EXXEL Distributions
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
      04-08-2015, 08:27 PM   #23
evanescent03
evanescent03's Avatar
1033
Drives: '24 M3 CS; '22 GT4
Originally Posted by DaBean
I agree with going square - I have that on my E46 and I love being able to pick and choose which tire I want where, depending on the track and existing wear.
I am also concerned with using spacers at the track. Doesn't that put a LOT more pressure on the hub, accelerating wear and potentially setting up for deformation?
Can someone confirm? An ET33 offset for an 18x10 wheel will work well for front and rear, with 275-width R888, using stock suspension (no camber plates... yet) and no spacers?
I'll be installing my 18x10et33 with 10mm front spacers, none rear and 275/35 NT01s. I'll post photos when I get em mounted up.
I've heard people swear for and against spacers... I've decided a smallish spacer by a big company is fine (I'm getting macht schell)... plenty people use them it seems without a major trend of mechanical failures so i decided that the benefits outweigh the potential risks to me.
Gone but not forgotten: '09 STi // '08 335i // '02 M3 // '11 335i // '15 M3 // '16 M3 // '16 Camaro SS // '16 Audi S3 // '18 Boxster 718S // '17 Camaro SS 1LE // '16 M6 GC CP
      04-08-2015, 10:36 PM   #24
JNoSol
JNoSol's Avatar
Drives: 750 MSPORT & E90M3
Macht Schell make really good stuff. You can never go wrong with their spacers. No vibration issues ever been reported (to my knowledge) on MS spacers. I can't say the same for lower end brands. Please post photos to the this thread when you have it installed. We want this thread to be a rolling knowledge compository of track fitments.
Daily: G12 750 MSPORT Weekend Car: E90 M3
      04-09-2015, 07:35 PM   #25
evanescent03
1033
i sure will. should have them in a week or so... gotta wait for the ATE dot 4 and RS29 pads and gonna do it all at once before my track day early next month. i'll be taking some amateur-quality shots with my DSLR lol. i think the "what wheels, tires, spacers, and suspension has worked and hasn't worked" is a great thread.
i'll report back
      04-09-2015, 10:41 PM   #26
buildbright
buildbright's Avatar
155
Drives: F80 M3 MG
i'll report back
Sounds great working on what tires to get. Right now I am between RS3's and AD08R's. RS29 pads seem the go to pads right now.
      04-09-2015, 11:05 PM   #27
evanescent03
1033
i'll report back
you'll find plenty love for both of those .. I went with nt01 275/35/18.. too many rave reviews and people using them all the way until they cord without heat cycling them out first. I can't wait to try them out.
      04-09-2015, 11:11 PM   #28
buildbright
155
Drives: F80 M3 MG
Let me know about those tires I hear mixed reviews about them. But this is the internet. I have RS3's on my tuned 335i and they are awesome. I can drive aggressive even in the rain without issue.
      04-09-2015, 11:21 PM   #29
evanescent03
1033
Let me know about those tires I hear mixed reviews about them. But this is the internet. I have RS3's on my tuned 335i and they are awesome. I can't drive aggressive even in the rain without issue.
there are mixed reviews for everything, honestly. I'll post my humble feedback after my track days next month.
      04-10-2015, 01:36 PM   #30
Gtrny
13
Drives: m3
Nice write up!!
I picked up apex ec7 18x10 +25 aquarium set up,
May I run stager tire with same wheels?
I'm new to m3
Thanks
      04-10-2015, 01:52 PM   #31
JNoSol
JNoSol's Avatar
Originally Posted by Gtrny View Post
Nice write up!!
I'm new to m3
Thanks
With ET25, it will stick out if you run anything larger than 275. I'll let others chime in who had experience with such aggressive offset. I'm using the reference of guys who has stock ET40 rear wheels with 15mm spacers, which puts it at ET25. They are very flush with very little wiggle room with 275/40/18.
If I were you, I'd run 275/35/18 all around. That, I know will fit and you can rotate your tires. If it was ET33, you could do 295/35/18 rear and 265/35/18 front.
      04-10-2015, 02:52 PM   #32
Gtrny
13
Drives: m3
Ok I have a nt01 275 square So I ll try this set up next month @ njmp thunder.
I want to try next set of tire for 275 Front 295 Rear!
Thank you in put!
      04-11-2015, 07:05 AM   #33
CSBM5
CSBM5's Avatar
2723
Drives: 2019 M2 Comp, 2011 M3, etc
With the NT-01s, make sure you inspect the rears after every session on track, and rotate to the other side of the car, as needed, to change the direction of rotation. The tread splice tends to open on them these days (issue started maybe 3 years back now, and has come and gone since then with various batches), and you don't want to have it tear open a large gap. If you swap the rotation of the rears, you'll be forcing one tire to be putting closing pressure on the splice while the other is stressing it to open. It's about the best you can do.
I've not seen an issue with the fronts opening up (due to large breaking forces), and I can only imagine that the F80 will stress the rears more than my M5 and M3 do. There is a long thread on this issue in the E9x M3 section of the board.
As to the NT-01 itself, I've used them for 8 years now, and they are a wonderful mid-line R-comp tire that can be driven on the street to/from events. They will give a lot more audible feedback at high slip angles near/over the limits than more dedicated track tires (Hoosier A6/R6, BFG R1/R1S, etc), and they are more forgiving it you step over the peak of that tractive force plot.
