BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    M Performance Exhaust Installation
      07-31-2023, 09:36 PM   #1
tntravelingman
11
Drives: 2023 BMW M5 Competition
Hey everyone, just had the M Performance Exhaust installed. I had it done at an independent euro shop. After seeing other pictures online I’m trying to figure out if my exhaust tips were installed correctly - they seem like they may be too far out from the back bumper. For those that have one, do my tips look like they’re in the right position?
Thanks!
      07-31-2023, 11:55 PM   #2
jm490
519
Drives: 21' F90 M5c
Yours are definitely sticking out more than mine are. At first I thought mine were too far in but I think they’re actually perfect and how they’re supposed to be. Another member pulled up the install guide for the exhaust and it shows that it should be under the bumper/diffuser and not sticking out past it. I’ll grab some pictures of mine tomorrow.
Funny thing is my tips wouldn’t even come out farther than they are now. There’s a notch on it that doesn’t allow it to come out further so I’m not sure how your shop even got it out that far. Maybe they shaved off the notch that holds them in place. That’s the only way I can think of making that possible.
Appreciate 2
      08-01-2023, 12:12 AM   #3
ResIpsaLoquitur
ResIpsaLoquitur's Avatar
4092
Drives: 2022 M5C
+1 — Agree with jm490. I do not have the MPE on my LCI, but I am quite familiar with it on other applications.
You should not have the gap between the lower bumper and the back of the tip indicated in your photo below when looking at profile view.
Not a BMW guy...but certainly an M5 guy.
Appreciate 2
      08-01-2023, 12:25 AM   #4
tntravelingman
11
Thank you so much for the input and pictures. I saw the guide online, which is why I was questioning it. After looking at the guide I looked at my tips, and I could a actually see the notch behind the tips - it looks like they placed them so they're pushed all the way up the notches, but the notches are definitely outside the clamp for the tips. I'm betting they didn't remove the bolt fully to place the notch between the clamp as described in the instructions. The tips on the actual product look different than in the installation instructions; in the instructions it looks like the carbon tips are angled on both edges, but the tips are cut at 90 degrees on the product. I also don't see any difference between left and right tips, as the guide suggests. Since the picture is different than the actual tips I was wondering if the guide was wrong or if it was angled on the guide for illustrative purposes.
Are those notches supposed to sit underneath the carbon then? Can you see them on yours?
      08-01-2023, 12:26 AM   #5
tntravelingman
11
I agree - that's another thing that made me question the placement! Thank you!
      08-01-2023, 12:41 AM   #6
tntravelingman
11
It's hard to get a good picture of the notch, but you can see it here behind the tip. The tip is placed all the way up to the notch.
      08-01-2023, 01:34 AM   #7
ResIpsaLoquitur
4092
Drives: 2022 M5C
You’re welcome!
      08-01-2023, 01:51 AM   #8
micvite
1540
Drives: 2009 mazda RX8
I'm not sure, I can snag a pic of mine tomorrow, maybe they didn't do the bayonet part of the instructions lol
      08-01-2023, 07:06 AM   #9
crypto
crypto's Avatar
1471
Drives: 2022 M5 CS
Can you just loosen a nut or something and push it back and re tighten?
Current: 2022 M5 CS
Past: 2021 M550i (BSM)
Past: 2010 535 xDrive (Alpine White)
      08-01-2023, 09:16 AM   #10
micvite
1540
You're not supposed to "push" you're supposed to depress the pin and turn like you're mounting a Bayonett, per the instruction😂 could just be that's the whole issue, problem is you can't get to the bolt to remove tips without lowering the whole exhaust or at least the rear section
      08-01-2023, 09:32 AM   #11
tntravelingman
11
Update everyone - I took it back to the shop, and the problem was that the tips were not installed correctly. They removed the tips, removed the screw from the tips, and per the instructions slid the tips back on with the pin passing through the bracket, and turned the tips like a bayonet fastening before reinstalling the screw.
The pins are supposed to rest beneath the carbon fiber component when installed correctly.
I've seen pictures of some other folks with the tips sticking out like mine were. Hopefully this will help others with installation!
Appreciate 2
      08-01-2023, 11:34 AM   #12
ResIpsaLoquitur
4092
Drives: 2022 M5C
There we go! Glad this got resolved for you.
      08-01-2023, 04:50 PM   #13
jm490
519
Drives: 21' F90 M5c
MUCH BETTER glad you got it fixed! Enjoy the best mod out there
Appreciate 2
      08-02-2023, 11:44 AM   #14
micvite
1540
Yeah... a little late for my pic but the pins are not visible haha😂 glad you figured it out.
      08-03-2023, 02:02 PM   #15
ElectroGeek
Drives: X5 G05 50i
Just picked mine up like 3 weeks ago, had the Exhaust added to my build and port installed.
It's in about the same place as my M8
Appreciate 2
jm490519.00
      08-19-2023, 11:24 PM   #16
theeawz
Drives: M5 F90
Share some videos now and let us hear how it sounds! 😉
      08-20-2023, 08:17 AM   #17
willyp
159
Drives: M5C, M3CS, X5
How much better does it sound? I wish the M5 was a touch louder TBH.
IG- thewillpeoples
      08-20-2023, 01:51 PM   #18
josec70
josec70's Avatar
Drives: 22' Individual Chalk M5C
Night and Day difference versus M-Sport (M5C) or Base exhaust.
In my opinion, the MPE is what a proper M5 should sound like. This is obviously subjective, but the Base and M5C are way too muted for my taste.
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
Appreciate 2
      08-20-2023, 09:52 PM   #19
jm490
519
Drives: 21' F90 M5c
As Jose above me said. It’s incredible. Best mod you can do to really liven up the car everyone that hears it is in awe
Appreciate 2
