BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    TTE920+ Turbos
      09-24-2023, 11:22 AM   #1
CrashCade
112
Drives: '19 M5 Comp,
TTE920+ Turbos
I am contemplating picking up this set of turbos and wanted to get feedback from other users running this setup. Has anyone ran these without building the engine first?
How is drivability?
Any increase in lag?
Any increase is voodoo magic boosty noises?
I know I won’t see full benefit until I build the engine. However, I am currently running an E50 stage 2 setup and due to living at 5,000’ elevation, my stock turbos struggle with providing enough air compared to a similar setup at sea level.
      09-24-2023, 11:44 AM   #2
TacoJova
72
Drives: 2015 BMW M3
How is drivability?
All cars are going to struggle more compared to sea level. Did your tuner say your turbos can’t keep up?
      09-24-2023, 11:52 AM   #3
CrashCade
112
They are definitely working harder and not as efficient due to pushing them harder at this elevation.
      09-24-2023, 04:42 PM   #4
TacoJova
72
Drives: 2015 BMW M3
Well yes. So would the TTE turbos comparing to sea level. My point is are you trying to push more power at your elevation? Cause unless you build the motor it’s a lot of money and retuning to be at the same power level since right now your limited by rods not by turbos