I'm also amazed at how they stick well for many heat cycles. Back in 2012 a friend did a private track rental, so I pulled out a mounted set I had for the M5 that had been used a bunch but had been sitting, covered, in conditioned garage, since 2009. I put them on for a quick test, and grip was still excellent however the edges were just starting to show cords after I came in, so I had to use PSS for that event.
Have fun, but watch those rear tire's tread splice!
Regards,
Chuck
P.S. For the F8x, if it was me, I would actually consider running a staggered setup simply due to the torque output curve of the S55. I'd want a 295 or 305 in the rear. If that's not possible, you give up rotation, but running a 275/40-18 in the rear might help hook up a bit given it's slightly larger diameter.
Current Stable:
2024 G20 M340i Melbourne Red/Cognac
2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg
2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8
      04-11-2015, 08:55 AM   #34
MaynardZed
MaynardZed's Avatar
Drives: wife crazy
Bunch of good info here. I'll just add that might worth looking at tweaking the stock alignment a bit too. Couple of issues we've noted with the F8X chassis on the track. Its a bit lazy on turn in, stock alignment has some front toe in so we made it neutral and it has helped some. I may even go a little bit of toe out next time.
Obviously its a little tail happy with 460 ft/lb torque (Dinan) at the rear wheels. There is not much toe in from factory to help this, so we added more. I think we are at 3/8 total toe in for the rear now. This will probably be especially helpful if you're running 275 square. As its been mentioned a bunch, the M-mode is near useless on the track so you'll need to get comfortable eventually with tracking with everything off.
Couldn't mess with camber/caster much yet since I'm on stock suspension. IIRC it had -1.2 camber / +7.0 caster (wow?) in front and -2.0 camber in the rear.
Road course laptimes for BMW M4 2015 6MT
WHP East Track: 1:04.880, Arizona Motorsports Park: 1:54.352
Road course laptimes for Porsche 911 991.1 GTS 7MT
WHP East Track: 1:02.770, Arizona Motorsports Park: 1:48.889
      04-11-2015, 02:59 PM   #35
slavearm
226
Drives: 2019 M5CE MBB/SS
Thank you in put!
Run the 305 rear. It is a near perfect match to the stock diameters and you will want as much rubber as you can put back there.... trust me.
      04-11-2015, 04:27 PM   #36
evanescent03
1033
Thank you in put!
assuming this is what you've done, what wheel specs worked for you?
thanks!
      04-12-2015, 06:06 AM   #37
slavearm
226
thanks!
18x10 +25 275/35/18
18x11 +35 305/35/18
The 275 for the front everyone has in stock. The 305 rears usually need to be ordered, but are available.
Appreciate 3
      04-13-2015, 11:15 AM   #38
JNoSol
JNoSol's Avatar
thanks!
18x10 +25 275/35/18
18x11 +35 305/35/18
Is your car lowered? I just realized tires are cheaper in 19s for those odd sizes. Ideal staggered setup would be 275/30/19 front and 305/30/19.
275/30/19 all around for square setup.
I might do 19s staggered which should look good for street and track. The price difference of tires should help justify the inability to rotate tires front to back. Anyone disagree?
      04-13-2015, 01:24 PM   #39
CanAutM3
CanAutM3's Avatar
21117
Drives: 2021 911 turbo
What has not gotten me fully convinced about a staggered width setup for the F8X is the weight distribution of the car. The F8X remains with a front biased weight distribution, which means the front tires need to work a little more during cornering.
While a slight stagger might be beneficial to handle the power, I am not convinced it will outweigh the benefit of being able to roatate tires on the fly. I guess I will find out after a few events. Only 2 weeks to go until my season opener .
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black
      04-13-2015, 02:43 PM   #40
FTS
Enjoying driving
FTS's Avatar
Drives: 645
You certainly are correct, and of course we really don't know much about the dynamics, particularly me. But you might be discounting the dynamic weight shift maybe too much.
My expectation is under braking the weight shift to the front axle and unloading of the rear will be enough to prevent terminal understeer, except it will be easier to overload the front tries probably. Under acceleration, the weight shift to the rear will certainly put more weight on the rear axle than the front, by how much - I don't know, but enough that the largest possible tires combined with low gear torque hitting the rears will feel very good
      04-13-2015, 02:53 PM   #41
JNoSol
JNoSol's Avatar
Some of the guys have complained 275 isn't enough rubber for the rear. Our cars are tail happy and have tons of torque.
      04-13-2015, 02:56 PM   #42
JNoSol
JNoSol's Avatar
I'll wait for your feedback before making a decision on my June track setup.
      04-13-2015, 03:34 PM   #43
slavearm
226
Just at big willow yesterday. Go staggered. Just look at everyone in the dirt for proof. Too much torque. No amount of weight bias is going to make up for that. This car does not understeer... it oversteers... ALOT. You need the extra meat out back to help balance it out.
      04-13-2015, 03:40 PM   #44
slavearm
226
1. I am not going to say much to this because I don't really want to start a flame war, but that only matters during turn in. The moment you get to the apex and put the hammer down, it doesn't matter anymore. What matters is how much traction you can generate with your rear wheels.
2. You can deal with most of that by handling weight distribution with the brake and throttle.
3. A front weight biased car rear wheel drive car will tend to oversteer. Which is why you add more traction to the rear to counter.
Tags
square, staggered, track wheels
f80post
