BMW M5 F90 (2018+) General Forums Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls    Best Lug Nut Socket for 2020 M5C
      09-26-2021, 08:25 PM   #1
Stealth7
147
Drives: No BMWs Right Now!
Any suggestions best lug nut for our OEM wheels? Deep enough and non-scratching if possible.
Also, I did not notice any lug nut socket included with the car--2020 M5C (I am the original owner).
Thanks!
      09-27-2021, 08:46 AM   #2
AHall
982
Drives: 1993 Nissan 240sx
Thanks!
My wife has a 2018 M550i and it came with a spare, jack, lug nut wrench and other tire changing tools. I used the jack and wrench when I needed to remove one of my wheels. The jack works great. It fits perfectly in the jack supports. The wrench works well also. There is nothing to prevent banging the wrench against the wheels. Some shops wrap these with tape. I think if you are careful you should be able to avoid damage.
      09-27-2021, 11:10 AM   #3
Egrunt
Egrunt's Avatar
553
Drives: BMW M5 (F90), Tacoma, GTI
Many years ago I purchased the Harbor Freight Pittsburgh 1/2 In. Drive Super High Torque Lug Nut Impact Socket Set 11 piece from Harbor Freight. There are protective sleeves around the socket to protect the insert area of the wheel. Worked great for protecting my wheels when I changed out the stock brake pads to the Porterfield pads.
      09-27-2021, 11:55 AM   #4
GranitM5
GranitM5's Avatar
366
Drives: 2018 BMW M5
I bought these last year when I switched from winters to summers. They do their job well but wore out quite a bit after only one use
      09-27-2021, 02:12 PM   #5
Stealth7
147
Egrunt:
Thank you for the excellent suggestion!
In the past I have had similar sockets on a case – by – case basis.
This time I just purchased a 1/2" Drive 17mm, deep socket and will use electrical tape to help avoid scratches.
Also, I contacted my local BMW Dealer and they do not sell any such part.
      10-22-2021, 09:52 PM   #6
Maverik259
Maverik259's Avatar
Drives: F90 M5 / F15 50i
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Thanks!
Don't over complicate this. Amazon will do just fine and provide 100s or options.
'07 Yamaha R1 (sold)
'06 C55 AMG (sold)
‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe
'14 X5 50i (wife’s now)
