11-27-2023, 10:13 AM | #2 |
1716
Rep 1,909
Drives: 2023 M5C
Just go to the dealership and buy it. They will ask what year/model car you own and select the correct one.
IG @windtendo_m5
11-27-2023, 10:29 AM | #3 |
55
Rep 94
BMW HT-12 and is green. If you buy the BMW jug it is concentrated. Just mix 50/50 with distilled water. Is good for both engine and turbo cooling loops, that’s what I use to top mine off.
11-27-2023, 03:28 PM | #5 | |
55
Rep 94
I knew I needed HT-12 but the dealership was swearing up and down it was blue. I even pull some from the cooland reservoir with a dropper to make sure it was green. Eventually told them to give me what I asked and got the right one. Just look it up for yourself and don’t rely on the 1st thing the dealer tells you. |
11-27-2023, 03:36 PM | #6 | |
982
Rep 1,797
GTTC55.00 |
11-28-2023, 07:36 AM | #8 |
316
Rep 398
Drives: 23 M5C, 19 X5
From ISTA:
Blue for F90 produced up to 7/31/2018. HT-12 for F90 produced from 8/1/2018. OP: Since your car is a 2019 it might be possible it was built before 8/1 which might be why different places gave you different answers. I think the change from 2018 to 2019 occurred on 8/1 though. You should be able to see if you have green or blue unless your level is really low. You can find your production date on the drive door jamb label. |
11-28-2023, 08:50 AM | #9 |
5234
Rep 10,616
https://www.getbmwparts.com/oem-part...on-83192468442
Look at the compatibility image in the link. Green HT-12 is backwards compatible with the blue G48. |
11-28-2023, 10:41 AM | #10 |
1716
Rep 1,909
Drives: 2023 M5C
All the more reason to buy it from the dealership. If they give you the wrong one it's on THEM, not you.
IG @windtendo_m5
11-30-2023, 09:36 AM | #11 |
1774
Rep 3,490
Don't worry, when it leaks all over your injectors you will know which one to use!
ResIpsaLoquitur4093.50 |
12-21-2023, 01:01 PM | #12 |
Rep 2
Drives: ‘19 F90 Competition
Hey all! Just had a question. I get a slight coolant smell upon shutting car off in the garage. I constantly check for leaks, nothing there and never had a low coolant warning. Anyone else experience this?
12-21-2023, 01:44 PM | #13 | |
838
Rep 478
Would appear it doesn’t matter because they’re compatible with each other. |
