06-21-2023, 11:30 AM | #23 |
IG: @M5RCY_
365
Rep 317
+1 for PTP
Just finished installing my PTP blanket this week. I need to go for a sprinted hour drive this weekend to compare my infrared temp readings that I took preinstall, so we can actually see the difference in engine bay temps.
So far, so good, and highly recommend to everyone. Also seems like a good way to reduce the amount of heat getting to the expansion tank, therefore hopefully extending the life.
Autotecknic.com - code: M5RCY for 12% off
Project Gamma - code: M5RCY for 5% off Dura-Coating - code: M5RCY for 20% off |
06-22-2023, 10:17 AM | #24 | |
982
Rep 1,797
Also we’re any modifications necessary? Were you able to reinstall all original parts and hardware after the blanket is in place? |
06-22-2023, 10:51 AM | #25 |
5234
Rep 10,616
Some say blanketing or wrapping cats is not good. Some say retaining heat in the Vee is not good by just throwing a blanket on top of everything hot. This blanket will reduce heat escaping upwards towards the coolant tank if that is the goal. My recommendation is turbine blankets or coating and catless downpipe coating or wrapping.
06-25-2023, 12:45 AM | #26 |
4140
Rep 7,160
Drives: F90 M5 / F15 50i
Agree. Catless is ideal. Designing them to sit almost in the V itself is a rather piss poor design for engine parts longevity. Quick way to get them heated for emissions though. Fml.
'07 Yamaha R1 (sold)
06-25-2023, 08:19 AM | #27 |
5234
Rep 10,616
I don’t know whether putting the turbos in the Vee was for emissions or for response or for engine compartment packaging. It certainly took a lot of work to change the exhaust parts on the heads from outside to inside and make a compact new crossover manifold and design new intake manifolds for the outside. Was this all to heat up the cats as quickly as possible? It sure was good for response and power.
I agree the heat will likely have a long term negative effect on the motor. I did what I could to reduce that early on the life of my motor. I did not buy an $8k Supersprint manifold and send it out for coating but if I build a motor, I would consider that. |
06-26-2023, 06:56 AM | #28 | |
114
Rep 282
06-26-2023, 07:50 AM | #29 | |
22
Rep 82
What’s this super sprint manifold, have you got a link ? |
06-26-2023, 08:09 AM | #30 |
5234
Rep 10,616
06-27-2023, 12:08 PM | #31 |
IG: @M5RCY_
365
Rep 317
My BMW tech did it for me. He said it was relatively easy. The most difficult part was removing and setting aside the coolant tanks and hoses. He said 2 of the bolts lined up but the shear space (or the lack there of) is holding that blanket well in place. Its not moving what so ever.
06-28-2023, 10:18 AM | #32 | |
4140
Rep 7,160
07-15-2023, 07:02 PM | #33 | |
114
Rep 282
07-18-2023, 11:20 AM | #34 |
IG: @M5RCY_
365
Rep 317
Sorry I have been delaying. Allow me to work on that this weekend. Its been triple digits the last 2 weeks in northern cali.
Ill take a nice drive this weekend then take temp readings. Overall first impressions are fantastic!
07-21-2023, 07:40 AM | #36 | |
114
Rep 282
Thanks for doing this!! |
07-21-2023, 06:05 PM | #37 |
IG: @M5RCY_
365
Rep 317
It's 110-109 all weekend. Sorry I am just waiting for a cooler day. I took my initial readings on an 82 degree day. Just hoping to test in similar conditions. Its been so hot lately!
07-22-2023, 10:30 AM | #38 |
114
Rep 282
Just had mine installed. I didn't do a temp check before and after unfortunately, timing just didn't work.
To set the stage, we have had 99-103 degrees the past month daily. Heat index is 113-120 degrees daily. My observations for the past day.....the car only went to 210 degrees for less than 10 mins of the hour and half driving around and idling around I did in 100 plus degree sunny weather This thing works, and works really really well! Last edited by Kponti; 07-22-2023 at 10:36 AM.. |
07-22-2023, 02:16 PM | #39 |
5234
Rep 10,616
I would not have expected the PTP blanket draped over the turbines and cats to lower engine oil or coolant temperatures. Seems like it is just trapping heat in the Vee of the engine. The expected benefit is lower under hood temperature, which would extend the life of plastic parts, especially those next to or above the turbos and cats.
On a car with a big, slow turbo, trapping heat in the turbine can help performance. Our little GT22 are probably too small and already so fast spooling that there would be no performance gain. Last edited by pbonsalb; 07-25-2023 at 11:35 AM.. |
07-23-2023, 05:12 PM | #40 | |
114
Rep 282
But I definitely can see the temp gauge staying in the 160-180F range all day yesterday when ambient temps were 100-105 with heat index of 113-120F. It will creep up to 210 if idle too long especially after a brisk higher rpm drive. Even that is short lived, dropped temps back down a few minutes later. About the drop in 0-60, was not expected. But my best 0-60 has been a 3.85 on this heat (tried it twice just for testing purposes). Best with the blanket is 3.41 and the difference was from heat soak. All times brake boosting not using launch control Last edited by Kponti; 07-23-2023 at 05:17 PM.. |
07-25-2023, 10:02 AM | #41 | |
4140
Rep 7,160
07-25-2023, 03:54 PM | #42 | |
1920
Rep 4,922
What temp are you looking at oil temps?
07-27-2023, 11:47 PM | #43 | |
114
Rep 282
No traction issues, but I did make sure the car was fully heatsoaked from day to day driving before making the runs Last edited by Kponti; 07-29-2023 at 02:57 PM.. |
07-30-2023, 12:03 AM | #44 |
4140
Rep 7,160
How are you determining “heat soaked”
