10-14-2019, 04:10 PM | #67 |
Rep 26
10-14-2019, 10:43 PM | #69 |
369
Rep 1,887
Drives: '20 M5C, '09 M3 DCT Coupe
FWIW, I've never been in a car that didn't have the triangle indicating which side the fuel is filled from. I think that's been pretty standard on all cars for quite some time now. But nice to know for folks that didn't realize it was there.
M5C 20% tint, Xpel full front, partial sides and rear. Spacers, 15mm front, 12mm rear. Turner Motorsport Oil Cooler Guard.
M3: Active Autowerke filter, Dinan underdrive pulley, Dinan full exhaust and software, 3.45 Differential, Springs, Brakes, Dinan/HRE wheels, 275/30-19 w/10mm spacer, 295/30-19 w/3mm spacer, painted front reflectors, 30% tint, Escort 8500i & Lidar Jammer, LUX H8 V5 halos, Euro rear foglights, 3M ClearBra. |
EPTXM579.00 |
10-15-2019, 08:09 AM | #70 |
31
Rep 159
10-15-2019, 10:46 AM | #71 |
1719
Rep 1,913
Drives: 2023 M5C
Another little "detail" I haven't seen mentioned... On the speedometer, assuming you're above the speed limit, the space between the needle and the speed limit will fill in red. So assuming you're going 50mph in a 40 zone, that gap between will fill up red as a visual reminder.
IG @windtendo_m5
10-27-2019, 06:05 PM | #73 |
28
Rep 75
Probably common knowledge, but ...
If you are in "sequential Mode" and Pull-Hold the Up "+ Paddle" the car will return back to "Auto Drive mode"
2015 911 Carrera 4S 7MT 2018 911 GT3 6MT 2019 BMW M5 Comp |
10-27-2019, 07:49 PM | #74 |
114
Rep 275
11-20-2019, 04:57 PM | #76 |
2511
Rep 4,381
So if you have the start/stop feature switched on and autohold switched on...when you come to a stop in traffic behind a stationary car, the engine switches off and you can take your feet off both pedals.
When the car in front of you drives off and it reaches a car length or two away, the start/stop switches the engine back on without you touching any pedals! Or at least it does for Euro cars. |
lsal137.50 |
11-20-2019, 11:11 PM | #77 |
16
Rep 68
one interesting fact that I found out on my south east asia spec car is that my rear seats do not fold down, as it does not have a latch behind! not sure if any other regions have this spec
11-21-2019, 07:51 AM | #78 |
200
Rep 327
Drives: BMW M5 Competiton
Location: Northwestern Switzerland veeeeery close to the German Autobahn
Works as described, actually a pretty neat feature! Thank you!
2019 - BMW M5C MY2019 (Individual Urban Green)
2016 - VW Passat B8 2.0 TSI (276 bhp) R-Line (sold) 2013 - BMW M135i xDrive 3.0 (316 bhp) (sold) 2010 - Mazda 3 MPS BL 2.3 (256 bhp) (sold) |
11-21-2019, 12:20 PM | #79 |
94
Rep 419
Drives: 2019 F90 M5B, 2006 E60 550i
11-21-2019, 02:20 PM | #80 |
200
Rep 327
It's a safety feature giving you the max possible rpm depending on the oil temperature.
05-22-2020, 06:32 PM | #81 | |
28
Rep 75
If you are at a standstill and hold the "- Paddle" while in manual mode the car will return to auto mode. (This will only work at a standstill, example red light). The other one will work at any time.
lsal137.50 |
05-22-2020, 11:50 PM | #83 |
1899
Rep 2,518
Nice thread. What other good tips are out there?
2022 F90 M5 Competition & 2019 M2 Competition
2019 F90 M5 Competition 2017 F80 M3 Competition 2014 F10 M5 Competition 2003 E39 M5 |
05-23-2020, 12:23 AM | #84 |
1434
Rep 1,362
05-24-2020, 02:09 AM | #86 |
508
Rep 673
When I try to unlock the car with the key fob or lock when it’s my first attempt of the day it doesn’t let me. I literally have to go to the door handle and unlock it that way. Then they key fob will work. Is it a low battery on the fob or jr sha new?
05-24-2020, 08:54 PM | #87 | |
69
Rep 96
Circulate it upward and then release it back down by the rear portion of your exhaust cats. It's done to help car keep rear ended seated down during high speeds. It used to drive me crazy at first then I put the car on a lift and noticed that and asked around that's the answer I got. |
05-24-2020, 08:58 PM | #88 |
69
Rep 96
Yes. This tranny works the same as a Hellcat transmission , I know I know I shouldn't bring mopar stuff around here but they're known for this feature as when they go race they shift down get to the right roll and gear and then hold pedal and hit gas and tranny does the rest of the work.
