10-07-2019, 03:26 PM | #1 |
294
Rep 456
Grippy tires for 20 inch wheels.
Are there any tires for the factory 20 inch wheels that will hook up off the line with an ecu tune/downpipes? I've been struggling to find much in the required size, and none have been drag radials or track compound.
10-14-2019, 05:58 PM | #2 |
237
Rep 838
How are you launching that it gives you traction issues? 4wd normal or 4wd sport? Or are you just making so much power it doesn't matter?
19 MBB M5C
16 Yas MarinaM4 (gone) 05 E46 M3 HPF/ProEfi Stage 2.25 (Gone ) |
10-14-2019, 06:31 PM | #3 |
463
Rep 524
Are you willing to sacrifice a bit of comfort for traction? My previous overpowered sedan had traction issues as well....swapped the Michelin rubber for Toyo r888r. Much stronger straight and curvy traction, but the tires were louuddddd....I didn't care, but its def noticeable. I had other rims to swap back to ps4s when I preferred 'luxury cruising'.
