M2 Technical Topics > Track / Autocross / Dragstrip > Square set up and MDM intervention
      01-30-2017, 08:43 PM   #23
rich8566
rich8566's Avatar
Drives: M2 + Z-4
2014 BMW M235i  [0.00]
Originally Posted by f87chas View Post
How low can you drop cold tire pressures and not get a TPMS message which I hear will not allow you to keep DSC off?
Adjust the tires pressures and then simply reset the TPMS - problem solved.
Current: 2017 ///M2 manual 2004 E85 Z-4 manual
      01-30-2017, 08:45 PM   #24
rich8566
rich8566's Avatar
Drives: M2 + Z-4
Originally Posted by M3 Adjuster View Post
Originally Posted by Hossel19 View Post
Originally Posted by David1 View Post
If you set up the suspension with camber plates , don't over drive the car, and have the correct starting tire pressures, the MPSS tires will be fine.
I had camber plates and updated suspension on my 335 and I am trying to avoid that on the M2.
Even with proper tire pressure my experience with Yoko AD08 and Dunlop StarSpec is significantly better than MPSS on the track from a durability perspective.
Yoko AD08 and Dunlop StarSpec is significantly better than MPSS on the track from a durability perspective."
Agree 100 percent.
The AD08 is significantly better than the MPSS with regard to hot weather track use. At temps
Above 80 degrees the MPSS can chunk badly where as the AD08 will be in its element.
Also Hancook RS3s - work great on track in a square setup.
      01-31-2017, 08:20 AM   #25
Hossel19
63
Drives: M2
RS3's are good but don't have the same durability as AD08's and Dunlop Start Specs. RS3's have been replaced with RS4 this year so we'll see how much improvement there is.
My personal list for dual duty street / Track day:
- Yoko AD08
- Dunlop Star Spec
- Bridgestone RE11
- Hankook RS3
MPSS does not make the list and I am yet to try Bridgestone RE71 however I hear it's got the best grip but falls short on durability...
m2
