The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > DIY Guides > DIY: 335i Exhaust Sound Mod. Better, and even easier than golf tee mod.
      03-05-2009, 05:22 PM   #221
vgrani1g35
2009 335i
vgrani1g35's Avatar
Drives: 2009 335i sedan
does unplugging the actuator make the car louder? unclear of the benefit..details
      03-05-2009, 05:26 PM   #222
vgrani1g35
2009 335i
vgrani1g35's Avatar
im am new to the forum..i only check the first pg..it does make it louder..nice..going to do it right now! thanx
      03-12-2009, 02:51 PM   #223
jstar41
jstar41's Avatar
Drives: F25
ok.. did it in 2 mins.. now it goes.. RUUMM RUUMMMM.. ! ! :-)
      03-14-2009, 01:31 PM   #224
nick6753
7
Drives: 07 335i Coupe
Just did this mod, noticeable increase in exhaust sound. Off to scan with BT tool to see if it throws a code.
      03-14-2009, 01:39 PM   #225
thisguyhere
thisguyhere's Avatar
74
Drives: bmw
curious, also, let us know if u can easily delete it
      03-15-2009, 05:27 PM   #226
scottjones
Professional Member
scottjones's Avatar
Drives: 2012 Jeep Grand Cherokee SRT8
??? throw code?
I just got my 335xi - have about 80 miles on it and am very tempted to try this.. but, dont want to get into a whirwind of **** from the dealer if it throws a code....
Anything yet?
Scott Jones
2009 BMW 335xi (Previous)
      03-15-2009, 05:53 PM   #227
raceyBMW
king of the hills
raceyBMW's Avatar
92
Drives: 2011 M3 w/ESS55, 2001 540i/6
2001 BMW 540i/6  [8.17]
1994 530i  [9.00]
2007 335i Coupe  [8.37]
I have unplugged it a dozen+ times, and have never had the dealer say a thing about it. Just remember to plug it back in before you go, only takes a minute either way.
      03-16-2009, 02:06 PM   #228
TL
TL's Avatar
Drives: Happy on H&R coil overs
2008 335xi  [1.00]
good stuff
I tired this on my 335xi and found it about 10% louder and so did my passenger. The only bad thing to me is my passenger side tail pipe is much dirtier.
      04-02-2009, 09:49 PM   #229
Synikal
37
Drives: F30 335i M Sport
I just finished this mod while I had the car running and you can really tell a difference immediately. I even heard a little click must have been the bypass disengaging. No errors what so even what a neat trick! thanks!
/Chris
      04-08-2009, 08:58 AM   #230
**335i**
**335i**'s Avatar
Switzerland
184
Drives: TOYOTA & 2008 E92 335i 6MT
2008 335i  [9.00]
reading all this i want to ask: do u feel any power loss i mean in torque and hps? and will it harms anything?
thanks
E92 335i Black Saphire 6MT PROcede V5, BMS DCI, Big Tom IC, AR CL-DP's 3", AR Design OC, Forge DV's, OEM M3 side skirts, BMW Performance Wheels 19 inch 269 Black Gloss+Continental ContiSportContact 5P (400hp and 550nm) https://www.youtube.com/user/aistis7..._as=subscriber
      04-09-2009, 03:35 PM   #231
GB///M
GB///M's Avatar
Drives: M3 CS, X5 M60i
Thumbs up Unplugging the actuator from the trunk
This was an extremely easy mod and i honestly noticed a difference right away along with a couple other people. I received no error codes and dont care if it does throw some in the computer and not the dash; the dealer can suck it. They definitely will not notice it anyway and i dont think this will cause any problems in the future. The exhausts are a little louder and it sounds sweet!! Maybe it's just me but i noticed my DTC flashing more when i punch it off the line now like at a red light; it does feel slightly quicker off the line. The only disadvantage i think there is for gas mileage. I think i get about one or two less miles per gallon, but for the way it sounds i really dont care!!
      04-10-2009, 06:02 AM   #232
**335i**
**335i**'s Avatar
Switzerland
184
2008 335i  [9.00]
but there are people saying that it can cause damage to o2 sims and so on
      04-10-2009, 08:01 AM   #233
GB///M
GB///M's Avatar
o2 sensors go bad once in while its not an uncommon thing. Im almost positive that the o2 sensor going bad is not from unplugging the actuator. Also if i have any problems ill let you know, but everything will be fine
      04-10-2009, 08:17 AM   #234
**335i**
**335i**'s Avatar
Switzerland
184
2008 335i  [9.00]
one of the forum members said to me:
Just crouch down behind the car by the left exhaust pipe and look underneath. Attached to the pipe behind the tip is an actuator with a rubber pipe attached to it. Just pull the rubber pipe off and stick something in the rubber pipe to block it.
do u know that doing this u dont get error codes and no probs on BMW service http://img301.imageshack.us/img301/7075/pic1f.jpg then u will avoid all error codes and everything
      04-10-2009, 09:17 AM   #235
GB///M
GB///M's Avatar
That sounds interesting and will probably work...but the exhaust system in the pic is not from a 335; looks like a 330. Maybe it still the same concept. To tell you the truth though if by some chance you get an error on your dash its not something to really worry about the dealer can never deny you to fix it...its all covered under warranty. You gonna try doing that?
      04-10-2009, 09:23 AM   #236
**335i**
**335i**'s Avatar
Switzerland
184
2008 335i  [9.00]
u mean as shown in this picture? maybe dont know yet
      05-06-2009, 10:25 AM   #237
Cptn Mo 703
Cptn Mo 703's Avatar
Drives: my feet
How do you do this in a E93? I looked for that flap you remove...and couldnt find anything that looked like the picture.
      05-06-2009, 01:49 PM   #238
FoShizzle
aka Mike
FoShizzle's Avatar
106
Drives: AW E92 335is
Its only on the 335 models.
If yours is a 335 and its not there, that would be very interesting.
      05-06-2009, 02:57 PM   #239
Cptn Mo 703
Drives: my feet
yup 335i convertible..and theres this plastic/rubbery cover thing...and i removed it and it was just the wires and stuff for the tail lights
      05-06-2009, 03:07 PM   #240
FoShizzle
aka Mike
FoShizzle's Avatar
106
Its in there. Grab a miners hat and dig deep! Seriously though, it might be a little hard to find the wires. I found mine by touch and had to yank on it a little. Maybe some e93'rs can chime in here...
      05-06-2009, 04:47 PM   #241
kyd335xi
Drives: alpine white 335xi coupe
ok just to let everyone know that unpluggin the actuator will throw codes but will not set a mil light on
so what ever u do do not unplug the actuator
      05-06-2009, 05:54 PM   #242
EuRoTUneR
Eurotuner
EuRoTUneR's Avatar
23
Drives: E90 330i
2006 330i  [0.00]
so i read each post and what i have concluded is....
1- 335+330 have it 328+325 do not
2- it does through codes, but bmw either dosn't realize or assumes we just unplug them by now
3-sounds like about 70% of people agree there is a deff change in tone?
4-20% of people think there are long term effects?
sounds like i will be unplugging it tomorrow haha
