04-28-2022, 04:22 PM | #23 |
228
Rep 298
Hey Chris, Here is a tip, hold the power button on the stereo for a few seconds when you power down the car, everything will turn off before you even open the door.
04-28-2022, 05:56 PM | #24 | |
292
Rep 605
04-28-2022, 06:08 PM | #25 |
180
Rep 659
Drives: '22 M5CS, '00 M5, '06 Z4M
Garage List 2022 M5CS [0.00]
2001 BMW 740i [0.00] 2006 BMW M Roadster [0.00] 2012 BMW X6 3.5i [0.00] 2006 BMW 325xi [0.00] 2017 BMW 540xi [0.00] 2000 BMW M5 [0.00] 2001 BMW X5 4.4i [0.00] |
THANK YOU!!! Had no idea!
'22 M5CS, '06 Z4M, '01 X5 4.4i, '00 M5, '05 Acura RL, '12 X6 3.5, '01 740, 08 335xi, '17 540xi (yes they all are still with me)
04-28-2022, 09:45 PM | #26 | |
180
Rep 659
https://smile.amazon.com/Schumacher-...ps%2C61&sr=8-9 Chris
04-29-2022, 05:22 PM | #28 |
292
Rep 605
04-29-2022, 05:41 PM | #29 |
5234
Rep 10,616
I have a cheap hand held analog “toaster” but I am sure there are big fancy digital ones. I don’t know whether testing lithium batteries is any different from lead acid batteries.
Out of curiosity, I just did a quick search and maybe the traditional load tester won’t work on the lithium battery. Perhaps all you can do without very expensive equipment is use one of those digital battery analyzers like cfoote linked. They don’t test load directly but maybe indirect is good enough. Last edited by pbonsalb; 04-29-2022 at 06:11 PM.. |
05-03-2022, 09:41 AM | #30 | |
982
Rep 1,797
I have a question. Since you have been using a trickle charger, I am wondering why you would have a failure that I would consider an early failure for a lithium ion battery. Any ideas? I considered a trickle charger but this definitely has raised a question in my mind. |
05-03-2022, 10:07 AM | #31 | |
2035
Rep 1,843
I'm using a trickle charger for almost a year now, and the LED indicator shows that the battery is fully charged and I never had a warning signal regarding the battery being low. I'm not driving my car for short drives, it probably helps. |
05-03-2022, 11:21 AM | #32 | |
2273
Rep 3,299
I used a non-lithium trickle charger ONCE. I used it ONCE. Last winter. And was AFTER THE ()*&^&*(^( BATTERY GAVE ME THE )&*()(&*()*& WARNING ABOUT "BATTERY MAINTENANCE. SO GET THE ()*^()&* OFF YOUR HIGH HORSE AND SHOVE IT UP ()&*)*&()&* I recommend, and SO THE DOES BMW based on the service manual, that the battery be charged fully now and then, with a Lithium ION charger. This should have been made VERY clear when the car was purchased. Now that I will have a new battery that will be my routine. As far as this being an 'early' failure, it looks like the AUDI DRC system all over again. My RS6 was the first to be reported to fail, I got all sorts of fan boy (&*)*& from other RS6 drivers and then one after the other virtually EVERY RS6 had that system fail. Then in the RS4 also. And Audi still offered that system in the TTRS and RS7. It was an engineering error in their design. And they all fail. The recall replacement failed. The same goes for the use of a LI battery in a car. This was a new thing for BMW. And they have failed in that concept. The car's systems know enough to cut power to other systems when the battery gets low but only warns the ()*&*&)(* driver after further drop in voltage. Dumb dumb dumb. I can't wait to see all the crow eating as one after the other batteries drop dead at "just 4 years." At least I am buying one of the few remaining LI batteries available in the US. End RANT. There I feel better. And I have been selling a bunch of un-used lawn equipment, a couple old Xbox's and monitors, and the that battery is paid for LOLOLOLOL Mike
Maverik2594140.00 |
05-03-2022, 11:28 AM | #33 | |
2273
Rep 3,299
My comfort access was not working and it turned out it was 1. the battery low in the car AND 2. the battery in the key fob. I cannot tell if the rear window defroster was out, but likely it was also as that is part of the 'save the battery, without telling the driver' method the jack ass engineers in Chermany came up with. The car has 100000 computers but not a )(*&)*& volt's meter. Dumb Dumb Dumb. Get a charger, use it. Then the LI battery should last '8 years' maybe. Mike
Maverik2594140.00 |
05-03-2022, 11:38 AM | #34 | |
2035
Rep 1,843
TheRealBob254.50 |
05-03-2022, 12:09 PM | #35 | |
4140
Rep 7,160
Drives: F90 M5 / F15 50i
I also installed a CTEK bluetooth battery voltage meter for both cars and every time i get in them i can check the voltage, temp, etc and see if that has changed over time.
