BMW M5 F90 (2018+) General Forums F90 M5 General Forum    Second expansion tank incoming...
      10-19-2023, 09:00 PM   #45
pbonsalb
5234
$1000 but maybe initial group buy for less.
      10-20-2023, 07:45 AM   #46
AHall
982
Drives: 1993 Nissan 240sx
Is this real? I would prefer a tank with a replaceable level sensor especially if the tank price is sky high like that one. What are you to do if the sensor fails?
      10-20-2023, 08:11 AM   #47
pbonsalb
5234
I assume the sensor is replaceable and fits inside but don’t know for sure. I would not buy a $1000 tank with a nonreplaceable electrical part. This tank is still in prototype stage. I have no plans to buy one.
      10-21-2023, 07:26 PM   #48
Jambo1
Drives: 2022 M5C /// 2023 XDrive40i
  [0.00]
The purchase link is up:
https://www.rkautowerks.com/index.ph...5NfyijUTHeHyuo
Reventon Splitter /// Reventon Diffuser /// Addlights M Door LEDs /// Dinan Inlets /// Gentleman's Switch /// Paddleshifterz With Piano Black Steering Wheel Trim /// Charcoal Filter Delete /// Piano Black Side Skirts /// Funk Motorsports Turbo Blankets
GTTC55.00
      10-22-2023, 11:08 PM   #49
Jakerx
Jakerx's Avatar
701
Drives: F90 Comp
Website mentions it uses the stock sensor from the original tank. So it is replaceable.
Real and replaceable.
      10-23-2023, 12:30 AM   #50
anjuwaa
anjuwaa's Avatar
7
Drives: m850i
logicators Curious to find out how this works out. Thanks for sharing with the community. Belated congrats on your M5.
      10-23-2023, 08:49 AM   #51
AHall
982
Their website shows the following for the sensor.
Customer will have to re-use the stock coolant sensor probe, it pulls out of the OEM reservoir. In certain cases it does not slide out smooth and you may need to trim around sensor to remove it. Additional o-rings are provided in the situation a stock o-ring is damaged.
I have examined the OEM tank and sensor. I do not see how the sensor pulls out of the tank. It appears to be a part of the tank and cannot be pulled out. Then they say if it does not pull out you may need to trim around the sensor to remove it. How are we supposed to trim around the sensor as the plastic is very hard? Second how would this be installed in their tank and sealed?
      10-23-2023, 11:54 AM   #52
pbonsalb
5234
There is a picture of it pulled out. Apparently an o-ring seal. Must be pretty tight to hold up to 29 psi. When I changed tanks, I looked pretty closely and did not think the sensor cam out. I guess I did not look closely enough. The billet tank includes new o-rings for the re-used sensor. My guess is that you might have to break or cut the sensor and surrounding area out of the stock tank and then trim away material to free it.
At present I do not plan to buy one of these but maybe I will think about it more. I have considerably reduced heat but it is not certain heat causes the tanks to fail.
      10-26-2023, 07:45 AM   #53
jm490
519
Drives: 21' F90 M5c
So I looked under my hood today and theres like 2 drops of coolant on the tank coming down it like its slowly starting to leak. Mine got replaced once already about 5 months ago and 8000 miles - i drive alot
Brought it to the dealer they said they did a pressure test and that there is no leak. I dont understand how that could be the case.
      10-26-2023, 11:56 AM   #54
Holset
Sweden
274
Drives: F90 M5 Comp LCI
It may be the cap that is leaking they are often designed to release pressure over a certain point.
      11-01-2023, 11:40 PM   #55
isenc2
isenc2's Avatar
Drives: 340i xDrive Stage 1
Beautiful looking tank, however, it still looks like a two piece design, top and bottom. I wonder why that is.....
      11-03-2023, 06:21 AM   #56
fraschusa
fraschusa's Avatar
Drives: 2023 M5 Comp
Originally Posted by Greer View Post
I own a 2022 and have had no issues with the tank, is this only on pre- LCI M5's?
I was carefully watching it...10 months old, 16k miles, and mine was replaced earlier this week due to a leak... The BMW dealer was super nice and took it in the same day and fixed it. I'll keep watching, as there seem to be members who had several failures...
      11-04-2023, 05:45 AM   #57
The5rivers
314
Drives: 21 M5C, 22 X3MC, 24 X7 40i
I posted this in another thread as well…
2021 M5C, 13.7K miles. I had the "engine coolant level low" error message pop up after a cold start tonight for about 4 seconds that went away on its own. Temp outside was 34 degrees. I drove away and the error message didn't come back. Stopped and started a few more times while running errands and still nothing.
Checked the fluid level and it is low (below the min level). I made an appointment with my dealer on Monday to check for a leak and going to show them the TSB and probably just push to get it replaced under warranty.
      11-04-2023, 04:20 PM   #58
F90king
Drives: BMW M5
There is a billet coolant expansion tank in production
      11-06-2023, 12:53 PM   #59
trev230
trev230's Avatar
351
Drives: 2022 M5C
Welp of course now my 2022's coolant tank is leaking. I pulled the cap today.
Also, my wifes Merc GLE is leaking at the coolant tank so we ain't the only one fella's! lol
      11-06-2023, 11:30 PM   #60
TimmyBHGM5
41
Drives: BMW M5
7000miles already leaking
      11-07-2023, 10:54 AM   #61
CrashCade
112
Drives: '19 M5 Comp,
If this was a single piece how would you machine out the interior cavity? It is two piece with an O-ringed seal.
      11-07-2023, 11:04 AM   #62
homanmaster
95
Drives: 2013 BMW 335i F30
I recently bought the RK Autowerks Billet Coolant Reservoir tank in the intro pricing. I got a video made for the install with James Aka What’s Your Forte on YouTube.
https://youtu.be/Iy4KB8lq36Q?si=XVNlSZVAmCiPnVuT
      11-07-2023, 11:08 AM   #63
Pilatus
Drives: M5 C F90/M3 C F80/C5 TwinTurbo
One other option could have been to TIG weld but that would increase production cost and potentially require more QA. Time will tell how the O-ring holds up. Two-piece O-ring design is a good compromise and can be replaced if needed. O-rings are proven suitable even in high-pressure applications.
      11-07-2023, 01:23 PM   #64
isenc2
isenc2's Avatar
I guess my concern is that since BMW’s design is two piece jointed by top and bottom and it leaks thru the seam. It is a bit unnerving to see this new billet tank look the same way. However, I do believe in this product, and I’m sure it will work flawlessly. Really looking into getting one of those LCI F90 atm. Hopefully this addressed the coolant leak problem.
      11-14-2023, 03:14 PM   #65
swom5
Commander USNR Ret
15
Drives: M5, Cayenne S, Ariel Atom 4
Copied and pasted letter referenced above to bmw customer relations. Just purchased a 2019 M5 Comp. Coolant tank & injectors replaced ~12K miles, and documented in service records. After driving for two weeks coolant tank leaking at seam, 14K mi. Car under extended warranty until Apr 2024. Off to the dealer for another one. Remarkable that BMW will not / cannot solve this problem.
      11-14-2023, 04:07 PM   #66
AHall
982
So your tank replaced at 12k miles is leaking after 2k miles?
