07-21-2020, 07:43 PM | #199 | ||
366
Rep 436
07-21-2020, 09:06 PM | #200 |
3322
Rep 8,083
07-23-2020, 09:45 AM | #201 | |||
12968
Rep 18,715
Done plenty of that setup.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
GranitM5366.00 |
07-26-2020, 08:43 AM | #203 |
12968
Rep 18,715
07-29-2020, 03:03 PM | #204 |
500
Rep 1,313
What happened to your side vent pieces for the front fenders?
E92 M3 Supplemental manual p.38: "The laws of physics cannot be repealed, even with DSC."
08-10-2021, 06:32 AM | #206 |
Rep 1
Wheel spacers don't fit my rims
I believe my rims are the 706m Bmw oem wheels, but I ordered 10mm macht schnell spacers and the hub is too big for my rim. How can I find out if the spacers I order will fit properly? Any advice appreciated
10-25-2021, 05:40 PM | #207 |
98
Rep 73
Ordered 15f & 11b. Once I tried them on, decided that it was a bit to aggressive for me. Stuck 11s up front and it seem like a good fit.
I also attached the way 11s looked at the back. Stock suspension |
10-31-2021, 01:34 PM | #208 |
775
Rep 569
Drives: 2019 M5 Competition
15/12 h&r
15F/12R
stock suspension (for now, installing KW HAS next week) '19 Comp |
Holset274.00 r33_RGSport12967.50 |
12-17-2021, 10:52 PM | #209 |
51
Rep 64
Silly queen here - looking to purchase some spacers and wondering if there are any recommendations on which brand to get? I'd assume they're all the same. I saw Dinan is selling them for much cheaper than other sites(h&r), roughly $250 for 2 sets and lug nuts. What's the recommendation?
12-18-2021, 01:09 PM | #210 |
5234
Rep 10,616
Dinan was cheaper but out of stock do I bought H&R. Here is one of the sizes and go can search other H&R PN. https://m.eeuroparts.com/Parts/52497...rak-3055664SW/
04-11-2022, 11:45 PM | #212 |
28
Rep 228
Trying to decide if I want to go 12 mm or 13mm front.. Anybody with stock height / tires on 789M wheels with 12 or 13 front and 11 rear?
It seems 11 will stick out a little bit at the back.. ideally I don't want any sticking out but H&R doesn't make 10s unfortunately.. |
04-27-2022, 09:30 AM | #214 |
5234
Rep 10,616
15mm rear is just 3mm more than the 12mm that some use without issue and 4mm more than the 11mm that most agree presents no problem. 1mm is .040 inches so even 4mm more is just 0.16 inches. Not much. My best guess is that you might hear a rub on compression over a large dip in the road at high speed with 4-5 people in the car and a trunk full of luggage. If its usually just you, there will likely not be a problem. Let us know in a few months how it works.
05-03-2022, 12:39 PM | #215 | ||
230
Rep 75
Appreciated I had like this for over a year now and haven't had issues with it. I was told that is very aggressive. I will update the post if something happens |
07-19-2022, 06:06 PM | #216 | |
551
Rep 638
do you have pics of the front with 15's? lowering CS (car has pzero's) and i need to figure out setup. Will be lowered with h&r 550i kit. |
08-06-2022, 06:34 PM | #217 |
Rep 13
I feel like my issue with spacers is the 5mm ones dont have the lip, so they dont sit as "flush" against the back of the wheel. Just had my rear tires replaces and the shop mentioned they had a hard time lining it back up in the rear. Thinking about just having the 12mm up front and taking the rear off unless I can find small ones for the rear that have the little lip.
2019 BMW M5 Competition
Singapore Grey, Black Merino Leather CCBs, Executive Package, Driver Package, B&W |
08-06-2022, 09:29 PM | #218 |
5234
Rep 10,616
Small ones dont have enough substance to support the lip. Supposedly 11 to 12mm in the minimum to have a lip. There are numerous reports of lips on 10mm spacers cracking. But there are hub extenders you can buy that take the place of the integrated lip and you use a flat spacer with those.
08-07-2022, 11:32 AM | #219 |
31
Rep 85
I started with 12mm front and 5mm rear and car had minor shake at 100mph or higher, i just went to 15mm front and 10mm rear and shake went away and gave the car a really nice stance, i wouldnt go any bigger in rear
Jeffrey jaquez