'07 Yamaha R1 (sold)
05-03-2022, 12:57 PM | #36 | ||
982
Rep 1,797
05-03-2022, 01:29 PM | #37 |
2273
Rep 3,299
Are you Cam's Twin? LOL. I have a Lithium Ion Charger for the M5 and a non lithium ion charger for the Boxster.
Mike
05-03-2022, 01:31 PM | #38 | |
2273
Rep 3,299
Mike
05-03-2022, 02:05 PM | #40 | |
26
Rep 40
The CTEK Bluetooth battery voltage meter are for lead batteries according to their website specs and manual, and would NOT give an accurate reading for lithium ion batteries as they are different chemistry and thus is measured differently (resistance, voltage etc.).
Aronis2273.00 |
05-03-2022, 02:34 PM | #41 |
2273
Rep 3,299
This potentially could be a really issue for long term function of this car. The car seems built around this electrical system which is designed to work with the LI battery. So a swap to an AGM battery is not apparently possible. Perhaps. Can-am (who knows all) can tell us?
Mike
05-03-2022, 02:46 PM | #42 | |
Perennial PFC
336
Rep 1,275
Antigravity Batteries, a company in Los Angeles, has both a lead/acid version and a Li/ion version battery tracker using Bluetooth to your phone. Worth a look at only $36. Looking through the general vehicle electronics in the F90 complete vehicle .pdf on page 131, it mentions the battery supervision circuits (BUE) check state of charge, battery condition, battery capacity, and data memory for battery information. I’ve never used ISTA or even Bimmercode, but perhaps the car has that info stored somewhere for some period of time? Would it be accessible to someone who knew how to get to it? The Antigravity site says their tracker stores data for 31 days, maybe BMW does the same thing? Just chatted with customer service at Antigravity. The leads for the battery tracker are 17" terminal to terminal. I was worried our batteries might be too large for how small the tracker is. Our batteries are about 12" wide, so it should be fine. Last edited by Used2be; 05-03-2022 at 03:23 PM.. Reason: Added info |
Aronis2273.00 |
05-03-2022, 02:48 PM | #43 |
2273
Rep 3,299
From Service Manual.....
Don't let your M5 sit. I don't know which BMW cars have the LI battery but I think the battery would last much longer if it's kept charged. Lesson learned. Pass it on. I was less concerned with my other cars because the batteries are not $2000 and are actually available. "Battery recharging intervals for booth vehicles, battery charging calendars and battery tags (12-V battery, high-voltage battery unit) All models Situation: Due to the self-discharging of the vehicle battery (12 V battery, high-voltage battery unit) and vehicle standby current (if the vehicle battery was not disconnected from the vehicle electrical system), the vehicle battery is discharged slowly, but continuously. If the vehicle battery is not recharged for an extended period of time, it will be damaged. This will result in a premature battery failure. To maintain the quality of the vehicle battery in standing vehicles, it is necessary to recharge this vehicle battery regularly. Recharging intervals: 12V battery All vehicles: 12-V battery connected to the vehicle electrical system: 6 weeks All vehicles without BMW i and Plug-in Hybrid (PHEV): Continuous disconnection of the 12-V battery from the vehicle electrical system by removal of the ground cable to the 12 V battery or by switching off of the fitted battery master switch, if installed: 12 weeks Measure: Procedure:...."
05-03-2022, 06:16 PM | #44 | |
2273
Rep 3,299
I have an indy mechanic who has all the tech to check it out, but I don't like to abuse our friendship. I'll have to reach out to him. I sent my copy of the Foxwell 530 back as it did not work for me. I don't think my other scanner can do that scan. I'll have to check again. Mike
