BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    1/4mi 60-130 Dragy Tips and Tricks
      09-22-2021, 10:00 AM   #1
DrivenAgain
MFJWADE
120
Drives: 2018 BMW M5
I wanted to start a new thread where we can share all of our tips and tricks that we are using to make our cars quicker and faster. From launch techniques to shift settings lets use the thread to assist each other in getting the best times and achieving our performance goals.
I follow a few of you guys on Dragy which is an excellent resource for comparative data.
Dragy Name: MON5TER
Best 60-130 6.71 DA216FT
2018 M5 JB4-Custom Map 6-Project Gamma intake-resonator removed for custom X pipe-E40
How are you all achieving your best 60-130? What settings? I use 4WD Sport, start in 3rd gear at 3k rpm then nail it, its give the turbos full boost as the MPH passes 60mph.
2018 M5 Singapore Grey CCBs/Utku Noa E45 ECU/xHP TCU/PG-Intake/PG-Lower Downpipes
      09-22-2021, 11:38 AM   #2
brad65ford
256
Drives: 2022 M3
What will be interesting is if the lc function shifts the best for 60-130 vs manual. This has been a discussion for some time now.
      09-22-2021, 06:14 PM   #3
DrivenAgain
MFJWADE
120
Drives: 2018 BMW M5
All of my quickest times have been on a deliberate 60-130 run, not within a 1/4 run whereby I was using LC
      09-22-2021, 10:00 PM   #4
AngryInch
213
Drives: 2021 BMW M5 Comp
1/4 mile runs in low ambient temps, LC flags come on, let off the brake quick, it seems to build boost through 1st gear better instead of blowing all 4 tires off. Ive been cutting 1.59 like this, with the heavy stock wheels.
Also, probably the most important thing Ive learned recently. Do 3 runs when testing, check log, make sure its good, do a cool down (lower IAT) and hammer out another run. A lot of the time, my timing comes up and the 3rd run is the fastest.
      09-22-2021, 10:47 PM   #5
PaLaKaT
71
Drives: 2022 X6M
Interesting, mine is exact opposite, i had my best run on my first pull. Best time: 6.66
Everything in sports plus, and letting the car shift it self with LC.
      09-23-2021, 07:36 AM   #6
DrivenAgain
MFJWADE
120
Drives: 2018 BMW M5
6.66 60-130 is super fast!! What are your mods?
      09-23-2021, 07:53 AM   #7
PaLaKaT
71
Drives: 2022 X6M
xHp Stage 3 TCU, Catless DPs, bootmod3, KN Drop ins, and removed Carbon filters. Car pulls well at the top, but my issue is down bottom 😂.
Everyone seems to get 2.7-2.8s from the LC mine doesnt want to get under 3s. 🤦
      09-23-2021, 08:38 AM   #8
AngryInch
213
You’re probably over the 100 LC limit. Try brake boosting it manually maybe? Mines the opposite… LC’s hard (for now) then 5th gear, timing could be better…
      09-23-2021, 09:37 AM   #9
DrivenAgain
MFJWADE
120
Drives: 2018 BMW M5
xHp Stage 3 TCU, Catless DPs, bootmod3, KN Drop ins, and removed Carbon filters. Car pools well at the top, but my issue is down bottom 😂.
If it makes you feel any better I'm in same position. All of my short times suck. Everyone gets 1.5x-1.6x 60ft and i average 1.7x My 0-60 averages 3.2😯 But in good air I can trap 135mph so No complaints. I still have stock downpipes.
      09-23-2021, 09:53 AM   #10
PaLaKaT
71
Drives: 2022 X6M
Its moving for stock downpipes! But yea its past the 100 launches. I actually switched my tune back to stock till i replace my Spark Plugs. I did a launch control on stock ended up with 4.1 secs. Then 5 minutes later i put the car in Drive brake boosted and it did 3.4secs.
      09-23-2021, 01:56 PM   #11
brad65ford
256
Drives: 2022 M3
So I'm guessing that pretty much answers the whole "does xHP tcu tune remove the 100 launch cap". Shame
      09-23-2021, 06:55 PM   #12
DrivenAgain
MFJWADE
120
Drives: 2018 BMW M5
Best 60ft launch technique?
Does anyone air down their tires a bit or keep "stock" pressures?
I have a mix of 100/E85, it should be close to ambient late tonight so I'm going to try to get a decent 1/4 run in.
      09-23-2021, 06:59 PM   #13
brad65ford
256
Drives: 2022 M3
only if you need to but some times airing down just doesn't work. Fortunately we have the ability to heat up the tires if need be. Lately I've been airing down to get best ride and I notice i keep going lower. 32 all around right now cold. Bet 28 psi would be fine for the rears. Not sure if xhp has the ability to change launch control rpm but i know there is a way to remove torque limiters when launching. Have a feeling we can do some sick times if we had slicks/drag radials and half shaft upgrades with editing the software.
      09-24-2021, 11:49 AM   #14
eric97hoh
Drives: 2020 bmw m5
how much does it cost for full tank on 100 and e85 mix
2020 BMW m5 with some bmc filters, charcoal filter delete, and Dinan turbo inlets.
Previous BMW model 2018 bmw 340i FBO custom e50 tune 500 wheel
      09-24-2021, 11:54 AM   #15
DrivenAgain
MFJWADE
120
Drives: 2018 BMW M5
Lol too much😂 $150++ but I didn't do a full tank. It also did not net me any faster times. 😖
6.70 60-130 DA76ft
      09-24-2021, 01:21 PM   #16
eric97hoh
Drives: 2020 bmw m5
6.70 60-130 DA76ft
two questions how are you calculating that da and why don't you wanna try a flash tune?
      09-24-2021, 01:28 PM   #17
DrivenAgain
MFJWADE
120
Drives: 2018 BMW M5
6.70 60-130 DA76ft
Dragy calculates the DA.
No flash tune because of warranty issues.
      09-24-2021, 01:48 PM   #18
eric97hoh
Drives: 2020 bmw m5
holy fuck 54 temp and 200 ft above sea level I need that
      09-24-2021, 01:51 PM   #19
DrivenAgain
MFJWADE
120
Drives: 2018 BMW M5
Lol i run in all DA so I know how my car will respond. Been runnin in 2200-1500 all summer but it's staring to cool off late night. Def had some good conditions last night was trapping 134-135 but it wouldn't hook for shit.
      09-24-2021, 01:57 PM   #20
eric97hoh
Drives: 2020 bmw m5
ya that true when its really cold out it gets hard to hook, I cant wait until I'm on bm3 e30 with my turbo inlets and charcoal delete
      09-24-2021, 01:58 PM   #21
DrivenAgain
MFJWADE
120
Drives: 2018 BMW M5
What's your current setup and times?
      09-24-2021, 02:02 PM   #22
eric97hoh
Drives: 2020 bmw m5
2020 m5 just removed the charcoal filters and put in bmc filters I ordered dinan tubro inlets should be here next week. I'm on 91 octane so its bad I mix a e85 gallon or two I haven't ran a draggy time but I'm about to next week when I install the inlets. and at least my cars a bit lighter cuz I got cabron ceramics but I got sunroof no carbon roof
Appreciate 2
