BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    2021 m5 jb4
      04-01-2021, 08:57 PM   #23
boost4breakfast
Drives: 992 GT3 24 M4C 21 M5C (gone)
installed the jb4 with all the connections. adding the jb4 gave me heated cup warmers lol. car pulls hard on map3 with snake oil. anyone else have heat soak issues? even the purel in my center console storage was warm lol
      04-02-2021, 01:16 PM   #24
Quinn A
122
Drives: 2016 M3
Car runs super hot even without JB4.
Ive never had a car where the oil is 250F while cruising
2020 M8 SMB full boltons and tune
2022 CT5-V Blackwing
2019 GT3RS full headers exhaust and tune
2022 Cayenne Turbo coupe Catless/ Tune
2022 Huracan STO
      04-02-2021, 03:30 PM   #25
boost4breakfast
topping off the coolant every 3k miles helps. heard that meth lowers IAT tremendously as well
      04-02-2021, 07:24 PM   #26
Dethsupp0rt
329
Drives: N/A
You clearly never had a E90 335i then.
DrewBert151.50
      08-15-2021, 12:05 AM   #27
AngryInch
213
Drives: 2021 BMW M5 Comp
I installed the JB4 on a 21 Comp. I have the EWG installed and get a drivetrain malfunction under part load boost in map2 and right away in map 3. 94oct fuel with a can of boostane in it.
What is the stock boost of this 21 comp? I logged a 3rd gear pull, boost went up to 25, 26 and even 27. Timing seems to drop down quite a bit to around 5-7 degrees on ign1. Avg Ign is around 13 or so... Are we watching the cylinder ign or average??
AFR 14.2-14.7 under the pull. AFR hits 13 then leans out to mid 14s.
Seems like it was adding ~5psi of boost vs the ecu psi... IAT was 105-106f.
      05-06-2023, 04:44 PM   #28
RS61
80
Drives: Audi RS6
How is everyone else with a 2021 jb4 setup currently doing? I've got a 2021 comp with a JB4 without the EWG connectors and haven't so far felt any difference. I haven't installed the EWGs because (1) it's harder to do yourself, (2) a few years ago that would lead to faults being thrown, and (3) a racechip supposedly works just fine with the standard two wires so logically a JB4 should too.
Has anyone done any dynos with this setup - 2021+ comp and jb4 to compare with stock? Or any other data to show how it runs (interested in both without ewg and with ewg as if that makes a difference I'll take it to the shop to get them plugged in)
