, that reduces the coolant temp, at least in sport plus mode, I am guessing by changing the electronic thermostat setting and running the fans more. I also run water/meth injection to help make 95F days more like 75F days.
01-18-2024, 09:06 AM | #57 |
114
Rep 282
01-18-2024, 12:37 PM | #58 |
150
Rep 141
