09-20-2018, 08:47 PM | #1 |
407
Rep 2,704
M5 battery - winter storage
Gents,
I ask any feed back as most likely I will not be driving this car through winter. So, can I connect the tender charger to the hood ports, or does it need to go directly to the lithium battery in the trunk ?. Also do I need to do any other prep like pull the plugs ? or and in the gas additive ? First time doing this. |
09-20-2018, 08:59 PM | #2 |
192
Rep 390
The f90 has a lithium ion battery. I would use a lithium ion specific charger, like the ctek lithium us..it won’t over charge the lithium like a normal lead acid battery.. also connecting to the positive and ground terminal under the hood is fine, you don’t need to connect directly to the battery..on the gas I would just top the tank off full so there’s not much room for water vapor to form. If you really want to you could also put the car on jack stands so the tires don’t develop flat spots from sitting.. doing all this the car should be good for at least 6 months no problem
marcvtec407.00 phoenixbmwlife1912.50 |
09-20-2018, 09:17 PM | #3 | |
407
Rep 2,704
Any other advice would be greatly appreciated. |
09-21-2018, 07:45 PM | #6 |
///M
6654
Rep 3,683
In a trunk, right under the bottom panel
Life is too short...enjoy your life
///M |
09-21-2018, 08:07 PM | #7 |
3503
Rep 1,004
09-22-2018, 07:58 AM | #8 |
337
Rep 578
$4000 for a car battery! Wow!
BayDriverSF203.50 |
09-22-2018, 08:20 AM | #9 |
46
Rep 217
OptiMATE Lithium 4s 0.8A, TM-471, 8-step 12.8/13.2V 0.8A Battery saving charger-tester-maintainer https://www.amazon.ca/dp/B00Y38X7WI/..._GgKPBbQMB36ZR
BMW newbie, please be kind and patient
2019 M5 Competition. |
09-22-2018, 10:20 AM | #10 |
23
Rep 54
Drives: 2018 M5
I see BMW@ shopbmwusa.com has a charger they recommend for the M5 for $145 which is compatible with both Lead Acid Batteries and Lithium Ion Batteries. It looks like it is made by Ctek but I can't make out which Ctek model it is. Does anyone know?
09-23-2018, 05:55 PM | #11 |
37
Rep 48
BMW is not going to sell something that won't work on BMW's. I purchased the $145 one and it works on AMG, lead acid, and lithium-ion batteries. By the looks of it, it is the more expensive ctek model. I was wondering that same question. It's ready for this winter.
10-06-2019, 03:44 PM | #14 | |
94
Rep 419
Drives: 2019 F90 M5B, 2006 E60 550i
I lived in Minneapolis back in 1982/3 for a few months and the damn car would literally get frozen to the ground; unbelievable. I solved that problem and joined the Air Force. Eventually got stationed near Cocoa Beach (Patrick AFB). I spent most of my 10-year career there. I never did go back to visit MN... |
10-06-2019, 06:17 PM | #16 |
94
Rep 419
How long are they supposed to last? I’ve not had great experiences with batteries in my other bimmers over the years.
10-06-2019, 08:46 PM | #17 |
3619
Rep 4,532
04-27-2020, 05:19 PM | #20 |
94
Rep 106
The BMW-branded CTEK unit is a bit pricey ($135) but works well. I've used it a few times with no issue. I also picked up a NOCO Genius G3500 from Woot recently for only $35 for use on our other cars (it, like the CTEK, is supposed to work for both lithium and AGM batteries).
