10-02-2023, 05:25 PM | #1 |
27
Rep 103
F90 M5 Base Engine Compared to Comp
if I was to lets just say blow a comp motor would I be able to put a base engine in my comp and run it no problems and still get the max hp the comp engine have?
10-02-2023, 05:42 PM | #2 |
170
Rep 221
Tuning is the only difference, hence the reason when you go stage 1,2 the HP/tq is the same wether you are comp or not. IIRC the comp makes slightly more boost up top to account for the difference in HP but not an increase in tq.
cali_m527.00 |
10-02-2023, 08:24 PM | #4 |
5269
Rep 10,666
There is no difference in the motors. Very slight difference in the programming of the ECU operating the motor.
Some say there was a change to the cylinders lining around 2020. No one has said the change has any significance in terms of performance or durability. |
cali_m527.00 |
10-08-2023, 11:15 PM | #5 |
4146
Rep 7,164
Drives: F90 M5 / F15 50i
Same engine. Not sure how you’ll get the computer to like it.
'07 Yamaha R1 (sold)
10-09-2023, 06:59 AM | #6 |
5269
Rep 10,666
The computer won’t know the difference — and there is no difference in motors ir ECUs. The comp computer is flashed with the comp tune, which works fine on the non comp. I have run the comp tune on my non comp.
10-09-2023, 01:59 PM | #7 |
170
Rep 221
10-09-2023, 04:56 PM | #10 |
5269
Rep 10,666
The mod bug got me before I even had the car. I started with a JB4 immediately, added the BMS meth kit a month later, and after about a year installed CTS Turbo high flow primary cats and catless secondaries along with the BM3. I bought the bundle of tunes for the BM3 and tried the Comp tune but it was not noticeable so I went to the Stage 2 for 93 tune with the JB4 just controlling meth. Later, I changed to MAD catless primaries. Then I added 5 psi through the JB4 when the meth is flowing. Also added Xhp trans tune.
LouK170.00 |
