11-01-2022, 04:17 PM | #155 |
988
Rep 1,806
I have fewer miles and have added antifreeze two or three times in a year and a half ownership. Less that 16 ounces total. No signs of a leak but both tanks were low. I check it regularly based on what I have learned here. I really do not understand where the coolant is escaping to though.
11-01-2022, 04:52 PM | #156 |
33
Rep 85
Drives: F90 M5 Competition 2019
One more leaking expansion tank
I just got my 2019 M5 Comp (22k miles) 3 weeks ago and noticed the white residue on the expansion tank. It does seem like it leaked down a bit, but it doesn't seem to have damaged any components. But it is leaking and see the picture, quite a bit.
I sent the picture to my SA and he said to bring it right in. I did and left it with him and he ran over to parts to get a new tank. Under warranty and if they have one in stock he said the car should be ready in a day. I will update when I hear more. |
11-01-2022, 05:04 PM | #157 |
87
Rep 99
Woke up last week to my 19 Comp saying "Low Coolant". Brought it in for a top off and they saw all the residue and said the tank had a crack in it. Car was supposed to be completed today and just got a message from my service advisor saying "Tank is replaced but now the car is misfiring from all cylinders. We are going to need to replace the injectors and coils. Will be done in 2 days". So we will see what happens.
11-01-2022, 10:46 PM | #159 |
4148
Rep 7,164
Drives: F90 M5 / F15 50i
'07 Yamaha R1 (sold)
11-02-2022, 10:32 AM | #160 |
50
Rep 72
11-02-2022, 12:17 PM | #161 |
IG: @M5RCY_
365
Rep 318
Im already on my 2nd tank as well. hope your next tank lasts longer!
Autotecknic.com - code: M5RCY for 12% off
Project Gamma - code: M5RCY for 5% off Dura-Coating - code: M5RCY for 20% off |
11-02-2022, 02:50 PM | #162 |
988
Rep 1,806
11-02-2022, 04:45 PM | #163 |
IG: @M5RCY_
365
Rep 318
It was replaced at about 32k. There was a coolant leak, you could visibly see the dried up coolant in the engine bay on the driver side under the tank. Even leaked on to my coils and all driver side coils were replaced. All under warranty
11-03-2022, 08:01 PM | #165 |
988
Rep 1,806
11-03-2022, 08:13 PM | #166 |
Rep 24
I picked up mine with 27k on it and had 2 weeks before the car lost half the motor. I was told that the injector holes where filled with coolant and the plugs where done too. They told me because the bmw deal that did the work before me didn't do it right and let coolant into the injector ports but they where also in there doing injectors.
I took the panels off the drivers side and I can see dried coolant everywhere so Im guessing it was from the tank. Needless to say they changed all the injectors again all the plugs and 2 coils. He also told me that the other 2 coils are most likey going to fail at some point but they couldn't do all 4 at once per BMW. The car is now going back next week for starting then dying right away so I'm gonna have him check it out again and make sure theres nothing leaking. |
11-04-2022, 03:23 PM | #167 | ||
33
Rep 85
11-04-2022, 03:31 PM | #168 | |
1739
Rep 1,664
My car has been in twice now with 13,800 miles on the clock. I still smell coolant every time I pull into the garage and shut her down. Never see anything on the garage floor. I've had 2 low coolant messages on I drive. All these aholes do at the dealership is "pressure test" the system and say its good to go. My SA tried telling me its normal for V8's to burn up coolant. It's very frustrating and complete bullshit. Summer 2021 I was driving around and kept getting this TOXIC smell with windows down. Took it in and started explaining to the SA about the smell. He immediately goes, oh yea, theres a TSB on that for burnt coolant in the deep V section of the motor. What the F ??? Anyway they cleaned it up and smell was gone.
2020 M550 / Dark Graphite / Napa Saddle Brown / DHP Pkg / Exec Pkg / Luxury Pkg / Parking Asst Pkg
11-04-2022, 04:37 PM | #169 | ||
4148
Rep 3,700
Drives: 2022 M5C
If someone tells me this one more time…
Not a BMW guy...but certainly an M5 guy.
11-04-2022, 07:35 PM | #170 | |||
4148
Rep 7,164
ResIpsaLoquitur4148.00 |
11-05-2022, 06:33 AM | #172 |
5275
Rep 10,674
That one is lean on top around the cap. Was it leaking around the horizontal seam of the top and bottom halves? Heat from the cat wound be greatest on the inside (towards middle of engine) where the white dust shows.
11-05-2022, 10:27 AM | #173 |
988
Rep 1,806
How do you disconnect the tank sensor? Do you need a tool?
11-05-2022, 12:00 PM | #174 | |
33
Rep 85
CUSTOMER STATES COOLANT LIGHT COMING ON -Checked and found coolant level is low -Found there is evidence of leaked coolant under the reservoir -Referred to SI B17 02 22 -Removed engine fan cowl to gain access to and remove the lower radiator hose to flush coolant - Removed the coolant expansion tank for inspection -Found there is an excessive amount of coolant build up on the injectors on cylinders 7 and 8 - Replaced injectors for cylinders 7 and 8 due to coolant contamination - Cleaned area extensively, there is a significant amount of coolant residue in the engine bay -Cleaned the ignition coils and removed spark plugs for inspection -Spark plugs and coils are OK and do not require replacement - Re assembled vehicle, replaced coolant reservoir and filled and bled system -During replacement of the reservoir, the vent line from the reservoir to the radiator was damaged. Removed driver side airbox and replaced vent line Qty Part Number Description Unit Total 1 BM17-13-7-889-450 EXPANSION TANK WARRANTY 1 BM17-12-7-856-736 VENTILATION LINE, R WARRANTY 1 BM13-64-7-852-362 INJECTOR WARRANTY 1 BM83-19-2-446-564 BMW GROUP RUST OFF WARRANTY 1 BM83-19-2-468-442 BMW ANTIFREEZE/COOL WARRANTY 1 BM17-11-7-639-021 SCREW CAP FOR EXPAN WARRANTY TOTAL PARTS: 0.00 LABOR 0.00 PARTS 0.00 roCustomerInitials TOTAL 0.00 |
F30Andy1778.50 |
11-05-2022, 10:52 PM | #175 |
5275
Rep 10,674
11-06-2022, 10:08 AM | #176 |
553
Rep 547
I am contemplating changing both coolant tanks for preventative maintenance. I rather deal with just the coolant tanks then wait for them to leak onto the coils and injectors. It appears it will cost me $229.83 for both tanks before shipping and taxes. My 2018 M5 is a weekend driver only with just under 11k miles since I purchased it new in August of 2018. Has anybody changed the two aforementioned tanks out themselves? Any pointers?
