BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    Stud conversion anyone?
      04-22-2023, 09:01 PM   #1
916_M5
IG: @M5RCY_
916_M5's Avatar
Drives: BMW F90 M5
Hey all, I am thinking about converting my wheel bolts over to steel studs (not titanium) and using some Project Kics R40 Iconix M14 Lug Nuts.
Does any have any photos of this stud conversion done on their F90 and can please share?
I can only maybe 2 or 3 examples online, I know FSHNGRY is running FC Titanium set and they look fantastic, can anyone else chime in please?
Autotecknic.com - code: M5RCY for 12% off
Project Gamma - code: M5RCY for 5% off
Dura-Coating - code: M5RCY for 20% off
FSHNGRY2336.50
      04-22-2023, 09:31 PM   #2
pbonsalb
5234
I run studs from Future Classic. There were not many options when I was shopping. Usually I buy Bimmerworld’s race/premium studs. I can say that the 80mm I have are longer than you need even with 12/15mm spacers on stock wheels.
      04-22-2023, 11:22 PM   #3
916_M5
IG: @M5RCY_
916_M5's Avatar
Drives: BMW F90 M5
Would you be so kind to share some pictures of your set up with that length. I was considering going with 78mm studs.
      05-03-2023, 10:29 AM   #4
Maverik259
Maverik259's Avatar
Drives: F90 M5 / F15 50i
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Do it.
'07 Yamaha R1 (sold)
'06 C55 AMG (sold)
‘?20 M5, MP Carbon Pro Spoiler, MP Carbon Diffuser, MP Black grille and gills, MP Carbon Mirrors, CF side sills, 789M w/ Ti studs, eventuri, Dinan X pipe
'14 X5 50i (wife’s now)
      05-14-2023, 02:22 PM   #5
shawnhayes
1834
Drives: 22M5 CS,23X5E,24M3 CS,24 i4
Having had plenty of regular stud failures on non-EU cars in the past....
WHY would you add another element to the system that might fail?
BMW/Merc/Volvo/Audi have kept the "wheel bolt" system for years for a reason.
Shawn
      05-17-2023, 11:56 PM   #6
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Shawn
Weight savings. Duh!
'06 C55 AMG (sold)
      05-20-2023, 03:39 PM   #7
shawnhayes
1834
Maverik2594140.00
      05-21-2023, 03:16 PM   #8
FastFive
28
Drives: Bmw ///M’s
I did the stud conversion. Motorsports Hardware Titanium. I’m running 20X11fr and 20X12r Anarky Wheels. No spacers. No issues.
      05-26-2023, 10:38 PM   #9
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Not at all. Hahahahaha
They are beautiful though. I would never track them and I don’t have any canyons near me to push the car past the typical 100+ run up the express lanes to work/home.
'06 C55 AMG (sold)
shawnhayes1834.00
      06-26-2023, 09:12 AM   #10
99-ls1-ss
27
Drives: 2023 M5 Competition
Is there any evidence that wheel bolts are better/stronger/more dependable than wheel studs and lugs? Not being a confrontational, I'm asking in all seriousness. I would like to know the answer.
I understand that European manufacturers us bolts but every single American manufacturer uses studs.
Since this is my first vehicle that has wheel bolts, I can definitely say that mounting the wheel on a vehicle with studs is much easier to do than a vehicle with bolts.
      06-26-2023, 10:09 AM   #11
pbonsalb
5234
Factory studs are pressed on from behind. By design they are stronger than aftermarket screw in studs. There may be a company doing replacement hubs with pressed in studs for some BMW models but not sure about the F90.
As for clamping force, it should be the same. It is more a strength or durability issue. Probably has to do with the stud being threaded from one end to the other and having 2 attachment points versus the bolt being one solid piece at the bolt head.
You can buy a wheel hanger — essentially 1 extra long stud you thread in and slide the wheel onto to make installing bolts easier. They you unscrew it and put the last bolt in its place.
Some install screw in studs anyway and have no issues. Just don’t use cheap ones and if you track, check them yearly and consider replacing them every year or 2. I don’t track, but use studs on my E36 M3 and F90 M5 and also used them on my E90 M3.
      06-26-2023, 11:42 AM   #12
shawnhayes
1834
No. It adds one more movable/replaceable part to a mechanism that needs no more moving parts. It boils down to do you wish to add a stud that depends on splines to prevent turning. If it fails, you have to drill it out.
Wheel security for either is the same (given the same number of lugs and similar pitch/engagement). A set of threads is torqued down and holds the wheel onto the hub.
Having had multiple stud failures in my Pre-BMW days, I like the wheel bolts better. They are more fiddly when changing, but when the bolts threads get buggered, I pull another one out of the bag and put it in the hole. Throw the old one away.
Shawn
      06-26-2023, 11:46 AM   #13
shawnhayes
1834
Mine
916_M5365.00
      06-27-2023, 05:38 AM   #14
frozenRedm5
33
Drives: M5, M3, X5M
If this helps any on your decision to convert to wheel studs. I've converted every BMW I have owned without any issues. I've ran wheel studs on my E46 M3 racecar for over 5 years and it hasn't failed on me yet. Matter fact, last year I crashed my racecar into the jersey wall, front impact. Wheels snapped but studs still in one piece (visually). Will replace them for peace of mind.
On that note, I bought a set of Matt Schnell wheel studs and will be converting my M5.
Maverik2594140.00
      06-28-2023, 10:24 AM   #15
Maverik259
Maverik259's Avatar
2020 BMW M5  [10.00]
2014 X5 50i  [0.00]
Agree here. Quality stud or don’t do it. Steel are more ideal if you’re concerned so to their more elastic nature than Ti+ but I went for looks and lack of corrosion and as I said I don’t track this car.
Raceseng, macht Schneider, and future classic have quality kits. I went with the future classic because they were available otherwise Raceseng would have been my primary choice.
'06 C55 AMG (sold)
