11-16-2021, 05:10 PM | #1 |
Rep 20
2020 M5C lithium battery dead, need advice
Hello everyone, I have a 2020 M5 competition with 300 miles. It was stored for the last 9 months and now the battery is dead. It is 2 k to replace, and I live in greece and need two week to receive it from dealer as they don't have it in stock. 2 questions:
- will it make any problem if I use a normal agim battery for two weeks by the time I receive the lithium one? Positive and negative cables are ok but the is a third small cable that goes to the lithium that will be unused on the normal agim battery - I tried to contact bmw to see if they would replace it on warranty, they said they have to diagnose but if the car have low miles and is unused they won't replace it. I find this unfair. I tried to take the battery to a shop with a lithium charger and we tried to charge it without success. Any thought is appreciated |
11-18-2021, 10:53 AM | #3 |
43
Rep 177
I didn’t even know lithium battery was standard or even an option on the M5. Do all F90 M5 come with a lithium battery?
2019 Range Rover Supercharged
2015 Ferrari F12 |
11-18-2021, 11:13 AM | #4 |
2273
Rep 3,299
BMW of South Atlanta has a great online catalog for buying BMW parts from BMW. My local BMW dealer does not know what the internet is I guess.
Anyway....the part number is 61-21-6-805-461 which is a 70 AH battery. They list it as not available. Another part number listed is 61217604808 which is a 105 AH also not available. I'd love to know the true battery required for this car. Found the first part number on GetBMWparts.com for $366.00 The odd thing is they list this battery part number for almost all BMW's. So I am not sure which is correct? My understanding from this forum is that the M5 battery was some larger battery? Who knows? So replacement may not be as expensive as they say? Will be looking forward to hearing of your resolution and what the actual battery cost. Mike
11-18-2021, 11:30 AM | #5 |
801
Rep 1,214
Every F90 M5 I have worked on has had the 70Ah/860CCA Li-ion battery, mine included.
61 21 7 857 288 is the current PN, with a list price of $1,893.47 at this time. It is manufactured in Japan. |
11-19-2021, 01:55 AM | #7 | |
1540
Rep 2,008
Doctor_X1158.00 |
11-19-2021, 05:32 AM | #8 |
1113
Rep 869
Batteries for some strange reason are in short supply. 3 weeks wild be quick. We buy Indistries batteries from Trojan and full river are both very back ordered.
11-19-2021, 06:17 AM | #9 |
2273
Rep 3,299
Our cultural decline (worldwide) all thanks to man tinkering with nature for the purpose of power.
Mike
HighwayStar82.50 EPTXM577.50 |
11-19-2021, 09:54 AM | #10 |
4140
Rep 7,160
Drives: F90 M5 / F15 50i
can you not find an aftermarket solution? There's a bunch of "light weight" Li-ION options out there for cars. Not very versed in them, just know they exist.
'07 Yamaha R1 (sold)
11-19-2021, 10:06 AM | #11 |
43
Rep 177
Good to know! Good job, BMW! Even Ferrari’s don’t usually have lithium standard on most models.
2015 Ferrari F12 |
11-19-2021, 10:08 AM | #12 |
43
Rep 177
Braille, anti-gravity to name two brands I have used before.
2015 Ferrari F12 |
11-19-2021, 10:31 AM | #13 |
292
Rep 605
11-19-2021, 02:51 PM | #14 |
Rep 10
The original poster appears to be MIA but someone helped me recently so perhaps this can help someone else.
The lithium Ion battery has a built in BMS (Battery Management System) and safety relay that physically disconnects the cells from the terminals to protect itself when cell voltage gets too low. If the terminal voltage is 0, then the relay is likely "open". Someone asked what the terminal voltage was and I didn't see an answer. That was a VERY important question! If the voltage is 0- then a battery charger will NOT work because the battery terminals are "physically" disconnected from the cells that need recharging. I have been able to open up a battery and charge the cells "directly" with a Lithium Ion specific charger and then reset the relay. There's a Youtube video about this- search "BMW Lithium Ion Battery Disassembly"- you will find one from "M. Ovidiu"... that's the one to watch. I highly doubt the battery is truly "dead" - however- opening up the battery, while relatively easy, carries some risk and you should have some mechanical and electrical knowledge. Also- the car's ECU may still tell you the battery needs to be replaced even after the battery is brought back on line. I'm not that far yet but I'm hoping I can reset that message on mine. IMHO- our cars draw some significant current in stand-by mode... I'd stick with a lithium Ion battery and I think the ECU will know if you don't, but, I don't know for sure. Hope this helps. Last edited by jav1; 11-19-2021 at 03:08 PM.. |
12-08-2023, 11:04 AM | #15 | |
2038
Rep 1,843
Get the hell outa here. |
