BMW M5 F90 (2018+) General Forums iDrive, Nav, Stereo, Bluetooth, Electronics    Adding trunk sub to B&W
      12-24-2020, 01:40 AM   #1
2JsSePa_F90
Drives: M5 comp
Hi All,
I am planning on installing a trunk sub setup out my old F80 into the F90.
Two issues I just need clarification on if anyone knows:
1 - Will ASD be an issue as it was in the F80? In the F80 I just unplugged the module while I was in there. Luckily I got MPE so I should be OK with ASD off.
2 - I notice that the bass gets rolled off when volume goes past about 60%. Is there a way to get around this?
Thanks in advance.
      12-24-2020, 08:19 AM   #2
Motorin Mark
38
Drives: 2020 M5 Rhodonite Silver
Love to do this to mine. Keep us updated as you move along please.
      12-28-2020, 04:04 AM   #3
2JsSePa_F90
Drives: M5 comp
So as to my second issue, I forgot that the LC2i does perform this function so this is a non-event.
New issue.
ASD is not where I thought it would be?
      12-28-2020, 04:55 PM   #4
Motorin Mark
38
New issue.
Must be coded out on 2020-2021 models, it was a plug you pulled in the trunk on 2018-2019 models.
      12-29-2020, 12:51 AM   #5
2JsSePa_F90
Drives: M5 comp
New issue.
New issue.
Thought as much. I have left it on and I must say that I am not concerned about too much drone running through the new sub. I actually think the deeper ASD along with MPE sounds better overall.
Thanks for the input.
Definitely worth the effort. For those worried about the sound passing into the cabin I can say it is not an issue.
I am running an old 12inch MTX dvc in a sealed enclosure powered by a 600w monoblock amp.
Now to kill the vibrations on the underside at about 50hz. Sounds like heat shields.
Jamesmick131.00
      01-05-2021, 04:07 PM   #6
Jamesmick
131
Drives: 2018 M5 Azurite Black
Awesome, info. Did you take any photos of the install? Would love to add something similar to mine.
2018 M5 (current)
2012 535i Msport/Dinan (current)
2008 535i Msport (retired)
2003 530i (retired)
2000 C32 AMG (retired)
      01-07-2021, 07:10 AM   #7
2JsSePa_F90
Drives: M5 comp
No pics but will take some once I figure out a permanent way of keeping the box in place.
This same box stayed in place with bungees for 4 years in my F80. This thing pulls much harder.
I have ended up not using Accubass due to it being very unpredictable in its delivery and I have not coded out ASD.
Just re-tuned EQ, fader and Lc2i output levels for me to be fully optimised at about 65% on the volume scale.
Jamesmick131.00
      01-07-2021, 06:07 PM   #8
Bahzad
Drives: BMW M5 F90(coming)
Actually if u can add some post install video clips of music playing
      01-10-2021, 10:52 AM   #9
Mcc420
Mcc420's Avatar
475
Drives: G80 M3CX
2023 g80x  [0.00]
  [0.00]
I just put two strips of Velcro under the box.
G80 Comp, Hcp custom e50, 9.69@141
F90 Comp, Hcp custom e40 meth, 9.76@143, 174ml/h 1/2ml 60-130 5.53
F10 M5, HCP Tune ,BM3, 10:8@137, 166.05 1/2ml.
Ig @mcc420
Appreciate 2
      02-11-2021, 06:40 AM   #10
TXDroneRacer
TXDroneRacer's Avatar
Drives: 21 M5 Comp, 21 X5 M50i
Where did you get power for the sub amp?
I have a 2021 M5C.
Where do you connect the audio input?
Thanks
      02-21-2021, 07:49 PM   #11
EPTXM5
Drives: 2018 BMW M5
Where did u get the signal input for the amp?
      03-03-2021, 08:47 AM   #12
SG_E90
DaZuc
72
Drives: S65 1M Clone
https://technicpnp.com/
New issue.
You mentioned LC2i resolves bass roll off issue?
I'm having this issue in my G20.
https://www.audiocontrol.com/car-aud...-upgrade/lc2i/
Jamesmick131.00
