04-26-2023, 08:15 PM | #67 |
2273
Rep 3,299
inside of Transfer case (I have video also).
From 328 but probably very similar to M5. Mike
05-01-2023, 11:39 AM | #68 |
36
Rep 151
Thank you ! When you get a chance if you don’t mind can u post a pic of the hook tube you used ? I need to get one like yours. A shop Is telling me 300 to do transfer case but screw that I have quick jacks the transfer case is exposed it’s easy if I get the right hook tube to get in there.. thank you for your help!
05-01-2023, 01:53 PM | #69 | |
2273
Rep 3,299
I used this and bent the tubing to the shape I needed. Worked great. SMOTIVEPRO Engine Oil Extractor Pump Brake Fluid Extraction Syringe Vacuum Filling and Extracting Pump Capacity 500CC https://a.co/d/ixjMHvm Mike
19M541.00 |
05-02-2023, 08:31 AM | #71 | |
36
Rep 151
05-02-2023, 04:50 PM | #72 | |
2273
Rep 3,299
Mike
05-02-2023, 04:51 PM | #73 | |
2273
Rep 3,299
Mike
05-14-2023, 02:01 PM | #74 |
69
Rep 92
Did you have anything supporting the trans when you removed the support per the BMW manual? Not sure if anything will fall on me once I remove the support
05-14-2023, 03:15 PM | #75 | |
2273
Rep 3,299
Car was on QUickJack. Mike
08-12-2023, 07:01 PM | #76 | |
41
Rep 52
2019 BMW M5
2016 Dodge Charger HC 2005 E55 AMG Wagon |
08-12-2023, 08:16 PM | #77 |
292
Rep 605
Then you overfilled it by an entire liter. The instructions specifically say that if you fill to the edge of the fill plug, the rear differential will be overfilled.
08-12-2023, 08:23 PM | #78 |
5234
Rep 10,616
08-12-2023, 11:56 PM | #79 | |
41
Rep 52
Nope. 2 liters came out of the rear axle; and I put 2 liters in. I personally drained it and personally put in the 2 liters.
2019 BMW M5
08-12-2023, 11:57 PM | #80 |
41
Rep 52
That could have been.
2019 BMW M5
08-13-2023, 10:41 AM | #81 |
5234
Rep 10,616
Most likely if you put back what you took out, tge jevel hs fine—unless someone else overfilled it previously. I did not put a camera in there to see what the level is before the fill port. I tend to think it would not hold an extra liter but have not verified that.
08-17-2023, 07:48 PM | #82 |
292
Rep 605
You might want to check the volume on those bottles. If you actually got 2 liters out of the rear diff, it was overfilled. You can always call your dealership parts department and ask for rear diff fluid capacity to confirm.
08-18-2023, 09:53 AM | #83 |
1540
Rep 2,008
08-18-2023, 10:12 AM | #84 | |
2273
Rep 3,299
Mike
08-18-2023, 10:19 AM | #85 |
1540
Rep 2,008
08-18-2023, 10:23 AM | #86 |
1540
Rep 2,008
08-23-2023, 03:27 PM | #87 |
292
Rep 605
Are you saying that the new diff takes twice the volume of fluid than the old one?
08-23-2023, 03:32 PM | #88 |
1540
Rep 2,008
