11-21-2022, 09:15 AM | #45 |
4802
Rep 2,553
Appreciation to BC Forged NA for their personal communication this morning providing missing wheel weights for Gxs615's HCA386s, now found in the known list.
Lots of info online discussing performance and handling benefits of unsprung weight reduction, but found this short video interesting as he tried to actually define the acceleration changes using three different wheel and tire setups.(Speed Labs – Unsprung Weight and Acceleration/Why You should Buy Lighter Wheels) 5’49” |
11-29-2022, 04:45 PM | #46 |
4802
Rep 2,553
About 700 miles in with the BC Forged RZ05 wheels - what an improvement in handling and performance these lighter weight wheels seem to allow. Subjective as I've not instrumented with autocross, track or strip data, but sure wish I had made the change to lighter wheels years ago based on what I'm sensing so far.
Now even more interested to get some formal slips as the only change was the weight (same wheel specs and tires). Surprised M doesn't allow a true monoblock lightweight forged option on their Competition models (even SAVs), as this seems to be an easy fix to overall weight savings and in a location which positively influences the driving dynamic. |
Edgar_FriendlyX3M606.00 TonyTone207.00 |
12-02-2022, 11:21 AM | #47 |
2048
Rep 999
Sharing another set of BC Forged for the X3M. These are my dads new wheels that I decided to test fit and see how the bronze looks on white. Really digging them!
BC Forged RS45 - Matte Bronze 20x9.5 et18 (24.6lbs) 20x10.5 et 28 (25.4lbs) Michelin Pilot All Season 4 275/40/20 (29lbs) 315/35/20 (33lbs) Grant total: 224lbs
12-02-2022, 01:46 PM | #48 | |
4802
Rep 2,553
Known weight list updated - now up to 84 total with 61% having estimated wts (much of it thanks to you)! |
12-02-2022, 02:06 PM | #49 | |
2048
Rep 999
I'll have another set shortly after too LMAO. He got a set of Neuspeeds for winter as well. The BC are his summer.
12-02-2022, 10:14 PM | #50 |
231
Rep 149
Drives: 2022 BMW X3M, 2022 Audi RS6
Just got my Vossen HF5's in Satin Bronze on:
Total F97/98 for Vossen HF5 (21x9.5 et16, 21x11 et35)/Michelin PS4AS (255/40 R21, 295/35 R21) - wt N/A yet https://x3.xbimmers.com/forums/showp...postcount=2892
Max Well4802.00 |
12-04-2022, 02:17 PM | #51 |
Need mo $$s
873
Rep 912
New winter wheel setup:
https://x3.xbimmers.com/forums/showp...postcount=2896 Specs: Asanti Black Label ABL-31 in Satin/Gloss Black Lip https://www.asantiwheels.com/wheel/1...&finishID=1902 20x9 ET25 (38 lbs) 20x10.5 ET38 (36 lbs) Pirelli Scorpion AS 265/45-20 (32 lbs) 295/40-20 (36 lbs)
2020 TRM-BLACK X4///M Competition
2020 Porsche Macan 1995 Dodge Stealth TwinTurbo Past: 2020 X3M, 2019 TTS, 2008 X5 4.8 M Sport Last edited by 95wildtt; 12-14-2022 at 12:26 PM.. |
12-15-2022, 01:55 PM | #53 |
42
Rep 46
Vossen 21x5.5 16 offset front 21x11 35 offset rear. stock 255 front 295 rear to maintain rolling diameter.
2023 M3 X-Drive Comp
Max Well4802.00 stangd1909158.50 |
12-16-2022, 07:06 AM | #54 | |
4802
Rep 2,553
01-09-2023, 03:48 PM | #55 |
2048
Rep 999
Sharing another squared set that we mounted this past weekend!
My dad's new dedicated winter wheels. Neuspeed Rse102 Custom finished in Satin Black 20x9.5 et25 with 8mm spacers. (23.5lbs) 275/40/20 Vredstein Wintrac Pro (32lbs)
01-12-2023, 04:40 PM | #57 |
381
Rep 372
Something different...fitting a 19x9.5 up front
22.7 lbs
2022 BMW X3M - 11.604 @117.96
Gone But not forgotten 2008 BMW 135 - 10.9 @ 131 2016 BMW X6 |
01-12-2023, 06:27 PM | #58 |
2048
Rep 999
Impressive! What tire are you thinking?
01-12-2023, 06:28 PM | #59 |
381
Rep 372
01-13-2023, 05:56 AM | #60 |
4802
Rep 2,553
01-26-2023, 06:16 AM | #62 | |
4802
Rep 2,553
Received a PM from a new Member, rj202 , on 22 Jan 2023 0804AM in which he shared his combination he wished entered into the list. Was able to add to the known list as the BBS SX and Blizzak's stats already shared.
01-31-2023, 06:52 PM | #63 |
153
Rep 171
Neuspeed RSe102 20x9.5 ET25 that i repurposed off my S5. They were silver but had them powder coated high gloss black to match the trim.
Tires are Michelin Alpin 5 255/45R20 all around. Something to keep in mind that these wheels are Ball/acorn seat. BMW OEM are conical. so you'll need to purchase M14x1.25 Ball Seat bolts to go with these. Last edited by pmark837; 01-31-2023 at 07:02 PM.. |
02-01-2023, 06:41 AM | #64 | |
4802
Rep 2,553
Will be interesting to see what you plan on doing for your Summer set - are you going to just change the tires and keep these wheels, or is this a dedicated Winter set like BrockDM and others run? Once you get a taste of the improved handling these lighter combinations allow it'd be tough to go back to a heavier set! Last edited by Max Well; 02-01-2023 at 12:21 PM.. |
02-01-2023, 07:49 AM | #65 | |
153
Rep 171
02-16-2023, 03:21 PM | #66 |
381
Rep 372
19x9.5 +25 rays 57cr...to clear front 20 mm spacer required.
275/40/19 nittos. wheel is 22.8lbs tire 29lbs
Max Well4802.00 |
