09-07-2022, 03:49 PM | #1 |
1392
Rep 1,358
Battery consumption with closed car
Has anyone had this problem and can tell me what to look for? The car after 4 days stopped consumes the battery completely?
Thanks in advance! |
09-07-2022, 09:33 PM | #2 |
156
Rep 290
Drives: 2021 m550i
It was mentioned on the G30 thread that a unlocked car for 2 days took 12 hours to charge on a charger, whereas a locked car took only 2 hours to recharge.
Electronics don't fully shut down. I now keep my car in the garage locked for a lesser battery drain. |
09-08-2022, 12:06 AM | #3 |
1392
Rep 1,358
Do you have to leave it parked with the charger on so the battery doesn't drain?
09-08-2022, 05:50 AM | #4 | |
156
Rep 290
Drives: 2021 m550i
Also short trips don't give it enough time to fully charge. |
09-08-2022, 11:30 AM | #5 |
Rep 37
why does an unlocked car drain the battery faster? what does a locked car turn off to conserve battery? When locked, security systems are activated. I never lock my car in the garage and never have had a battery issue, sometimes a week before driving.
09-08-2022, 01:05 PM | #6 | |
156
Rep 290
Drives: 2021 m550i
I used a ODB MXII adapter and read the battery percentage when sitting locked for 2 days vs unlocked for 2 days. It seems it doesn't fully sleep (at least with G30s) when sitting unlocked. |
09-08-2022, 01:53 PM | #7 |
Rep 37
Probably the best test would be with an amp meter connected to pos and ground under the hood and see draw when unlocked vs. locked. Durring winter months I leave CTech lithium charger connected 24/7 with car unlocked, possible that some parasitic draw is good for cycling lithium battery or should I keep car locked all winter?
09-08-2022, 03:07 PM | #8 | |
1392
Rep 1,358
