09-16-2022, 05:56 AM | #89 |
2274
Rep 3,300
Update, checked my dad's car. The cap on the reservoir was CROSS THREADED and that is where the leak is. Prior service they cross threaded it, next service saw evidence of leak, topped off and CROSS THREADED CAP AGAIN.
Ya, love dealer "Service." Mike
09-16-2022, 06:47 AM | #90 |
983
Rep 1,799
I believe the same thing happened when I took my car for the oil change. Since I follow this forum I check my coolant periodically and noticed the cap was extremely difficult to remove. It does not appear the threads were deformed as after I finally removed it I have been able to remove and replace. It is one of those things I will probably tell them not to do at future service as I do not want to deal with them damaging it and not accepting responsibility. Fortunately I have no signs of a leak.
09-16-2022, 08:30 AM | #91 | |
Perennial PFC
338
Rep 1,275
As with yours there was no deformity of the threads, so no cross threading had been done. I believe the coolant mixture acts as a bonding agent on the threads and causes the turning difficulty. Perhaps the hot environment pushes a vapor up into the threads, coating them? The rubber o rings also add resistance, but it can’t be much. No leaks in my system that I can see, but I’ve had to top up with 4 to 6 ounces of fluid a couple of times over the last 3 years. |
OCDoningtonF9039.00 |
09-21-2022, 06:18 PM | #92 |
5260
Rep 10,638
If anyone wants my old tank to give to a fabricator to attempt to duplicate in aluminum or steel, let me know. Otherwise I will be tossing it soon. I have done enough heat reduction and shielding that I don’t have any concerns.
For those that do, the cost of the custom tank would be 2 or 3 times that of a new plastic one so a DIYer who stays on top of maintenance and checks regularly under the hood should be fine with periodically replacing the plastic one. It’s those who don’t look under the hood and/or don’t work on cars that could reduce the risk of failure (and potentially much greater damage) or save tank replacement money long term. |
09-22-2022, 03:01 PM | #93 |
2274
Rep 3,300
[QUOTE=pbonsalb;29357386
For those that do, the cost of the custom tank would be 2 or 3 times that of a new plastic one so a DIYer who stays on top of maintenance and checks regularly under the hood should be fine with periodically replacing the plastic one. It’s those who don’t look under the hood and/or don’t work on cars that could reduce the risk of failure (and potentially much greater damage) or save tank replacement money long term.[/QUOTE] since new BMW tanks are not available, that price (2 or 3 times) sounds ok to me...LOL.... Mike
09-22-2022, 03:26 PM | #94 |
5260
Rep 10,638
I did not know new tanks are not available. I bought one a few months ago. I am sure they will be available again if they are out of stock.
09-22-2022, 04:44 PM | #95 | |
2274
Rep 3,300
Mike (My tank is fine but for a couple hundred bucks I'd rather have one in the garage ready to swap out......)
09-22-2022, 04:48 PM | #96 | ||
983
Rep 1,799
09-22-2022, 06:42 PM | #98 |
2274
Rep 3,300
LMAO....DOUBT IT......all bought up because of leaks and those who know about risk of leaks. The tank is $130, not a big expense. The damage is thousands when it leaks. Then you get in line to buy all the other parts...........stupid supply chain....stupid COVID........
Mike
Maverik2594144.50 |
09-23-2022, 08:14 AM | #99 |
Rep 37
I checked my levels in both tanks and levels were OK, threads on both tanks were corroded, lubed with wd40 silicone to ease future checks. What tank is leaking or do both leak when problems arise? How difficult is it to replace leaking tank? Probably have to remove fluids before replacing, thinking of ordering new tank for potential problems.
09-23-2022, 08:24 AM | #100 | |
4145
Rep 7,160
Drives: F90 M5 / F15 50i
'07 Yamaha R1 (sold)
09-23-2022, 08:48 AM | #101 |
5260
Rep 10,638
I’d put a towel underneath and tilt the tank up a bit so the bottom port won’t drain out onto the heat shield and down onto the injectors and coils. I was not able to siphon every bit of coolant out of the tank and some remained. What is in the lower hose will drain also and you should not clamp too close to the plastic end. A silicon cork works also.
09-23-2022, 09:55 AM | #103 |
2274
Rep 3,300
Here you go.....
If you can figure out why they want you to remove the ECU connections let me know....LOL...looks like you can do it without all these steps. Mike
09-23-2022, 11:06 AM | #106 |
983
Rep 1,799
Disconnection of the battery is usually suggested during auto repair. The disconnecting and connecting of connectors could result in damage to the components if they are powered at the time of connection.
09-23-2022, 11:17 AM | #107 |
5260
Rep 10,638
You might get a cel for the disconnected sensor if you have not made sure the car is asleep. It does not hurt to disconnect the battery but I usually don’t except sometimes when welding and have never had any issues.
09-23-2022, 11:48 AM | #108 |
Rep 37
How do you inspect the tank, it is so crammed in I cannot inspect the seams. do I wait until tank starts loosing a little fluid? Do you have to remove to inspect,pita.
09-23-2022, 12:51 PM | #109 |
5260
Rep 10,638
Undo the 2 bolts, loosen hoses from their retainers, and lift it up a bit and look around it with a bright light. It will probably look fine. I don’t think anyone has posted pictures of a cracked tank yet. Some may just be failing at the cap and leaking.
M5Neededi94.00 |
09-23-2022, 12:57 PM | #110 |
94
Rep 74
Drives: 2019 M5, Ram 1500
Yeah I wonder if the culprit has sometimes been misidentified as cracked tank as opposed to cross-threaded cap?
